SD card does not appear, the drop-down list (labelled "Usb Disk") is empty. I tried with and without antivirus active, also I tried it in a different machines and still the same issue. In all tests I run the tool always as administrator.
Help will be appreciated!
Hello, format the SD card and unplug it from the computer, then open SocTookit and then insert the SD card;
At the same time, please make sure that your SD card can work normally, and that it can read and write normally on the computer
