Hi, I need to make a customized SC3336 sensor board, because I need to change the mount and lens (the current one doesn't fit). Is there a reference schematic for the existing SC3336 board?
Rockchips RV1106G AI IPC reference board uses the SC530AI sensor (as shown in their schematic). Is this sensor compatible with the Pico Luck Max software?
SC3336 sensor board schematic
The camera is not independently manufactured by us, and we do not have the schematic diagram. The RV1106 theoretically supports SC530AI, but we haven't tested it yet. Apart from the software driver, their data line quantities are also different.
SC3336: MIPI D-PHY 2Lines uses two data lines to transmit data.
SC530AI: MIPI D-PHY 4Lines uses four data lines to transmit data.
