了解更多详情:
GitHub链接:https://github.com/LuckfoxTECH/luckfox- ... ADME_CN.md
Gitee链接:https://gitee.com/LuckfoxTECH/luckfox-p ... ADME_CN.md
更新说明
- 支持Ubuntu系统
- 恢复对busybox的支持,使用户可以根据自身需求选择busybox、buildroot和ubuntu
- 添加ubuntu根文件子库,并且支持github与gitee源切换
- 添加exfat文件系统的支持
- 部分bug修复
More details:
GitHub link: https://github.com/LuckfoxTECH/luckfox- ... ADME_CN.md
Gitee link: https://gitee.com/LuckfoxTECH/luckfox-p ... ADME_CN.md
Release Notes:
Support for Ubuntu system
Restore support for busybox, allowing users to choose busybox, buildroot, and ubuntu according to their needs
Add Ubuntu root file submodule and support switching between GitHub and Gitee sources
Add support for exFAT file system
Partial bug fixes
Luckfox Pico 更新通知(Luckfox Pico Update Notice)
Luckfox Pico 更新通知(202407)。以下为简单的发布说明,
了解更多详情:
Wiki 链接:https://wiki.luckfox.com/zh/Luckfox-Pico/Download
论坛链接:index.php
更新说明
Luckfox Pico Update Notification (202407). Below is a brief release note:
For more details:
Wiki link: https://wiki.luckfox.com/zh/Luckfox-Pico/Download
Forum link: index.php
Update Notes
了解更多详情:
论坛链接:index.php
更新说明
- 增加了对 Luckfox-pico-Ultra 和 Luckfox-pico-Ultra-W 的支持
- 增加了RGB屏幕切换分辨率的功能
- 增强包管理操作,使用 ./build.sh buildrootconfig 命令直接进入menuconfig选项界面
- 增强内核配置操作,使用./build.sh kernelconfig 命令直接进入menuconfig选项界面
- 增加了luckfox-config系统配置工具,可以在开发板上快速启用或禁用特定的接口,例如 I2C、SPI、GPIO 、UART和USB等端口
- 优化了./build.sh clean rootfs 会全删buildroot的问题
- 优化系统根文件系统打包流程,允许自定义`<Luckfox-pico SDK PATH>/output/out/rootfs_uclibc_rv1106`夹中的根文件
- 修复在编译Ubuntu过程中下载软件包失败等问题
- 开源 Luckfox Pico Ultra系列完整的原理图
For more details:
Update Notes
- Added support for Luckfox-pico-Ultra and Luckfox-pico-Ultra-W
- Added functionality to switch resolutions on RGB screens
- Enhanced package management operations, allowing direct access to the menuconfig interface using the ./build.sh buildrootconfig command
- Enhanced kernel configuration operations, allowing direct access to the menuconfig interface using the ./build.sh kernelconfig command
- Added the luckfox-config system configuration tool, enabling quick enablement or disablement of specific interfaces on the development board, such as I2C, SPI, GPIO, UART, and USB ports
- Optimized the ./build.sh clean rootfs command to prevent it from deleting the entire buildroot
- Optimized the system root filesystem packaging process, allowing customization of the root files in the <Luckfox-pico SDK PATH>/output/out/rootfs_uclibc_rv1106 directory
- Fixed issues with downloading software packages during Ubuntu compilation
- Open-sourced the complete schematics for the Luckfox Pico Ultra series
Luckfox Pico 更新通知(202411)。以下为简单的发布说明,
了解更多详情:
论坛链接:index.php
更新说明
Luckfox Pico Update Notification (202411). Below is a brief release note:
For more details:
Update Notes
了解更多详情:
论坛链接:index.php
更新说明
- 内核更新至 5.10.160,升级 RKNN 和 ROCKIT 驱动,RV1106G3 可以在设备树中开启超频使 NPU 算力达到 1 TOPS
- 增加了快速启动支持,可以实现在 1 s 内进入根文件系统,支持将 Luckfox Pico 模拟为 UVC 摄像头,目前适配了 Luckfox Pico Ultra / Luckfox Pico Ultra W / Luckfox Pico Pro / Luckfox Pico Max
- 增加自定义根文件系统功能,可以快速替换为第三方根文件系统
- 规范客制化根文件系统的方式,在 rootfs.img 构建时按文件系统结构替换或添加文件
- 增加USB Peripheral模式下因接触不良断开重新连接的功能
- 优化 spi-nand 构建镜像的存储空间布局
For more details:
Update Notes
- The kernel has been updated to version 5.10.160, with upgraded RKNN and ROCKIT drivers. For RV1106G3, overclocking can be enabled in the device tree, boosting NPU performance to 1 TOPS.
- Added fast boot support, enabling the system to enter the root filesystem within 1 second and emulate as a UVC camera. Currently, it is compatible with Luckfox Pico Ultra, Luckfox Pico Ultra W, Luckfox Pico Pro, and Luckfox Pico Max.
- Introduced a custom root filesystem feature, enabling quick replacement with third-party root filesystems.
- Standardized the customization of root filesystems by replacing or adding files according to the filesystem structure during `rootfs.img` construction.
- Added reconnection functionality in USB Peripheral mode to address disconnection issues caused by poor contact.
- Optimized SPI-NAND image storage layout to improve space utilization.
