LuckFox pico mini type c傳輸問題
  • Hello, it is feasible to pull data to the computer through type-C, you can simulate the USB as a USB0 network device, and use the operation of the network device to pull the data of the LuckFox pico mini, such as using scp to get the data
    At the same time, LuckFox pico mini also supports the adb function, which can be used to adb pull xxxx to get data after setting up the Windows environment
  • 不好意思,想請問我要如何透過type c即時傳輸資料,我將usb設成device,但是我電腦看不到新的COM裝置
  • 暂时没有测试即时传输资料方法,我们当前只有这几种文件传输方法。
    https://wiki.luckfox.com/zh/Luckfox-Pic ... e-Transfer
