Hi
I have a Pico Mini B and I am trying to flash the firmware to my SD card. I have 2 SD cards: 64 GB and 128 GB.
But the flashing tool does not find them at step 2 below:
What is the problem? I can see both in Windows file explorer.
Do you open the flashing tool as an administrator?
Hi, thanks for your answer.
Yes, I did exactly as suggested in the FAQ:
Run the software as an administrator by right-clicking and then insert the TF card. If it still cannot be recognized, close the antivirus software and redownload the software.
Is there a maximum supported SD card size? Is 64GB or 128GB too much?
I tried on another computer, with the same result.
Lesept on 2025-01-08 9:48, edited 2 times in total.
Thanks a lot. I had version 1.85 downloaded from Luckfox website:
https://wiki.luckfox.com/Luckfox-Pico/L ... burn-image. I tried on another computer with the same result.
I have tried your version (both with the SD card already mounted or not), but it doesn't change: the device is not detected.
I have tried formatting the SD card with FAT32, NTFS, ex-FAT, with fast and hard format : no change.
Could it be possible to provide an image (.iso or .img file) of the firmware that I could copy on the SD card using other software, such as Win32diskimager?
Lesept on 2025-01-09 15:03, edited 2 times in total.
There are currently no pre-burned image files available; all files need to be written to the SD card using software.
Thank you. I understand that, but as I can't use the burning software, I expected that someone could write the files on an empty SD card and make an image of it, then put it somewhere where I can download it to finally burn it on my SD card (using a different software).
Don't close SocToolKit, replug your sd card should work
Thanks, it should work, but doesn't.
I'll try again later on a Linux computer.
But the easiest way would be (TMHA) to burn an image with another software
Can anyone help me, please?
