I'm currently working on a project using the Luckfox Pico Ultra W with Buildroot. I'm trying to convert an ONNX model to RKNN using the RKNN-Toolkit2, but I've encountered issues during the conversion process.
Model information:
The model I'm using is the Yolov5 fire detection model, which can be found at: https://github.com/spacewalk01/yolov5-f ... main/model
I tried converting the ONNX model to RKNN using RKNN-Toolkit2 versions 1.6.0 and 2.3.0
I referred to the RKNN Inference Test guide on the Luckfox wiki and followed the steps there.
Previously, I was able to implement an object detection example using YOLOv5 from Rockchip following the RKNN Inference Test guide, and this model worked well.
Errors Encountered:
With RKNN-Toolkit2 version 1.6.0:
(RKNN-Toolkit2) bt@bt:~/Test-Yolov5_fire/onnx_to_rknn/scripts/luckfox_onnx_to_rknn/convert$ python convert.py ../model/yolov5s_best.onnx ../dataset/50.txt ../model/yolov5s_best.rknn Yolov5
W __init__: rknn-toolkit2 version: 1.6.0+81f21f4d
--> Config model
done
--> Loading model
W load_onnx: It is recommended onnx opset 19, but your onnx model opset is 12!
W load_onnx: Model converted from pytorch, 'opset_version' should be set 19 in torch.onnx.export for successful convert!
Loading : 100%|█████████████████████████████████████████████████| 135/135 [00:00<00:00, 6453.29it/s]
done
--> Building model
W build: found outlier value, this may affect quantization accuracy
const name abs_mean abs_std outlier value
onnx::Conv_371 0.95 1.68 17.561
E build: Unsupport file 0!
W build: ===================== WARN(4) =====================
E rknn-toolkit2 version: 1.6.0+81f21f4d
E build: Catch exception when building RKNN model!
E build: Traceback (most recent call last):
E build: File "rknn/api/rknn_base.py", line 1992, in rknn.api.rknn_base.RKNNBase.build
E build: File "rknn/api/graph_optimizer.py", line 1949, in rknn.api.graph_optimizer.GraphOptimizer.sparse_weight
E build: File "rknn/api/sparse_weight.py", line 528, in rknn.api.sparse_weight.sparse_weight
E build: File "rknn/api/sparse_weight.py", line 75, in rknn.api.sparse_weight._range_input
E build: File "rknn/api/rknn_log.py", line 92, in rknn.api.rknn_log.RKNNLog.e
E build: ValueError: Unsupport file 0!
W If you can't handle this error, please try updating to the latest version of the toolkit2 and runtime from:
https://console.zbox.filez.com/l/I00fc3 (Pwd: rknn) Path: RKNPU2_SDK / 1.X.X / develop /
If the error still exists in the latest version, please collect the corresponding error logs and the model,
convert script, and input data that can reproduce the problem, and then submit an issue on:
https://redmine.rock-chips.com (Please consult our sales or FAE for the redmine account)
Build model failed!
(RKNN-Toolkit2-2.3.0) bt@bt:~/Test-Yolov5_fire/onnx_to_rknn/scripts/luckfox_onnx_to_rknn/convert$ python convert.py ../model/yolov5s_best.onnx ../dataset/50.txt ../model/yolov5s_best.rknn Yolov5
I rknn-toolkit2 version: 2.3.0
--> Config model
done
--> Loading model
I Loading : 100%|███████████████████████████████████████████████| 121/121 [00:00<00:00, 5865.48it/s]
done
--> Building model
I OpFusing 0: 100%|███████████████████████████████████████████████| 100/100 [00:01<00:00, 90.17it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:01<00:00, 63.66it/s]
I OpFusing 2 : 100%|██████████████████████████████████████████████| 100/100 [00:02<00:00, 36.36it/s]
W build: ===================== WARN(1) =====================
E rknn-toolkit2 version: 2.3.0
File "rknn/api/rknn_log.py", line 344, in rknn.api.rknn_log.error_catch_decorator.error_catch_wrapper
File "rknn/api/rknn_base.py", line 1967, in rknn.api.rknn_base.RKNNBase.build
File "rknn/api/graph_optimizer.py", line 2340, in rknn.api.graph_optimizer.GraphOptimizer.sparse_weight
File "rknn/api/sparse_weight.py", line 542, in rknn.api.sparse_weight.sparse_weight
File "rknn/api/sparse_weight.py", line 83, in rknn.api.sparse_weight._range_input
File "rknn/api/rknn_log.py", line 95, in rknn.api.rknn_log.RKNNLog.e
I ===================== WARN(0) =====================
During handling of the above exception, another exception occurred:
File "convert.py", line 44, in <module>
ret = rknn.build(do_quantization=True, dataset=dataset_path)
File "/home/taibt/miniconda3/envs/RKNN-Toolkit2-2.3.0/lib/python3.8/site-packages/rknn/api/rknn.py", line 192, in build
return self.rknn_base.build(do_quantization=do_quantization, dataset=dataset, expand_batch_size=rknn_batch_size)
File "rknn/api/rknn_log.py", line 349, in rknn.api.rknn_log.error_catch_decorator.error_catch_wrapper
ValueError: Traceback (most recent call last):
ValueError: Unsupport file 0! Questions:
1. Has anyone encountered a similar issue with Luckfox Pico Ultra W or RKNN-Toolkit2 when converting ONNX models?
2. Are there any specific steps or configuration changes I can apply to resolve the "Unsupport file 0!" error?
3.Could the issue be related to the model itself (e.g., unsupported operators or opset issues), and how can it be resolved?
I would appreciate any advice or tips on how to move forward with this issue.
Thank you!
