Eng38 wrote: ↑2024-03-09 9:29
__ctype_tolower and __ctype_b are c library functions, which may be related to your compilation environment.
Check whether this error will occur when compiling rknpu2 directly. If an error is reported, please check your compilation environment:
1. Install rknpu2
git clone https://github.com/rockchip-linux/rknpu2.git
2. Set environment variables
export RK_RV1106_TOOLCHAIN=<SDK directory>/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf
3. Cross compilation
chmod +x build-linux_RV1106.sh
./build-linux_RV1106.sh
Note: rknpu2 has stopped maintenance, and the secondary development is still based on the routines in rknn_model_zoo
Appreciate for your reply. I figure out what is wrong with my project. I failed to set the RKNN tool chain so that the cmake used the system's gcc-linux-armhf compiler. This also may raise exception even if compiling is complete,. For instance, the execute file can not run on target board, because system's compiler uses GlibC , whereas rv1106 uses ulibc tool chain.
I fix this problem now. However, the compiling process still break down when linking with rknn. There is the :
Error:
/opt/RKNN/arm-rockchip830-linux-uclibcgnueabihf/bin/../lib/gcc/arm-rockchip830-linux-uclibcgnueabihf/8.3.0/../../../../arm-rockchip830-linux-uclibcgnueabihf/bin/ld.bfd: ../../lib/libmmdeploy.so.1.3.1: undefined reference to `rknn_run'
/opt/RKNN/arm-rockchip830-linux-uclibcgnueabihf/bin/../lib/gcc/arm-rockchip830-linux-uclibcgnueabihf/8.3.0/../../../../arm-rockchip830-linux-uclibcgnueabihf/bin/ld.bfd: ../../lib/libmmdeploy.so.1.3.1: undefined reference to `rknn_query'
/opt/RKNN/arm-rockchip830-linux-uclibcgnueabihf/bin/../lib/gcc/arm-rockchip830-linux-uclibcgnueabihf/8.3.0/../../../../arm-rockchip830-linux-uclibcgnueabihf/bin/ld.bfd: ../../lib/libmmdeploy.so.1.3.1: undefined reference to `rknn_outputs_get'
I try to fix this error by modifying part of cmake file:
link_directories("/opt/RKNN/rknpu2/runtime/RV1106/Linux/librknn_api/armhf/librknn_api.so")
link_directories("/opt/RKNN/rknpu2/runtime/RV1106/Linux/librknn_api/armhf/librknnmrt.so")
I also ensured that the rknn_api.h is included in the project.
// Copyright (c) OpenMMLab. All rights reserved.
#include "rknn_net.h"
#include <stdio.h>
#include <fstream>
#include "mmdeploy/core/logger.h"
#include "mmdeploy/core/model.h"
#include "mmdeploy/core/utils/filesystem.h"
#include "mmdeploy/core/utils/formatter.h"
namespace mmdeploy::framework {
static inline const char* const rknn_type(rknn_tensor_type type) {
switch (type) {
case RKNN_TENSOR_FLOAT32:
return "FP32";
But they don't work. I wonder if there are any solutions for this? Thanks.
