boot fail when enable ftrace
  • Hello, it is recommended that you use the USB to serial port tool to obtain the boot log for analysis, the LED is flashing with the kernel activity, and stopping the flashing indicates that the kernel may fail to boot
  • Crocodile wrote: 2025-03-27 1:33 Hello, it is recommended that you use the USB to serial port tool to obtain the boot log for analysis, the LED is flashing with the kernel activity, and stopping the flashing indicates that the kernel may fail to boot
    thanks for your replay,the uart ouput is below:
    ```bash
    DTB: rk-kernel.dtb
    HASH(c): OK
    Model: Luckfox Pico Mini
    ## retrieving sd_update.txt ...
    MMC: no card present
    mmc_init: -123, time 2
    CLK: (uboot. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
    apll 816000 KHz
    dpll 528000 KHz
    gpll 1188000 KHz
    cpll 1000000 KHz
    aclk_peri_root 400000 KHz
    hclK_peri_root 200000 KHz
    pclk_peri_root 100000 KHz
    aclk_bus_root 300000 KHz
    pclk_top_root 100000 KHz
    pclk_pmu_root 100000 KHz
    hclk_pmu_root 200000 KHz
    Net: eth0: ethernet@ffa80000
    Hit key to stop autoboot('CTRL+C'): 0
    ## Booting FIT Image at 0x2927f40 with size 0x002d1800
    Fdt Ramdisk skip relocation
    No misc partition
    ## Loading kernel from FIT Image at 02927f40 ...
    Using 'conf' configuration
    ## Verified-boot: 0
    Trying 'kernel' kernel subimage
    Description: unavailable
    Type: Kernel Image
    Compression: uncompressed
    Data Start: 0x02931540
    Data Size: 2916712 Bytes = 2.8 MiB
    Architecture: ARM
    OS: Linux
    Load Address: 0x00008000
    Entry Point: 0x00008000
    Hash algo: sha256
    Hash value: 24b339fee0ac6d0a5108836d3c906a34a459a2f1fa30521aae4103c49c3148a6
    Verifying Hash Integrity ... sha256+ OK
    ## Loading kernel from FIT Image at 02927f40 ... 15:07:08 [1645/1913]
    ## Verified-boot: 0
    Type: Kernel Image
    Architecture: ARM
    OS: Linux
    Hash algo: sha256
    ## Loading fdt from FIT Image at 02927f40 ...
    Trying 'fdt' fdt subimage
    Type: Flat Device Tree
    Data Start: 0x02928740
    Data Size: 36058 Bytes = 35.2 KiB
    Architecture: ARM
    Load Address: 0x00c00000
    Hash algo: sha256
    Hash value: ec878326be328d02cf921dd47e26715622d000bcf412e78c8a936ec0f5bb3285
    Loading fdt from 0x02927f40 to 0x00c00000
    Booting using the fdt blob at 0x00c00000
    Loading Kernel Image from 0x02931540 to 0x00008000 ... OK
    kernel loaded at 0x00008000, end = 0x002d0168
    Using Device Tree in place at 00c00000, end 00c0bcd9
    Adding bank: 0x00000000 - 0x04000000 (size: 0x04000000)
    Total: 634.247/846.763 ms
    Starting kernel ...
    and i have report this issue on github https://github.com/LuckfoxTECH/luckfox-pico/issues/256
  • Hello,Please choose either the forum or GitHub Issues to report your problem. Submitting feedback through multiple channels may lead to duplicate responses and increase our workload. Thank you for your understanding.
    Your kernel doesn't seem to boot successfully, it may be that the image is not burned correctly, I tried your configuration, if you dynamically load the .ko driver provided by rockchip at startup, it will report an error, you can first move /oem/usr/insmod_ko.sh to other directories to let the loading of .ko not run automatically, so that the kernel can load normally
