How to work Pico B with CSI2 Camera module as UVC.
  • Hello,
    To achieve UVC functionality with your Luckfox Pico Mini B and CSI camera module when connected to a PC via USB-C, you can refer to the tutorial at the following link:
    Tutorial link:https://wiki.luckfox.com/Luckfox-Pico/L ... usb-camera
  • Thank you for the Link. However, that is the way to connect a USB camera to a LuckFox Pico, which is the opposite of what I want to achieve.
    I will wait for the SDK to be updated in the future.
    Thanks again.
  • Thank you for your feedback. If your goal is realized in a future SDK update, we will notify you as soon as it becomes available.
  • I have the same function requirement, Does the SDK have update?
  • I believe this should work with the SDK as-is. You´d need to configure the kernel to add UVC USB gadget, then configure your usb gadget module
    https://www.kernel.org/doc/html//next/u ... t_uvc.html
