Hello.
Is it possible to stream 2 streams simultaneously (like securiy cameras) using the CSI camera (sc3336) with the default buidroot?
rtsp 2 streams
Hello, it is feasible to output two streams simultaneously using Luckfox-pico. Default rkipc application is output two flow at the same time, the address of the RTSP for rtsp://${IP}/live/0 and rtsp://${IP}/live/1. To set the output resolution using the sc3336 sensor, you can modify /oem/usr/share/rkipc-300w.ini
