My camera turns very green when connected, how can I fix this?
There are also other issues that bother me.There are also other issues that bother me:
How do I control the lens filter change?
What does the switch on the camera do? It is not described anywhere in the documentation.
omni3576 problem with imx415
1. If the image you get is green, it usually means you have to bring a RAW image. In one case, you obtained the wrong node, or in another case, your configuration is incorrect, causing the ISP to not work properly.
2. You can control IR-CUT through the corresponding IO0 of CSI. If your corresponding IO0 is not initialized, you can switch it by toggling the switch.
Thanks! That explains a lot. please tell me if it is possible to change the exposure time on this camera. Or, if this is done through an ISP, then through what function?
I tried to get the data through opencv, but the camera refuses to start via the v4l2 api.Eng33 wrote: ↑2025-06-03 9:00 1. If the image you get is green, it usually means you have to bring a RAW image. In one case, you obtained the wrong node, or in another case, your configuration is incorrect, causing the ISP to not work properly.
I tried to get the data through opencv, but the camera refuses to start via api v4l2.
Do you have a working code that can get a picture with the correct colors from the camera? A python script or cpp code is fine for me.
Generally speaking, exposure time and IOS are automatically adjusted by ISP.
For V4L2 issues, please refer to wikihttps://wiki.luckfox.com/luckfox-Omni35 ... SI-Camera/
There is TERRIBLY LITTLE written in this article. Now I've found out that maybe the camera is initializing incorrectly. How can I fix this?Eng33 wrote: ↑2025-06-04 4:04 Generally speaking, exposure time and IOS are automatically adjusted by ISP.
root@luckfox:/home/luckfox/Desktop# dmesg | grep imx
[ 3.034140] imx415 4-0037: driver version: 00.01.08
[ 3.034162] imx415 4-0037: Get hdr mode failed! no hdr default
[ 3.034178] imx415 4-0037: detect imx415 lane 4
[ 3.034225] imx415 4-0037: Failed to get power-gpios
[ 3.034233] imx415 4-0037: could not get default pinstate
[ 3.034239] imx415 4-0037: could not get sleep pinstate
[ 3.034270] imx415 4-0037: supply dvdd not found, using dummy regulator
[ 3.034395] imx415 4-0037: supply dovdd not found, using dummy regulator
[ 3.034423] imx415 4-0037: supply avdd not found, using dummy regulator
[ 3.102648] imx415 4-0037: Unexpected sensor id(000000), ret(-5)
[ 3.103655] imx415 5-0037: driver version: 00.01.08
[ 3.103685] imx415 5-0037: Get hdr mode failed! no hdr default
[ 3.103705] imx415 5-0037: detect imx415 lane 4
[ 3.103759] imx415 5-0037: Failed to get power-gpios
[ 3.103773] imx415 5-0037: could not get default pinstate
[ 3.103781] imx415 5-0037: could not get sleep pinstate
[ 3.103819] imx415 5-0037: supply dvdd not found, using dummy regulator
[ 3.103936] imx415 5-0037: supply dovdd not found, using dummy regulator
[ 3.103974] imx415 5-0037: supply avdd not found, using dummy regulator
[ 3.170636] imx415 5-0037: Unexpected sensor id(000000), ret(-5)
I also get these errors all the time.
just to remind you that I initially did everything as written in the wiki.
[ 406.323473] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.323505] stream_cif_mipi_id0: update sensor info failed -19
[ 406.323701] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.323713] stream_cif_mipi_id1: update sensor info failed -19
[ 406.323879] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.323890] rkcif_tools_id2: update sensor info failed -19
[ 406.324048] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.324057] stream_cif_mipi_id2: update sensor info failed -19
[ 406.324196] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.324204] stream_cif_mipi_id3: update sensor info failed -19
[ 406.324341] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.324350] rkcif_scale_ch0: update sensor info failed -19
[ 406.324492] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.324499] rkcif_scale_ch1: update sensor info failed -19
[ 406.324618] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.324625] rkcif_scale_ch2: update sensor info failed -19
[ 406.324740] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.324746] rkcif_scale_ch3: update sensor info failed -19
[ 406.324856] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.324865] rkcif_tools_id0: update sensor info failed -19
[ 406.324979] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.324985] rkcif_tools_id1: update sensor info failed -19
[ 406.325153] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.325161] stream_cif_mipi_id0: update sensor info failed -19
[ 406.325273] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.325280] stream_cif_mipi_id1: update sensor info failed -19
[ 406.325388] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.325394] stream_cif_mipi_id2: update sensor info failed -19
[ 406.325503] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.325510] stream_cif_mipi_id3: update sensor info failed -19
[ 406.325614] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.325621] rkcif_scale_ch0: update sensor info failed -19
[ 406.325730] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.325737] rkcif_scale_ch1: update sensor info failed -19
[ 406.325844] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.325850] rkcif_scale_ch2: update sensor info failed -19
[ 406.325955] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.325962] rkcif_scale_ch3: update sensor info failed -19
[ 406.326070] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.326076] rkcif_tools_id0: update sensor info failed -19
[ 406.326182] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.326189] rkcif_tools_id1: update sensor info failed -19
[ 406.326297] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.326304] rkcif_tools_id2: update sensor info failed -19
[ 406.414515] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.414542] stream_cif_mipi_id0: update sensor info failed -19
[ 406.414661] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.414669] stream_cif_mipi_id1: update sensor info failed -19
[ 406.414782] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.414788] rkcif_tools_id2: update sensor info failed -19
[ 406.414897] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.414904] stream_cif_mipi_id2: update sensor info failed -19
[ 406.415012] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.415018] stream_cif_mipi_id3: update sensor info failed -19
[ 406.415126] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.415132] rkcif_scale_ch0: update sensor info failed -19
[ 406.415239] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.415245] rkcif_scale_ch1: update sensor info failed -19
[ 406.415350] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.415357] rkcif_scale_ch2: update sensor info failed -19
[ 406.415464] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.415471] rkcif_scale_ch3: update sensor info failed -19
[ 406.415576] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.415584] rkcif_tools_id0: update sensor info failed -19
[ 406.415787] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.415796] rkcif_tools_id1: update sensor info failed -19
[ 406.416027] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.416039] stream_cif_mipi_id0: update sensor info failed -19
[ 406.416206] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.416214] stream_cif_mipi_id1: update sensor info failed -19
[ 406.416359] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.416366] stream_cif_mipi_id2: update sensor info failed -19
[ 406.416496] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.416504] stream_cif_mipi_id3: update sensor info failed -19
[ 406.416625] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.416632] rkcif_scale_ch0: update sensor info failed -19
[ 406.416769] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.416778] rkcif_scale_ch1: update sensor info failed -19
[ 406.416905] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.416912] rkcif_scale_ch2: update sensor info failed -19
[ 406.417031] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 406.417038] rkcif_scale_ch3: update sensor info failed -19
[ 406.417176] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 406.417185] rkcif_tools_id0: update sensor info failed -19
[ 406.417316] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 406.417323] rkcif_tools_id1: update sensor info failed -19
[ 406.417442] rkcif-mipi-lvds1: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 406.417448] rkcif_tools_id2: update sensor info failed -19
[ 406.465287] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
[ 406.465358] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
[ 406.465383] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
[ 406.465408] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
[ 406.465428] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
[ 406.465446] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
[ 406.465465] rkisp-vir0: rkisp_enum_frameintervals Not active sensor
Can I see your hardware connections?
There is no problem in our test. Please provide complete log information, including the instructions you used. We cannot judge the part you provided now.
I can't attach a photo of the physical connection to the board, but I can assure you that everything is in order and the cable is connected correctly.
- Attachments
dmesg_log.pdf (209.08 KiB)Downloaded 2202 times
This error message will only reappear when the camera is not connected. Please attach pictures of the hardware connection and information such as i2cdetect -y 4 or i2cdetect -y 5 to help us diagnose the issue. Thank you for your cooperation!
Method of uploading pictures on the forum: viewtopic.php?t=28
