log如下:
0.141228] cpu cpu0: rockchip_pvtpll_set_volt: failed to set vdd voltage (925000 1050000 uV): -22
[ 0.141403] cpu cpu0: failed to register system monitor
[ 0.141899] Synopsys Designware Multimedia Card Interface Driver
[ 0.143066] dwmmc_rockchip ffaa0000.mmc: IDMAC supports 32-bit address mode.
[ 0.143137] dwmmc_rockchip ffaa0000.mmc: Using internal DMA controller.
[ 0.143159] dwmmc_rockchip ffaa0000.mmc: Version ID is 270a
[ 0.143211] dwmmc_rockchip ffaa0000.mmc: DW MMC controller at irq 52,32 bit host data width,256 deep fifo
[ 0.144756] reboot: Failed to start orderly shutdown: forcing the issue
[ 0.146188] Emergency Sync complete
de=normal rootwait earlycon=uart8250,mmio32,0xff4c0000 console=t[ 1.062116] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
tyFIQ0 snd_soc_core.prealloc_buffer_size_kbytes=16 coherent_pool=0 ubi.mtd=6 root=ubi0:rootfs rootfsty[ 1.081145] rv1106-acodec ff480000.acodec: current soc_id: rv1106
pe=ubifs rk_dma_heap_cma=66M mtdparts=spi-nand0:256K(env),256K@256K([ 1.092373] rv1106-acodec ff480000.acodec: Use pa_ctl_gpio and pa_ctl_delay_ms: 0
idblock),512K(uboot),4M(boot),30M(oem),10M(userdata),210M(rootfs)
[[ 1.106658] xhci-hcd xhci-hcd.0.auto: remove, state 4
0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 byte[ 1.117316] NET: Registered protocol family 17
s, linear)
[ 0.000000] Inode-cache hash table entries: 8192 ([ 1.127362] usb usb2: USB disconnect, device number 1
order: 3, 32768 bytes, linear)
[ 0.000000] mem auto-init: sta[ 1.138097] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.147995] [WLAN_RFKILL]: Enter rfkill_wlan_init
ck:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 55340K/1310[ 1.153571] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
72K available (4068K kernel code, 308K rwdata, 1896K rodata, 168K in[ 1.165203] Key type dns_resolver registered
it, 134K bss, 8148K reserved, 67584K cma-reserved)
[ 0.000000[ 1.175023] xhci-hcd xhci-hcd.0.auto: remove, state 4
] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.0000[ 1.186545] Loading compiled-in X.509 certificates
00] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000[ 1.196857] usb usb1: USB disconnect, device number 1
[ 1.207888]
[ 1.209444] ********************************************************************
[ 1.216855] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 1.224255] ** **
[ 1.231654] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 1.239049] ** **
[ 1.246442] ** This means that this kernel is built to expose clk operations **
[ 1.253835] ** such as parent or rate setting, enabling, disabling, etc. **
[ 1.261229] ** to userspace, which may compromise security on your system. **
[ 1.268623] ** **
[ 1.276016] ** If you see this message and you are not debugging the **
[ 1.283410] ** kernel, report this immediately to your vendor! **
[ 1.290804] ** **
[ 1.298196] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 1.305589] ********************************************************************
[ 1.314046] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
[ 1.320321] reboot: Power down
DDR V1.10 ec2fae0c96 wesley.yao 22/11/15-10:58:09
求助:pro max内核一直重启
完整日志:
1.305241] ********************************************************************
[ 1.313716] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
[ 1.319992] reboot: Power down
S5P1
f947
F
DDRConf2
DDR3, BW=16 Col=10 Bk=8 CS0 Row=13 CS=1 Die BW=16 Size=128MB
924MHz
DDR bin out
U-Boot SPL board init
U-Boot SPL 2017.09 (Jun 01 2024 - 14:28:57)
unrecognized JEDEC id bytes: ff, ef, aa
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 3
spl: mmc init failed with error: -123
Trying to boot from MTD1
ENVF: Primary 0x00000000 - 0x00040000
ENVF: OK
Trying fit image at 0x400 sector
## Verified-boot: 0
## Checking uboot 0x00200000 (lzma @0x00400000) ... sha256(30024e32f2...) + sha256(9a0d3d1f32...) + OK
## Checking fdt 0x0025bfd8 ... sha256(51bba657c3...) + OK
Total: 270.437 ms
Jumping to U-Boot(0x00200000)
U-Boot 2017.09 (Jun 01 2024 - 14:28:57 +0800)
Model: Rockchip RV1106 EVB Board
PreSerial: 2, raw, 0xff4c0000
DRAM: 128 MiB
Sysmem: init
Relocation Offset: 07d85000
Relocation fdt: 06dfadb0 - 06dfedd8
CR: M/C/I
Using default environment
Bootdev(atags): mtd 1
ENVF: OK
PartType: ENV
DM: v2
No misc partition
boot mode: normal
DTB: rk-kernel.dtb
HASH(c): OK
Model: Luckfox Pico Max
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 924000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
aclk_peri_root 400000 KHz
hclK_peri_root 200000 KHz
pclk_peri_root 100000 KHz
aclk_bus_root 300000 KHz
pclk_top_root 100000 KHz
pclk_pmu_root 100000 KHz
hclk_pmu_root 200000 KHz
Net: eth0: ethernet@ffa80000
Hit key to stop autoboot('CTRL+C'): 0
## Booting FIT Image at 0x68dfb80 with size 0x0031a200
Fdt Ramdisk skip relocation
No misc partition
## Loading kernel from FIT Image at 068dfb80 ...
Using 'conf' configuration
## Verified-boot: 0
Trying 'kernel' kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x068e8b80
Data Size: 3215616 Bytes = 3.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha256
Hash value: 62b2c4b6e418ef0b48b13f2afd7d764ac1f9a1ec213c12acdd6672e720ef0db0
Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 068dfb80 ...
Trying 'fdt' fdt subimage
Type: Flat Device Tree
Data Start: 0x068e0380
Data Size: 34689 Bytes = 33.9 KiB
Architecture: ARM
Load Address: 0x00c00000
Hash algo: sha256
Hash value: 79f1330e72484d7269e65dd121d75a43e8f013d5f8ab71b18a888457364abb7f
Loading fdt from 0x00c00000 to 0x00c00000
Booting using the fdt blob at 0x00c00000
Loading Kernel Image from 0x068e8b80 to 0x00008000 ... OK
kernel loaded at 0x00008000, end = 0x00319100
Using Device Tree in place at 00c00000, end 00c0b780
Adding bank: 0x00000000 - 0x08000000 (size: 0x08000000)
Total: 551.60 ms
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.110 (ts@ts) (arm-rockchip830-linux-uclibcgnueabihf-gcc (crosstool-NG 1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #3 Mon Jun 3 17:25:56 CST 2024
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Luckfox Pico Max
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 67584 KiB at 0x03e00000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=mtd androidboot.storagemedia=mtd androidboot.mo000] random: get_random_bytes called from start_kernel+0x1fb/0x360 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000422] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.000442] pid_max: default: 4096 minimum: 301
[ 0.000624] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000639] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001286] CPU: Testing write buffer coherency: ok
[ 0.001775] Setting up static identity map for 0x81c0 - 0x81f8
[ 0.002192] devtmpfs: initialized
[ 0.009765] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.009988] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.010014] futex hash table entries: 16 (order: -5, 192 bytes, linear)
[ 0.010110] pinctrl core: initialized pinctrl subsystem
[ 0.010939] NET: Registered protocol family 16
[ 0.011393] DMA: failed to allocate 0 KiB pool for atomic coherent allocation
[ 0.012186] thermal_sys: Registered thermal governor 'step_wise'
[ 0.012193] thermal_sys: Registered thermal governor 'user_space'
[ 0.012458] cpuidle: using governor menu
[ 0.012492] Registered FIQ tty driver
[ 0.028634] rockchip-gpio ff380000.gpio: probed /pinctrl/gpio@ff380000
[ 0.029523] rockchip-gpio ff530000.gpio: probed /pinctrl/gpio@ff530000
[ 0.030255] rockchip-gpio ff540000.gpio: probed /pinctrl/gpio@ff540000
[ 0.031049] rockchip-gpio ff550000.gpio: probed /pinctrl/gpio@ff550000
[ 0.031750] rockchip-gpio ff560000.gpio: probed /pinctrl/gpio@ff560000
[ 0.031844] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.042076] fiq_debugger fiq_debugger.0: IRQ uart_irq not found
[ 0.042105] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 0.042394] printk: console [ttyFIQ0] enabled
[ 0.042596] Registered fiq debugger ttyFIQ0
[ 0.044867] SCSI subsystem initialized
[ 0.045111] usbcore: registered new interface driver usbfs
[ 0.045172] usbcore: registered new interface driver hub
[ 0.045227] usbcore: registered new device driver usb
[ 0.045479] mc: Linux media interface: v0.10
[ 0.045541] videodev: Linux video capture interface: v2.00
[ 0.046671] Advanced Linux Sound Architecture Driver Initialized.
[ 0.047873] rockchip-cpuinfo cpuinfo: SoC : 11061000
[ 0.047907] rockchip-cpuinfo cpuinfo: Serial : bd2b7a082ea21c02
[ 0.048344] rockchip,rknpor-powergood ff000000.syscon:rknpor-powergood: probe success!
[ 0.049171] clocksource: Switched to clocksource arch_sys_counter
[ 0.050649] NET: Registered protocol family 2
[ 0.050827] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.051325] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.051392] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.051427] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.051447] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.051556] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.051603] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.051746] NET: Registered protocol family 1
[ 0.052221] RPC: Registered named UNIX socket transport module.
[ 0.052242] RPC: Registered udp transport module.
[ 0.052251] RPC: Registered tcp transport module.
[ 0.052259] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.054642] Initialise system trusted keyrings
[ 0.054867] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.059283] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.060127] NFS: Registering the id_resolver key type
[ 0.060199] Key type id_resolver registered
[ 0.060221] Key type id_legacy registered
[ 0.060275] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.060777] Key type asymmetric registered
[ 0.060809] Asymmetric key parser 'x509' registered
[ 0.060836] io scheduler mq-deadline registered
[ 0.061267] rockchip-usb2phy ff3e0000.usb2-phy: IRQ index 0 not found
[ 0.069029] dma-pl330 ff420000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.069072] dma-pl330 ff420000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.069950] rockchip-pvtm ff240000.pvtm: pvtm@0 probed
[ 0.070191] rockchip-pvtm ff390000.pvtm: pvtm@0 probed
[ 0.070826] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.071614] ff4d0000.serial: ttyS3 at MMIO 0xff4d0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.078091] random: fast init done
[ 0.078236] random: crng init done
[ 0.089493] brd: module loaded
[ 0.096233] loop: module loaded
[ 0.097802] rockchip-spi ff500000.spi: no high_speed pinctrl state
[ 0.100512] spi-nand spi2.0: Winbond SPI NAND was found.
[ 0.100545] spi-nand spi2.0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.101701] 7 cmdlinepart partitions found on MTD device spi-nand0
[ 0.101722] Creating 7 MTD partitions on "spi-nand0":
[ 0.101753] 0x000000000000-0x000000040000 : "env"
[ 0.103773] 0x000000040000-0x000000080000 : "idblock"
[ 0.105726] 0x000000080000-0x000000100000 : "uboot"
[ 0.107697] 0x000000100000-0x000000500000 : "boot"
[ 0.109702] 0x000000500000-0x000002300000 : "oem"
[ 0.111807] 0x000002300000-0x000002d00000 : "userdata"
[ 0.113844] 0x000002d00000-0x00000ff00000 : "rootfs"
[ 0.118451] rk_gmac-dwmac ffa80000.ethernet: IRQ eth_lpi not found
[ 0.118668] rk_gmac-dwmac ffa80000.ethernet: PTP uses main clock
[ 0.118732] rk_gmac-dwmac ffa80000.ethernet: no regulator found
[ 0.118751] rk_gmac-dwmac ffa80000.ethernet: clock input or output? (input).
[ 0.118764] rk_gmac-dwmac ffa80000.ethernet: Can not read property: tx_delay.
[ 0.118785] rk_gmac-dwmac ffa80000.ethernet: set tx_delay to 0xffffffff
[ 0.118796] rk_gmac-dwmac ffa80000.ethernet: Can not read property: rx_delay.
[ 0.118806] rk_gmac-dwmac ffa80000.ethernet: set rx_delay to 0xffffffff
[ 0.118896] rk_gmac-dwmac ffa80000.ethernet: integrated PHY? (yes).
[ 0.118929] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_rx
[ 0.118954] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_tx
[ 0.118997] rk_gmac-dwmac ffa80000.ethernet: cannot get clock clk_mac_speed
[ 0.119012] rk_gmac-dwmac ffa80000.ethernet: clock input from PHY
[ 0.119279] rk_gmac-dwmac ffa80000.ethernet: init for RMII
[ 0.119487] rk_gmac-dwmac ffa80000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.119522] rk_gmac-dwmac ffa80000.ethernet: DWMAC4/5
[ 0.119536] rk_gmac-dwmac ffa80000.ethernet: DMA HW capability register supported
[ 0.119548] rk_gmac-dwmac ffa80000.ethernet: RX Checksum Offload Engine supported
[ 0.119557] rk_gmac-dwmac ffa80000.ethernet: TX Checksum insertion supported
[ 0.119566] rk_gmac-dwmac ffa80000.ethernet: Wake-Up On Lan supported
[ 0.119575] rk_gmac-dwmac ffa80000.ethernet: TSO supported
[ 0.119585] rk_gmac-dwmac ffa80000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.119595] rk_gmac-dwmac ffa80000.ethernet: TSO feature enabled
[ 0.119607] rk_gmac-dwmac ffa80000.ethernet: Using 40 bits DMA width
[ 0.122244] usbcore: registered new interface driver rt2800usb
[ 0.126471] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.126948] phy phy-ff3e0000.usb2-phy.0: illegal mode
[ 0.126994] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.127059] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 0.127298] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000022010010
[ 0.127371] xhci-hcd xhci-hcd.0.auto: irq 63, io mem 0xffb00000
[ 0.128383] hub 1-0:1.0: USB hub found
[ 0.128461] hub 1-0:1.0: 1 port detected
[ 0.128872] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.129002] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 0.129044] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 0.129119] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.129857] hub 2-0:1.0: USB hub found
[ 0.129923] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 0.130421] usbcore: registered new interface driver usb-storage
[ 0.130646] udc-core: couldn't find an available UDC - added [g_mass_storage] to list of pending drivers
[ 0.132348] rockchip-rtc ff1c0000.rtc: rockchip_rtc_compensation:timeout waiting for RTC TEST STATUS : -110
[ 0.133141] rockchip-rtc ff1c0000.rtc: registered as rtc0
[ 0.133240] rockchip-rtc ff1c0000.rtc: setting system clock to 2021-01-01T12:00:44 UTC (1609502444)
[ 0.133538] i2c /dev entries driver
[ 0.135011] i2c i2c-4: 1 i2c clients have been registered at 0x30
[ 0.135490] i2c i2c-4: 2 i2c clients have been registered at 0x30
[ 0.136809] usbcore: registered new interface driver uvcvideo
[ 0.136832] USB Video Class driver (1.1.1)
[ 0.138205] rockchip-thermal ff3c8000.tsadc: tsadc is probed successfully!
[ 0.138802] cpu cpu0: Failed to get cpu_leakage
[ 0.139475] thermal thermal_zone0: critical temperature reached (125 C), shutting down
[ 0.140435] cpu cpu0: avs=0
[ 0.141228] cpu cpu0: rockchip_pvtpll_set_volt: failed to set vdd voltage (925000 1050000 uV): -22
s, linear)
[ 1.207888]
[ 1.224255] ** **
[ 1.239049] ** **
[ 1.268623] ** **
[ 1.290804] ** **
S5P1
f947
S5P1
f947
F
DDRConf2
924MHz
DDR bin out
ENVF: OK
## Verified-boot: 0
Total: 270.437 ms
DRAM: 128 MiB
Sysmem: init
CR: M/C/I
ENVF: OK
PartType: ENV
DM: v2
No misc partition
boot mode: normal
DTB: rk-kernel.dtb
HASH(c): OK
apll 816000 KHz
dpll 924000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
No misc partition
## Verified-boot: 0
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha256
Architecture: ARM
Hash algo: sha256
Total: 551.60 ms
Starting kernel ...
s, linear)
[ 1.207888]
[ 1.224255] ** **
[ 1.239049] ** **
[ 1.268623] ** **
[ 1.290804] ** **
S5P1
f947
请优先使用网盘系统和默认镜像编译,如果自己想要添加USB WiFi等外设驱动,出现无法成功启动的情况,还需要自己排查。
我排查出来是温度过高自己关机了,这应该跟usb wifi无关吧,wifi模块在hub上,离板子很远呢:thermal thermal_zone0: critical temperature reached (125 C), shutting down
我烧回你们默认的镜像还是同样问题:cpu温度高、一直重启
可以联系买家更换。因为我们出厂的时候都是有专门测试的,不清楚是不是快递运输导致的元器件虚焊。
I have the same problem, so I returned it to the seller.
