Unable to download firmware from upgrade_tool
  • Hello, the upgrade_tool only supports flashing images to SPI NAND and eMMC. If you are using the Luckfox Pico (which does not have SPI NAND), the flashing will not be successful. You need to use a card reader to flash the image to the SD card first, then insert it back into the Luckfox Pico and power it on to boot.
