Network login
  • Certainly, you can also use ADB (Android Debug Bridge) for login. To install ADB on the Mac terminal, you'll need to use Homebrew, a commonly used package manager.Regarding login names and login passwords, please refer to https://wiki.luckfox.com/Luckfox-Pico/SSH-Telnet-Login/.
  • USB login example not working. Ping no problem via usb. Using putty I get Connection refused.
    C:\Users\Chris>ping 172.32.0.100
    Pinging 172.32.0.100 with 32 bytes of data:
    Reply from 172.32.0.100: bytes=32 time<1ms TTL=128
    Reply from 172.32.0.100: bytes=32 time=1ms TTL=128
    Ping statistics for 172.32.0.100:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
  • I got the ethernet and login issues resolved. My pico minib is now on the network and is detecting my i2c interface as well. very cool.
    [ 253.842454] rk_gmac-dwmac ffa80000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
    # i2cdetect -a -y 3
    0 1 2 3 4 5 6 7 8 9 a b c d e f
    00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
  • cgulick wrote: 2024-01-16 15:18 USB login example not working. Ping no problem via usb. Using putty I get Connection refused.
    Please note the default static IP address of the development board.
  • cgulick wrote: 2024-01-16 20:59 I got the ethernet and login issues resolved. My pico minib is now on the network and is detecting my i2c interface as well. very cool.
    Through the USB connection, on 172.32.0.93 ? How did you do it ?
    Moreover, "172.32.0.100" should be your local machine's IP on the ADB virtual bridge, not the LuckFox Pico's . :shock:
    I didn't see any ssh nor sshd in /etc/init.d , or in busybox's listing...
    PS G:\sources\LuckFox\tools\platform-tools> .\adb.exe devices
    List of devices attached
    b8e84e6881417032        device
    172.32.0.93:5555        device
    PS G:\sources\LuckFox\tools\platform-tools> .\adb.exe -s 172.32.0.93:5555 shell
    # ls
    media          linuxrc        usr            opt            dev
    lib64          root           var            oem            bin
    lib32          sbin           sys            mnt
    rockchip_test  proc           tmp            lib
    userdata       data           run            etc
    # ls /etc/init.d
    S99_auto_reboot  S21appinit       S50usbdevice
    S20urandom       S10udev          rcS
    S20linkmount     S99usb0config    rcK
    as for busybox :
    # busybox --list
    arp
    arping
    ash
    awk
    basename
    blkid
    cat
    chattr
    chgrp
    chmod
    chown
    chroot
    chrt
    chvt
    cksum
    clear
    cp
    cut
    date
    dd
    deallocvt
    devmem
    df
    dirname
    dmesg
    dnsd
    dnsdomainname
    du
    echo
    env
    ether-wake
    expr
    factor
    fallocate
    false
    find
    flock
    free
    fsck
    fsfreeze
    fstrim
    fuser
    getty
    grep
    halt
    head
    hexdump
    hostname
    hwclock
    i2cdetect
    i2cdump
    i2cget
    i2cset
    id
    ifconfig
    ifdown
    ifup
    inetd
    init
    insmod
    ipcrm
    ipcs
    kill
    killall
    killall5
    less
    linuxrc
    ln
    login
    logname
    ls
    lsattr
    lsmod
    lsof
    md5sum
    mdev
    mkdir
    mkfifo
    mknod
    mktemp
    mount
    mountpoint
    mt
    mv
    nc
    netstat
    nice
    nohup
    nproc
    passwd
    ping
    pipe_progress
    pivot_root
    poweroff
    printenv
    ps
    pwd
    rdate
    readlink
    realpath
    reboot
    renice
    rm
    rmmod
    route
    run-parts
    runlevel
    rx
    sed
    seq
    setkeycodes
    setlogcons
    setpriv
    setserial
    setsid
    sh
    shred
    sleep
    sort
    ssl_client
    start-stop-daemon
    strings
    stty
    svc
    swapoff
    swapon
    switch_root
    sync
    sysctl
    tail
    tar
    taskset
    tee
    telnetd
    test
    tftp
    timeout
    top
    touch
    tr
    true
    truncate
    tty
    udhcpc
    uevent
    umount
    uname
    uniq
    unlink
    uptime
    usleep
    uudecode
    uuencode
    vconfig
    vi
    w
    watch
    watchdog
    wc
    which
    who
    whoami
    xargs
    yes
    edit : There's a typo in the LuckFox Pico wiki, in the MobaXterm screen capture : the address read "172.0.32.93" instead of "172.32.0.93" .
    there -> https://wiki.luckfox.com/assets/images/ ... 790e10.png
    A running fox is a happy fox.
  • Thank you for pointing out the shortcomings in the Wiki.
  • @Taylor, are you sure this is for the the Pico Mini-B ? 😥
    I'm trying to establish a ssh connection on a Mini-B without an SDcard mounted (thus, no ubuntu).
    Should I flash a more up-to-date image on the NAND ? Because I ended up doing it with the contents of the "luckfox_pico_mini_b_image-20240119T155206Z-001.zip" archive, using SocToolKit.exe.
    Here's what a quick exploration of the device through ADB gives me :
    c800c8d03cffebb8        device
    PS G:\sources\LuckFox\tools\platform-tools> .\adb.exe -s c800c8d03cffebb8 shell
    # uname -a
    Linux Rockchip 5.10.110 #2 Wed Nov 8 09:51:03 CST 2023 armv7l GNU/Linux
    # which ssh
    # which ssh
    # ls /etc/s*
    /etc/shadow    /etc/services
    # ls /usr/bin/s*
    /usr/bin/svc          /usr/bin/sort         /usr/bin/setkeycodes
    /usr/bin/strings      /usr/bin/shred        /usr/bin/seq
    /usr/bin/ssl_client   /usr/bin/setsid
    Best regards.
    My problem was a wrong image reflash...
    I used the system image found in "luckfox_pico_mini_b_image-20240119T155206Z-001.zip" , that I took from the "backup" cloud directory...
    Wroooong !
    I should have used the image found in the buildroot archive from the start ! ( from the "Luckfox Pico/firmware/buildroot/luckfox_pico_mini_b_image" cloud directory ).
    Now I have a happy fox running ssh to my Putty session !
    Thanks. 😉
  • My Pico Max was actually using DHCP on the Ethernet connection by default, not the static IP as described in the manual. Had to check my router connections to find its IP.
