log
index=0, name=input.1, n_dims=4, dims=[1, 640, 640, 3], n_elems=1228800, size=1228800, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003922
index=0, name=501, n_dims=3, dims=[1, 16800, 4, 0], n_elems=67200, size=67200, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-121, scale=1.969940
index=1, name=536, n_dims=3, dims=[1, 16800, 2, 0], n_elems=33600, size=33600, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-2, scale=0.243524
index=2, name=571, n_dims=3, dims=[1, 16800, 10, 0], n_elems=168000, size=168000, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-120, scale=1.466965
model is NHWC input fmt
model input height=640, width=640, channel=3
load lable ./model/coco_80_labels_list.txt
[ 779.261699] stream_cif_mipi_id0: s_power 1, entity use_count 1
devpath = /dev/video11
driver = rkisp_v7
card = rkisp_mainpath
version = 20000
capabilities = 84201000
device_caps = 4201000
fmt = UYVY 4:2:2 59565955
fmt = Y/CbCr 4:2:2 3631564e
fmt = Y/CrCb 4:2:2 3136564e
fmt = Y/CrCb 4:2:0 3132564e
fmt = Y/CbCr 4:2:0 3231564e
rkaiq log level ff0
[ 779.571661] stream_cif_mipi_id0: open video, entity use_countt 2
[ 779.571876] stream_cif_mipi_id1: open video, entity use_countt 1
/dev/video11 does not support changing fps
rga_api version 1.10.0_[2]
[ 779.651308] rkisp rkisp-vir0: first params buf queue
[ 779.657544] rkisp_hw ffa00000.rkisp: set isp clk = 198000000Hz
[ 779.657682] rkcif-mipi-lvds: sditf_reinit_mode, mode->rdbk_mode 0, mode->name rkisp-vir0, link_mode 1
[ 779.659419] rkcif-mipi-lvds: stream[0] start streaming
[ 779.659611] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream on, src_sd: 8e63bb03, sd_name:rockchip-csi2-dphy0
[ 779.659627] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream ON
[ 779.659682] rockchip-csi2-dphy0: dphy0, data_rate_mbps 506
[ 779.659712] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 779.659723] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
WENJIE process_i8_rv1106 success,align_c = 255,grid_h = 4, grid_w = 16800
[ 781.135235] xc:GrpMsgThrd invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
[ 781.135274] CPU: 0 PID: 825 Comm: xc:GrpMsgThrd Tainted: G O 5.10.110 #1
[ 781.135282] Hardware name: Generic DT based system
[ 781.135327] [<b000f565>] (unwind_backtrace) from [<b000e037>] (show_stack+0xbKilled
/0xc)
[ 781.135354] [<b000e037>] (show_stack) from [<b03b175b>] (dump_header+0x37/0x148)
[ 781.135377] [<b03b175b>] (dump_header) from [<b004ee29>] (oom_kill_process+0x3d/0x178)
[ 781.135398] [<b004ee29>] (oom_kill_process) from [<b004f3c3>] (out_of_memory+0x21f/0x264)
[ 781.135417] [<b004f3c3>] (out_of_memory) from [<b006afbd>] (__alloc_[root@luckfox tmp]# pages_nodemask+0x44f/0x502)
[ 781.135437] [<b006afbd>] (__alloc_pages_nodemask) from [<b004da2b>] (pagecache_get_page.part.12+0x8b/0xd4)
[ 781.135453] [<b004da2b>] (pagecache_get_page.part.12) from [<b004e1fd>] (filemap_fault+0x155/0x2ac)
[ 781.135469] [<b004e1fd>] (filemap_fault) from [<b005f3d3>] (__do_fault+0x23/0x3a)
[ 781.135485] [<b005f3d3>] (__do_fault) from [<b0060f8b>] (handle_mm_fault+0x251/0x44a)
[ 781.135500] [<b0060f8b>] (handle_mm_fault) from [<b000faff>] (do_page_fault+0x10f/0x18c)
[ 781.135515] [<b000faff>] (do_page_fault) from [<b000fcd5>] (do_PrefetchAbort+0x25/0x58)
[ 781.135531] [<b000fcd5>] (do_PrefetchAbort) from [<b00092af>] (__pabt_usr+0x4f/0x50)
[ 781.135543] Exception stack(0xb13e3fb0 to 0xb13e3ff8)
[ 781.135555] 3fa0: a6d791ac 00000001 00000001 a6d5c0ec
[ 781.135567] 3fc0: 00000018 002c5d58 0000004b 00211ba0 0029d524 a6f1dec4 00000001 002143b0
[ 781.135577] 3fe0: 00000000 a5563c00 a6d4751c a6d5c000 20000010 ffffffff
[ 781.135585] Mem-Info:
[ 781.135605] active_anon:409 inactive_anon:2078 isolated_anon:0
[ 781.135605] active_file:0 inactive_file:3 isolated_file:0
[ 781.135605] unevictable:0 dirty:0 writeback:0
[ 781.135605] slab_reclaimable:823 slab_unreclaimable:1257
[ 781.135605] mapped:325 shmem:705 pagetables:51 bounce:0
[ 781.135605] free:156 free_pcp:0 free_cma:0
[ 781.135628] Node 0 active_anon:1636kB inactive_anon:8312kB active_file:0kB inactive_file:12kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1300kB dirty:0kB writeback:0kB shmem:2820kB writeback_tmp:0kB kernel_stack:616kB all_unreclaimable? yes
[ 781.135651] Normal free:624kB min:624kB low:780kB high:936kB reserved_highatomic:0KB active_anon:1636kB inactive_anon:8312kB active_file:0kB inactive_file:12kB unevictable:0kB writepending:0kB present:65536kB managed:24664kB mlocked:0kB pagetables:204kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[ 781.135659] lowmem_reserve[]: 0 0
[ 781.135675] Normal: 8*4kB (UM) 26*8kB (UM) 18*16kB (U) 1*32kB (U) 1*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB = 624kB
[ 781.135717] 708 total pagecache pages
[ 781.135729] 0 pages in swap cache
[ 781.135738] Swap cache stats: add 0, delete 0, find 0/0
[ 781.135744] Free swap = 0kB
[ 781.135750] Total swap = 0kB
[ 781.135756] 16384 pages RAM
[ 781.135762] 0 pages HighMem/MovableOnly
[ 781.135769] 10218 pages reserved
[ 781.135775] 8448 pages cma reserved
[ 781.135781] Tasks state (memory values in pages):
[ 781.135788] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[ 781.135809] [ 76] 0 76 447 17 6144 0 0 syslogd
[ 781.135823] [ 80] 0 80 446 16 6144 0 0 klogd
[ 781.135833] [ 91] 0 91 402 106 6144 0 -1000 udevd
[ 781.135849] [ 268] 0 268 447 17 6144 0 0 telnetd
[ 781.135860] [ 341] 0 341 2556 23 12288 0 0 adbd
[ 781.135872] [ 772] 0 772 192 16 6144 0 0 luckfox_switch_
[ 781.135884] [ 778] 0 778 458 30 6144 0 0 sh
[ 781.135895] [ 818] 0 818 10701 1864 49152 0 0 rknn_yolov5_dem
[ 781.135905] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=rknn_yolov5_dem,pid=818,uid=0
[ 781.135972] Out of memory: Killed process 818 (rknn_yolov5_dem) total-vm:42804kB, anon-rss:6156kB, file-rss:264kB, shmem-rss:1036kB, UID:0 pgtables:48kB oom_score_adj:0
[ 781.139640] oom_reaper: reaped process 818 (rknn_yolov5_dem), now anon-rss:0kB, file-rss:264kB, shmem-rss:0kB
[ 781.146415] rga_mm: [tgid:818] Decrement the reference of handle[5] when the user exits
[ 781.146453] rga_mm: [tgid:818] Decrement the reference of handle[6] when the user exits
[ 781.146794] stream_cif_mipi_id1: close video, entity use_count 0
[ 781.147239] stream_cif_mipi_id0: close video, entity use_count 1
[ 781.147979] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x2, cur 0x2
[ 781.155777] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream off, src_sd: 8e63bb03, sd_name:rockchip-csi2-dphy0
[ 781.155807] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream OFF
[ 781.156552] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 781.156571] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 781.156600] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 781.156794] rkcif-mipi-lvds: stream[0] stopping finished, dma_en 0x0
[ 781.157022] stream_cif_mipi_id0: s_power 0, entity use_count 0
