Luckfox pico Max Face Recognition
  • Respected Sir,
    I have run your code with previous instructions
    But no video or camera output is coming
    Ubuntu output is this:-------------------------
    # cd luckfox_retinaface_facenet_demo
    # chmod a+x ./luckfox_retinaface_facenet_demo_test
    # killall rkipc
    # ./luckfox_retinaface_facenet_demo_test ./model/RetinaFace.rknn ./model/mobilef
    acenet.rknn ./test.jpg
    this device is not whitelisted for jpeg decoder cvi
    init retinaface
    init facenet
    E RKNN: failed to allocate fd, ret: -1, errno: 12, errstr: Cannot allocate memory
    E RKNN: failed to allocate model memory!, size: 4426496, flags: #2
    Retinaface Info
    model input num: 1, output num: 3
    input tensors:
    index=0, name=input.1, n_dims=4, dims=[1, 640, 640, 3], n_elems=1228800, size=1228800, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=1.000000
    output tensors:
    index=0, name=515, n_dims=3, dims=[1, 16800, 4, 0], n_elems=67200, size=67200, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-125, scale=1.951411
    index=1, name=553, n_dims=3, dims=[1, 16800, 2, 0], n_elems=33600, size=33600, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-2, scale=0.243586
    index=2, name=592, n_dims=3, dims=[1, 16800, 10, 0], n_elems=168000, size=168000, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-119, scale=1.485194
    input_attrs[0].size_with_stride=1228800
    output mem [0] = 67200
    output mem [1] = 33600
    output mem [2] = 168000
    model is NHWC input fmt
    Facenet Info
    model input num: 0, output num: 0
    input tensors:
    output tensors:
    input_attrs[0].size_with_stride=67200
    input_mems rknn_set_io_mem fail! ret=-7
  • after few modifications this output is coming
    But Still no camera or video interference is coming
    # killall rkipc
    init retinaface
    init facenet
    Retinaface Info
    input tensors:
    output tensors:
    Facenet Info
    model input num: 1, output num: 1
    input tensors:
    index=0, name=input.1, n_dims=4, dims=[1, 160, 160, 3], n_elems=76800, size=76800, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003922
    output tensors:
    index=0, name=313, n_dims=2, dims=[1, 128, 0, 0], n_elems=128, size=128, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=9, scale=0.081335
    input_attrs[0].size_with_stride=76800
    output mem [0] = 128
    Init success
  • [email protected] wrote: 2024-03-26 8:50 after few modifications this output is coming
    # killall rkipc
    init retinaface
    init facenet
    Retinaface Info
    input tensors:
    output tensors:
    Facenet Info
    input tensors:
    output tensors:
    Init success
    Congratulations on reaching this stage, you're close to success! You've successfully loaded the RKNN model.
    However, I've noticed that you're using a program adapted for the framebuffer instead of one adapted for Restouch. This program fails to run because it can't find the framebuffer device during initialization.
    A properly adapted program for Restouch will output the type of development board.
    Please use the correct demo for validation.
     ./luckfox_retinaface_facenet_spi_demo_test ./model/RetinaFace.rknn ./model/mobilef
    This is the correct demo program.
    Downloaded 778 times
  • Thank you sir help
    Still few doubts to be cleared.
    1.Do i need to modify the CMakelist?
    2.Do i need to give the path name in CMake list?
    3.Will i compile this code folder same as previous one?
  • Sir,
    I have tried your last instructions,
    But this output is coming
    # ./luckfox_retinaface_facenet_spi_demo_test ./model/RetinaFace.rknn ./model/mob
    /bin/sh: ./luckfox_retinaface_facenet_spi_demo_test: not found
  • [email protected] wrote: 2024-03-26 9:20 Thank you sir help
    I'm very concerned about whether you can run the program normally now. Can you tell me if you can run it normally?
    1.If you need to use Luckfox-Pico Pro/Max, you'll need to modify the CMakeLists.txt file because I've enabled support for Luckfox-Pico Plus by default. You just need to choose whether to keep the line add_definitions(-DLUCKFOX_PICO_PLUS).
    2.I've already specified the location of the output folder in the CMakeLists.txt file. After compilation, you can find the output folder luckfox_retinaface_facenet_spi_demo in the parent directory (example/luckfox_retinaface_facenet/cpp_spi).
    3。I'm not sure which folder you're referring to. The attachment in my previous response contains the compiled output files, and the compilation work was all done in luckfox-pico-rknn-example/example.
  • # ./luckfox_retinaface_facenet_spi_demo_test ./model/RetinaFace.rknn ./model/mob
    ilefacenet.rknn ./test.jpg
    Sir as you see,after altering the compile version this error is showing
    Now, if i run this............no Camera or LCD interface is on
    init retinaface
    init facenet
    Retinaface Info
    input tensors:
    output tensors:
    Facenet Info
    input tensors:
    output tensors:
    Init success
    Which is to modify for SPI version for 3.5LCD restouch
  • [email protected] wrote: 2024-03-26 9:48 Sir,
    Did you use this demo I provided?
  • Yes sir,
    I have downloaded the code,
    Here is my doubt ,
    1.Do i have adb push luckfox_retinaface_facenet_spi_demo_for_promax to my DevBoard or
    adb push luckfox_retinaface_facenet_demo?
    if so then confirm?
