Device connection problems in the flushing tool
  • Hello, what system is it exactly? Which IP address was used to log in? USB static IP or network port dynamic IP? If it is a USB static IP, make sure that the development board and the computer are under the same LAN, that is, set RNDIS.
  • I found the IP of the Luckfox device using an IP scanner, as shown in the first image. Then, I used MobaXterm to connect to the Luckfox Pico device by entering its IP address. However, when I entered 'luckfox' as the password, I received an 'Access denied' message, as shown in the previous screenshot.
  • The latest images of the network disk have SSH enabled by default. If you can scan the IP normally, you can connect normally. Please log in according to the Wiki login account and password. If you cannot log in, try ADB or serial port login and use the ping command to check whether the development board and the computer are in the same LAN.
