pico ultra W case
  • buy a sheet of thin acrylic or plastic. and a handhell rotary tool. that is my setup. or find a plastic shell similar to size for repurposing. unless you have access to a 3d printer.
  • Thank you for the idea,
    Eventually I have made a case using a 3D printer including support for the external wifi antenna.
    I will post the link to the files as soon asap.
    Best regards.
    Felix
  • sounds great! thank you!
  • felix34 wrote: 2024-09-24 9:04 Eventually I have made a case using a 3D printer including support for the external wifi antenna.
    Is there an update on this case? I was going to start modifying a Milk-V Duo S case for the Pico Ultra, but if you've already done it would be great if you can share!
