Hello, are the C WiringPi libraries compatible with this board? If so, which operating system do you recommend installing Ubuntu, Buildroot or AlpineLinux?
https://projects.drogon.net/raspberry-p ... d-install/
Thank you
Install the C Wirinpi libraries
In fact, Raspberry Pi is gradually phasing out this library. Currently, Luckfox does not support the WiringPi library.
Thanks for answering, so the only way to compile an application written in C is through cross compilation using Buildroot, is that correct?Luckfox Taylor wrote: ↑2024-01-25 12:54 In fact, Raspberry Pi is gradually phasing out this library. Currently, Luckfox does not support the WiringPi library.
Yes, you are correct. It is also due to the limited RAM resources.
I just bought the Pico Mini (will probably take a month or so to get it), but I am interested in how exactly to develop software for it.
I have over 20 years of experience with C, I have some bit of experience with Linux and embedded devices, but I never developed for Linux with very limited resources.
So how would one go from a "hello world" c program to actually running it on the device?
Is it enough to cross compile it then copy it via scp on the Pico Mini and then run it there? Or there are extra steps?
Yes, for C programs, they can be run after being cross-compiled on the host and copied to Pico Mini.Radup wrote: ↑2024-03-30 23:23 I just bought the Pico Mini (will probably take a month or so to get it), but I am interested in how exactly to develop software for it.
Ok, thank you.
And if I want to use some library, it has to be added by buildroot, or are there other ways?
