我使用python export.py --rknpu --weight .\yolov5s-cls.pt导出onnx模型时发生了错误
Fusing layers...
Model summary: 117 layers, 5447688 parameters, 0 gradients, 11.4 GFLOPs
export detect model for RKNPU
Traceback (most recent call last):
File "D:\Documents\code\luckfox_yolov5\train\yolov5\export.py", line 724, in <module>
main(opt)
File "D:\Documents\code\luckfox_yolov5\train\yolov5\export.py", line 718, in main
run(**vars(opt))
File "C:\Users\hutao\anaconda3\Lib\site-packages\torch\utils\_contextlib.py", line 116, in decorate_context
return func(*args, **kwargs)
File "D:\Documents\code\luckfox_yolov5\train\yolov5\export.py", line 617, in run
model.model[-1]._register_detect_seperate(True)
File "C:\Users\hutao\anaconda3\Lib\site-packages\torch\nn\modules\module.py", line 1729, in __getattr__
raise AttributeError(f"'{type(self).__name__}' object has no attribute '{name}'")
AttributeError: 'Classify' object has no attribute '_register_detect_seperate'
lihualihua_1 wrote: ↑2024-10-24 22:15
Fusing layers...
main(opt)
run(**vars(opt))
您好,你可以参考这个示例:
https://wiki.luckfox.com/zh/Luckfox-Pic ... 错你应该使用这个命令 python export.py --rknpu --weight yolov5s.pt。你尝试导出yolov5s-cls.pt分类模型,但是脚本希望导出的是yolov5s.pt检测模型。
Alenwowo wrote: ↑2024-10-25 1:57
Fusing layers...
main(opt)
run(**vars(opt))
您好,你可以参考这个示例:
不支持yolo的cls分类模型吗?
您好,根据您提供的报错信息来看应该是使用的库版本不匹配导致'Classify' 模块找不到 '_register_detect_seperate',建议使用conda 或其他虚拟环境工具搭建开发环境,以避免版本不匹配的问题
