Additional USB ports
Hey, for my application I need at least 3 USB ports, is it feasible to add more USB ports via the pins for the luckfox pico mini b? Does it support multiple USBs? If yes how can it be done?
First, set the USB mode of the Luckfox Pico Mini B to host mode. Then you can use a Type-C interface with a powered USB docking station.
Hi There, How to set the USB mode to host mode in the Ubuntu system of Pico Pro/Max?Luckfox Taylor wrote: ↑2024-07-17 12:42 First, set the USB mode of the Luckfox Pico Mini B to host mode. Then you can use a Type-C interface with a powered USB docking station.
