Hello, I've purchased the Luckfox 7″ HD Touchscreen to use a small secondary monitor on my windows 11 PC.
I've exhausted every option I could to try to be able to firstly adjust scaling of text and features on this monitor and also to adjust brightness of it. I understand now that this is definetly not meant to be used a secondary windows monitor, since it lacks all these features. But I would still like to ask here on the forums if it is possible to adjust brightness somehow?
I could adjust it a bit via Nvidia control panel, but i would like to have a profile that i could switch between brightness levels.
If anyone knows how to do this please help.
And additionally if anyone knows the procedure to get windows text scaling enabled on this monitor I would also appriciate it greatly. Thank you!
I have to add, I'm not a programmer, so I apologise for any lack of knowledge on this topic from my side.
7″ HD Touchscreen Windows brightness
Hello
1. Enable window text scaling, you can open Settings (Win + I).
Select Ease of Access.
Under Display options, you can adjust Text size.
2. This screen does not currently support dimming on WindowPC
Hello, thank you for replying. I was wondering if I could do text scaling for the secondary (luckfox) monitor only?
Since the accesibility text size feature affects my primary monitor aswell.
For the dimming I was able to do it with third party software.
If anyone needs it: https://github.com/datbnh/ScreenDimmer
Hello
Thanks for sharing the dimming software!
I haven't found a way to change the font size of only one screen yet. If I find it later, I will update it here
