Please help me check which part is wrong. Thank you!!
this is my main code:
int main(int argc, char *argv[]) {
system("RkLunch-stop.sh");
RK_S32 s32Ret = 0;
int width = DISP_WIDTH;
int height = DISP_HEIGHT;
char fps_text[16];
float fps = 0;
memset(fps_text,0,16);
//h264_frame
VENC_STREAM_S stFrame;
stFrame.pstPack = (VENC_PACK_S *)malloc(sizeof(VENC_PACK_S));
RK_U64 H264_PTS = 0;
RK_U32 H264_TimeRef = 0;
VIDEO_FRAME_INFO_S stViFrame;
// Create Pool
MB_POOL_CONFIG_S PoolCfg;
memset(&PoolCfg, 0, sizeof(MB_POOL_CONFIG_S));
PoolCfg.u64MBSize = width * height * 3 ;
printf("%d\n",atoi(argv[1]));
RK_U32 blk = (RK_U32)atoi(argv[1]);
PoolCfg.u32MBCnt = blk;
printf("%d\n",blk);
PoolCfg.enAllocType = MB_ALLOC_TYPE_DMA;
//PoolCfg.bPreAlloc = RK_FALSE;
MB_POOL src_Pool = RK_MPI_MB_CreatePool(&PoolCfg);
printf("Create Pool success !\n");
// Get MB from Pool
MB_BLK src_Blk = RK_MPI_MB_GetMB(src_Pool, width * height * 3, RK_TRUE);
// Build h264_frame
VIDEO_FRAME_INFO_S h264_frame;
h264_frame.stVFrame.u32Width = width;
h264_frame.stVFrame.u32Height = height;
h264_frame.stVFrame.u32VirWidth = width;
h264_frame.stVFrame.u32VirHeight = height;
h264_frame.stVFrame.enPixelFormat = RK_FMT_RGB888;
h264_frame.stVFrame.u32FrameFlag = 160;
h264_frame.stVFrame.pMbBlk = src_Blk;
unsigned char *data = (unsigned char *)RK_MPI_MB_Handle2VirAddr(src_Blk);
cv::Mat frame(cv::Size(width,height),CV_8UC3,data);
// rkaiq init
RK_BOOL multi_sensor = RK_FALSE;
const char *iq_dir = "/etc/iqfiles";
rk_aiq_working_mode_t hdr_mode = RK_AIQ_WORKING_MODE_NORMAL;
//hdr_mode = RK_AIQ_WORKING_MODE_ISP_HDR2;
SAMPLE_COMM_ISP_Init(0, hdr_mode, multi_sensor, iq_dir);
SAMPLE_COMM_ISP_Run(0);
// rkmpi init
if (RK_MPI_SYS_Init() != RK_SUCCESS) {
RK_LOGE("rk mpi sys init fail!");
return -1;
// rtsp init
rtsp_demo_handle g_rtsplive = NULL;
rtsp_session_handle g_rtsp_session;
g_rtsplive = create_rtsp_demo(554);
g_rtsp_session = rtsp_new_session(g_rtsplive, "/live/0");
rtsp_set_video(g_rtsp_session, RTSP_CODEC_ID_VIDEO_H264, NULL, 0);
rtsp_sync_video_ts(g_rtsp_session, rtsp_get_reltime(), rtsp_get_ntptime());
// vi init
vi_dev_init();
vi_chn_init(0, width, height);
if(vpss_init(0,width, height)== RK_SUCCESS){
printf("VPSS INIT SUCCESS\n");
// venc init
RK_CODEC_ID_E enCodecType = RK_VIDEO_ID_AVC;
venc_init(0, width, height, enCodecType);
MPP_CHN_S stSrcChn,stvpssChn;
stSrcChn.enModId = RK_ID_VI;
stSrcChn.s32ChnId =0;
stSrcChn.s32DevId = 0;
stvpssChn.enModId = RK_ID_VPSS;
stvpssChn.s32ChnId =0;
stvpssChn.s32DevId = 0;
RK_MPI_SYS_Bind(&stSrcChn,&stvpssChn);
printf("init success\n");
while(1) {
// get vi frame
h264_frame.stVFrame.u32TimeRef = H264_TimeRef++;
h264_frame.stVFrame.u64PTS = TEST_COMM_GetNowUs();
// s32Ret = RK_MPI_VI_GetChnFrame(0, 0, &stViFrame, -1);
s32Ret = RK_MPI_VPSS_GetChnFrame(0,0,&stViFrame, -1);
if(s32Ret == RK_SUCCESS)
void *vi_data = RK_MPI_MB_Handle2VirAddr(stViFrame.stVFrame.pMbBlk);
cv::Mat yuv420sp(height + height / 2, width, CV_8UC1, vi_data);
cv::Mat bgr(height, width, CV_8UC3, data);
// cv::rotate(bgr,bgr,ROTATION_180);
cv::cvtColor(yuv420sp, bgr, cv::COLOR_YUV420sp2BGR);
cv::resize(bgr, frame, cv::Size(width ,height), 0, 0, cv::INTER_LINEAR);
sprintf(fps_text,"fps = %.2f",fps);
cv::putText(frame,fps_text,
cv::Point(40, 40),
cv::FONT_HERSHEY_SIMPLEX,1,
cv::Scalar(0,255,0),2);
memcpy(data, frame.data, width * height * 3);
// encode H264
RK_MPI_VENC_SendFrame(0, &h264_frame ,-1);
// rtsp
s32Ret = RK_MPI_VENC_GetStream(0, &stFrame, -1);
if(s32Ret == RK_SUCCESS) {
if(g_rtsplive && g_rtsp_session) {
//printf("len = %d PTS = %d \n",stFrame.pstPack->u32Len, stFrame.pstPack->u64PTS);
void *pData = RK_MPI_MB_Handle2VirAddr(stFrame.pstPack->pMbBlk);
rtsp_tx_video(g_rtsp_session, (uint8_t *)pData, stFrame.pstPack->u32Len,
rtsp_do_event(g_rtsplive);
RK_U64 nowUs = TEST_COMM_GetNowUs();
fps = (float) 1000000 / (float)(nowUs - h264_frame.stVFrame.u64PTS);
// release frame
s32Ret = RK_MPI_VI_ReleaseChnFrame(0, 0, &stViFrame);
if (s32Ret != RK_SUCCESS) {
RK_LOGE("RK_MPI_VI_ReleaseChnFrame fail %x", s32Ret);
s32Ret = RK_MPI_VENC_ReleaseStream(0, &stFrame);
RK_LOGE("RK_MPI_VENC_ReleaseStream fail %x", s32Ret);
// Destory MB
RK_MPI_MB_ReleaseMB(src_Blk);
// Destory Pool
RK_MPI_MB_DestroyPool(src_Pool);
RK_MPI_VI_DisableChn(0, 0);
RK_MPI_VI_DisableDev(0);
RK_MPI_VPSS_StopGrp(0);
RK_MPI_VPSS_DestroyGrp(0);
SAMPLE_COMM_ISP_Stop(0);
RK_MPI_VENC_StopRecvFrame(0);
RK_MPI_VENC_DestroyChn(0);
free(stFrame.pstPack);
if (g_rtsplive)
rtsp_del_demo(g_rtsplive);
RK_MPI_SYS_Exit();
=== 0 ===
RTDeviceV4L2 15:57:56-766 {ispStreamOn :511} do ispStreamOn done
vpss_init
rga_api version 1.10.1_[0]
VPSS INIT SUCCESS
venc_init
MpiAdapterEncode 15:57:56-780 {ma_encode_create :1743} ringbuf buf_size 3112960
MpiAdapterEncode 15:57:56-788 {ma_encode_create :1782} mem_fd = 55
init success
=== 1 ===
MpiAdapterEncode 15:57:56-863 {ma_encode_get_pack:2079} map ptr: 0xa3d9e000, fd 56
[DEBUG utils.c:134:rtsp_codec_data_parse_from_user_h264] sps 30
[DEBUG utils.c:142:rtsp_codec_data_parse_from_user_h264] pps 4
