7inch HD screen off/backlight brightness control in Debian Bookworm
  • Hello,
    In the Bookworm system, you can try using the following commands to turn the screen off/on:
    WAYLAND_DISPLAY="wayland-1" wlr-randr --output HDMI-A-1 --off
    WAYLAND_DISPLAY="wayland-1" wlr-randr --output HDMI-A-1 --on
    Note: Replace HDMI-A-1 with your device's name. If you're not sure what your device's name is, you can find it using the following command:
    To display information about connected devices:
    kmsprint | grep Connector
    Note: If you run this command without SSH, you don’t need to add the prefix WAYLAND_DISPLAY=wayland-1.
