W21 RTL8812AU to Luckfox Pico-M-256MB
  • Hello, in theory, as long as the module you use supports USB2.0, you can connect to Luckfox Pico. You need to ensure sufficient power supply.
    There is currently no driver option for RTL8812AU in the Luckfox Pico SDK. You may need to obtain the driver source code from the supplier to transplant or compile it. The kernel module is loaded into the kernel.
