make -C /home/johnny/luckfox-pico/sysdrv/source/kernel ARCH=arm mrproper
make[1]: Entering directory '/home/johnny/luckfox-pico/sysdrv/source/kernel'
/usr/bin/env: 'python': No such file or directory
/usr/bin/env: "python": 没有那个文件或目录
expr: 语法错误
make[1]: Leaving directory '/home/johnny/luckfox-pico/sysdrv/source/kernel'
make O=/home/johnny/luckfox-pico/sysdrv/source/objs_kernel -C /home/johnny/luckfox-pico/sysdrv/source/kernel ARCH=arm \
CROSS_COMPILE=arm-rockchip830-linux-uclibcgnueabihf- luckfox_rv1106_linux_defconfig || exit 1
make[2]: 进入目录“/home/johnny/luckfox-pico/sysdrv/source/objs_kernel”
GEN Makefile
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
YACC scripts/kconfig/parser.tab.[ch]
HOSTCC scripts/kconfig/lexer.lex.o
HOSTCC scripts/kconfig/parser.tab.o
HOSTCC scripts/kconfig/preprocess.o
HOSTCC scripts/kconfig/symbol.o
HOSTCC scripts/kconfig/util.o
HOSTLD scripts/kconfig/conf
init/Kconfig:33
# configuration written to .config
make[2]: 离开目录“/home/johnny/luckfox-pico/sysdrv/source/objs_kernel”
CROSS_COMPILE=arm-rockchip830-linux-uclibcgnueabihf- rv1106g-luckfox-pico-max.img BOOT_ITS=/home/johnny/luckfox-pico/sysdrv/source/kernel/boot.its -j1 || exit 1
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
LEX scripts/dtc/dtc-lexer.lex.c
YACC scripts/dtc/dtc-parser.tab.[ch]
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
UPD include/config/kernel.release
DTC arch/arm/boot/dts/rv1106g-luckfox-pico-max.dtb
GEN Makefile
SYSHDR arch/arm/include/generated/uapi/asm/unistd-common.h
SYSHDR arch/arm/include/generated/uapi/asm/unistd-oabi.h
SYSHDR arch/arm/include/generated/uapi/asm/unistd-eabi.h
HOSTCC scripts/kallsyms
HOSTCC scripts/resource_tool
HOSTCC scripts/sorttable
HOSTCC scripts/asn1_compiler
HOSTCC scripts/extract-cert
WRAP arch/arm/include/generated/uapi/asm/kvm_para.h
WRAP arch/arm/include/generated/uapi/asm/bitsperlong.h
WRAP arch/arm/include/generated/uapi/asm/bpf_perf_event.h
WRAP arch/arm/include/generated/uapi/asm/errno.h
WRAP arch/arm/include/generated/uapi/asm/ioctl.h
WRAP arch/arm/include/generated/uapi/asm/ipcbuf.h
WRAP arch/arm/include/generated/uapi/asm/msgbuf.h
WRAP arch/arm/include/generated/uapi/asm/param.h
WRAP arch/arm/include/generated/uapi/asm/poll.h
WRAP arch/arm/include/generated/uapi/asm/resource.h
WRAP arch/arm/include/generated/uapi/asm/sembuf.h
WRAP arch/arm/include/generated/uapi/asm/shmbuf.h
WRAP arch/arm/include/generated/uapi/asm/siginfo.h
WRAP arch/arm/include/generated/uapi/asm/socket.h
WRAP arch/arm/include/generated/uapi/asm/sockios.h
WRAP arch/arm/include/generated/uapi/asm/termbits.h
WRAP arch/arm/include/generated/uapi/asm/termios.h
WRAP arch/arm/include/generated/asm/early_ioremap.h
WRAP arch/arm/include/generated/asm/extable.h
WRAP arch/arm/include/generated/asm/flat.h
WRAP arch/arm/include/generated/asm/parport.h
WRAP arch/arm/include/generated/asm/compat.h
WRAP arch/arm/include/generated/asm/current.h
WRAP arch/arm/include/generated/asm/emergency-restart.h
WRAP arch/arm/include/generated/asm/exec.h
WRAP arch/arm/include/generated/asm/irq_regs.h
WRAP arch/arm/include/generated/asm/kdebug.h
WRAP arch/arm/include/generated/asm/local.h
WRAP arch/arm/include/generated/asm/local64.h
WRAP arch/arm/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm/include/generated/asm/mmiowb.h
WRAP arch/arm/include/generated/asm/msi.h
WRAP arch/arm/include/generated/asm/preempt.h
WRAP arch/arm/include/generated/asm/rwonce.h
WRAP arch/arm/include/generated/asm/serial.h
WRAP arch/arm/include/generated/asm/simd.h
WRAP arch/arm/include/generated/asm/trace_clock.h
UPD include/generated/uapi/linux/version.h
UPD include/generated/utsrelease.h
SYSNR arch/arm/include/generated/asm/unistd-nr.h
GEN arch/arm/include/generated/asm/mach-types.h
SYSTBL arch/arm/include/generated/calls-oabi.S
SYSTBL arch/arm/include/generated/calls-eabi.S
CC scripts/mod/empty.o
/home/johnny/luckfox-pico/sysdrv/source/kernel/scripts/Makefile.build:273: recipe for target 'scripts/mod/empty.o' failed
make[4]: *** [scripts/mod/empty.o] Error 127
/home/johnny/luckfox-pico/sysdrv/source/kernel/Makefile
make[3]: *** [prepare0] Error 2
arch/arm/Makefile:375: recipe for target 'rv1106g-luckfox-pico-max.img' failed
make[2]: *** [rv1106g-luckfox-pico-max.img] Error 2
Makefile:185: recipe for target '__sub-make' failed
make[1]: *** [__sub-make] Error 2
Makefile:484: recipe for target 'kernel' failed
make: *** [kernel] Error 1
make: Leaving directory '/home/johnny/luckfox-pico/sysdrv'
[build.sh:error] Running build_kernel failed!
[build.sh:error] exit code 2 from line 846:
[build.sh:info] make kernel -C ${SDK_SYSDRV_DIR} $kernel_build_options KERNEL_DTS=${RK_KERNEL_DTS} KERNEL_CFG=${RK_KERNEL_DEFCONFIG} KERNEL_CFG_FRAGMENT=${RK_KERNEL_DEFCONFIG_FRAGMENT}
