Connection refused on Pico mini B
  • Hello, you can refer to this post:
    viewtopic.php?p=1881&hilit=172.32.0.93#p1881
  • Eng38 wrote: 2024-06-27 2:10 Hello, you can refer to this post:
    I have tried, seems the respond is still connection refused. is there an issue with the USB set up or anything wrong with the imagae i have burn?
    thanks. I set the IP to 172.32.0.100
  • Try to run ifconfig on the development board to ensure that the IP address obtained by the development board is "172.32.0.93" and that the development board and the host can ping each other. If not, please check the network configuration and make sure that the firewall is turned off.
