适配了 ov5647,但是出图显示异常问题
  • 您好,一般信号问题导致的显示异常出现的是横条纹,竖条纹一般是电源问题或者颜色格式转换不对,建议参考sc3336把设备头图像过rkisp后输出,通过media-ctl -d /dev/media1 -p查询 rkisp_mainpath 的设备为 /dev/videoX 然后使用 v4l2-ctl --device=/dev/videoX --list-formats-ext 查看是否支持 NV12 这类已经将BayerRGB转换为YUV的格式,通过v4l2-ctl保存到本地用ffmpeg转换查看。
    如果只打算注册sensor不转换YUV可以调整一下ffmpeg 的输入格式,bayer_bggr16和BG10不匹配
  • 感谢指点,我试了一下用 rkisp 转成了 nv12,现在图片可以看了(虽然颜色和亮度不太对,这个我后面慢慢看吧)
    贴一下我的 ov5647.c 源码
    // SPDX-License-Identifier: GPL-2.0
     * A V4L2 driver for OmniVision OV5647 cameras.
     * Add support for rv1103 by <[email protected]> (2025.06)
     * Based on Samsung S5K6AAFX SXGA 1/6" 1.3M CMOS Image Sensor driver
     * Copyright (C) 2011 Sylwester Nawrocki <[email protected]>
     * Based on Omnivision OV7670 Camera Driver
     * Copyright (C) 2006-7 Jonathan Corbet <[email protected]>
     * Copyright (C) 2016, Synopsys, Inc.
    #define DEBUG
    #define VERBOSE_DEBUG
    #include <linux/clk.h>
    #include <linux/delay.h>
    #include <linux/gpio/consumer.h>
    #include <linux/i2c.h>
    #include <linux/init.h>
    #include <linux/io.h>
    #include <linux/module.h>
    #include <linux/of_graph.h>
    #include <linux/pm_runtime.h>
    #include <linux/slab.h>
    #include <linux/videodev2.h>
    #include <media/v4l2-ctrls.h>
    #include <media/v4l2-device.h>
    #include <media/v4l2-event.h>
    #include <media/v4l2-fwnode.h>
    #include <media/v4l2-image-sizes.h>
    #include <media/v4l2-mediabus.h>
    #include <linux/rk-camera-module.h>
     * From the datasheet, "20ms after PWDN goes low or 20ms after RESETB goes
     * high if reset is inserted after PWDN goes high, host can access sensor's
     * SCCB to initialize sensor."
    #define PWDN_ACTIVE_DELAY_MS	20
    #define MIPI_CTRL00_CLOCK_LANE_GATE		BIT(5)
    #define MIPI_CTRL00_LINE_SYNC_ENABLE		BIT(4)
    #define MIPI_CTRL00_BUS_IDLE			BIT(2)
    #define MIPI_CTRL00_CLOCK_LANE_DISABLE		BIT(0)
    #define OV5647_SW_STANDBY		0x0100
    #define OV5647_SW_RESET			0x0103
    #define OV5647_REG_CHIPID_H		0x300a
    #define OV5647_REG_CHIPID_L		0x300b
    #define OV5640_REG_PAD_OUT		0x300d
    #define OV5647_REG_EXP_HI		0x3500
    #define OV5647_REG_EXP_MID		0x3501
    #define OV5647_REG_EXP_LO		0x3502
    #define OV5647_REG_AEC_AGC		0x3503
    #define OV5647_REG_GAIN_HI		0x350a
    #define OV5647_REG_GAIN_LO		0x350b
    #define OV5647_REG_VTS_HI		0x380e
    #define OV5647_REG_VTS_LO		0x380f
    #define OV5647_REG_FRAME_OFF_NUMBER	0x4202
    #define OV5647_REG_MIPI_CTRL00		0x4800
    #define OV5647_REG_MIPI_CTRL14		0x4814
    #define OV5647_REG_AWB			0x5001
    #define REG_TERM 0xfffe
    #define VAL_TERM 0xfe
    #define REG_DLY  0xffff
    /* OV5647 native and active pixel array size */
    #define OV5647_NATIVE_WIDTH		2624U
    #define OV5647_NATIVE_HEIGHT		1956U
    #define OV5647_PIXEL_ARRAY_LEFT		16U
    #define OV5647_PIXEL_ARRAY_TOP		16U
    #define OV5647_PIXEL_ARRAY_WIDTH	2592U
    #define OV5647_PIXEL_ARRAY_HEIGHT	1944U
    #define OV5647_VBLANK_MIN		4
    #define OV5647_VTS_MAX			32767
    #define OV5647_EXPOSURE_MIN		4
    #define OV5647_EXPOSURE_STEP		1
    #define OV5647_EXPOSURE_DEFAULT		1000
    #define OV5647_EXPOSURE_MAX		65535
    #define OV5647_LANES			2
    #define OV5647_BITS_PER_SAMPLE		10
    struct regval_list {
    	u16 addr;
    	u8 data;
    struct ov5647_mode {
    	struct v4l2_mbus_framefmt	format;
    	struct v4l2_rect		crop;
    	u64				pixel_rate;
    	int				hts;
    	int				vts;
    	struct v4l2_fract		max_fps; // 帧率(FPS) = Pixel Rate / (HTS * VTS)
    	const struct regval_list	*reg_list;
    	unsigned int			num_regs;
    struct ov5647 {
    	struct v4l2_subdev		sd;
    	struct media_pad		pad;
    	struct mutex			lock;
    	struct clk			*xclk;
    	struct gpio_desc		*pwdn;
    	bool				clock_ncont;
    	struct v4l2_ctrl_handler	ctrls;
    	const struct ov5647_mode	*mode;
    	struct v4l2_ctrl		*pixel_rate;
    	struct v4l2_ctrl		*hblank;
    	struct v4l2_ctrl		*vblank;
    	struct v4l2_ctrl		*exposure;
    	struct v4l2_ctrl		*link_freq;
    	bool				streaming;
    static inline struct ov5647 *to_sensor(struct v4l2_subdev *sd)
    	return container_of(sd, struct ov5647, sd);
    /* pixel rate = link frequency * 2 * lanes / BITS_PER_SAMPLE
       link freq  = pixel rate * BITS_PER_SAMPLE / 4
    static const s64 link_freq_menu_items[] = {
    	220000000U, // @87500000
    	205000000U, // @81666700
    static const char * const test_pattern_menu[] = {
    	"Disabled",
    	"Color Bar"
    static const struct regval_list sensor_oe_disable_regs[] = {
    	{0x3000, 0x00},
    	{0x3001, 0x00},
    	{0x3002, 0x00},
    static const struct regval_list sensor_oe_enable_regs[] = {
    	{0x3000, 0x0f},
    	{0x3001, 0xff},
    	{0x3002, 0xe4},
    static struct regval_list ov5647_2592x1944_10bpp[] = {
    	{0x0100, 0x00},
    	{0x0103, 0x01},
    	{0x3034, 0x1a},
    	{0x3035, 0x21},
    	{0x3036, 0x69},
    	{0x303c, 0x11},
    	{0x3106, 0xf5},
    	{0x3821, 0x06},
    	{0x3820, 0x00},
    	{0x3827, 0xec},
    	{0x370c, 0x03},
    	{0x3612, 0x5b},
    	{0x3618, 0x04},
    	{0x5000, 0x06},
    	{0x5001, 0x01},
    	{0x5002, 0x41},
    	{0x5003, 0x08},
    	{0x5a00, 0x08},
    	{0x3000, 0x00},
    	{0x3001, 0x00},
    	{0x3002, 0x00},
    	{0x3016, 0x08},
    	{0x3017, 0xe0},
    	{0x3018, 0x44},
    	{0x301c, 0xf8},
    	{0x301d, 0xf0},
    	{0x3a18, 0x00},
    	{0x3a19, 0xf8},
    	{0x3c01, 0x80},
    	{0x3b07, 0x0c},
    	{0x3708, 0x64},
    	{0x3709, 0x12},
    	{0x3808, 0x0a}, // width   : 2592
    	{0x3809, 0x20},
    	{0x380a, 0x07}, // height  : 1944
    	{0x380b, 0x98},
    	{0x3800, 0x00}, // x-start : 0
    	{0x3801, 0x00},
    	{0x3802, 0x00}, // y-start : 0
    	{0x3803, 0x00},
    	{0x3804, 0x0a}, // x-end   : 2623
    	{0x3805, 0x3f},
    	{0x3806, 0x07}, // y-end   : 1955
    	{0x3807, 0xa3},
    	{0x380c, 0x0b}, // HTS: 2844
    	{0x380d, 0x1c},
    	{0x3811, 0x10}, // x-offset : 16
    	{0x3813, 0x06}, // y-offset : 6
    	{0x3814, 0x11},
    	{0x3815, 0x11},
    	{0x3630, 0x2e},
    	{0x3632, 0xe2},
    	{0x3633, 0x23},
    	{0x3634, 0x44},
    	{0x3636, 0x06},
    	{0x3620, 0x64},
    	{0x3621, 0xe0},
    	{0x3600, 0x37},
    	{0x3704, 0xa0},
    	{0x3703, 0x5a},
    	{0x3715, 0x78},
    	{0x3717, 0x01},
    	{0x3731, 0x02},
    	{0x370b, 0x60},
    	{0x3705, 0x1a},
    	{0x3f05, 0x02},
    	{0x3f06, 0x10},
    	{0x3f01, 0x0a},
    	{0x3a08, 0x01},
    	{0x3a09, 0x28},
    	{0x3a0a, 0x00},
    	{0x3a0b, 0xf6},
    	{0x3a0d, 0x08},
    	{0x3a0e, 0x06},
    	{0x3a0f, 0x58},
    	{0x3a10, 0x50},
    	{0x3a1b, 0x58},
    	{0x3a1e, 0x50},
    	{0x3a11, 0x60},
    	{0x3a1f, 0x28},
    	{0x4001, 0x02},
    	{0x4004, 0x04},
    	{0x4000, 0x09},
    	{0x4837, 0x19},
    	{0x4800, 0x24},
    	{0x3503, 0x03}, // AGC AEC Auto
    	{0x0100, 0x01},
    static struct regval_list ov5647_1080p30_10bpp[] = {
    	//{0x503d, 0x80}, // test pattern: 0x80(color bar)
    	{0x0100, 0x00},
    	{0x0103, 0x01},
    	{0x3034, 0x1a},
    	{0x3035, 0x21}, // sysclk_div[7:4] and scale_div[3:0]
    	{0x3036, 0x62}, // PLL multi. range: 4~252
    	{0x303c, 0x11},
    	{0x3106, 0xf5},
    	{0x3821, 0x00}, // mirror flip
    	{0x3820, 0x00},
    	{0x3827, 0xec},
    	{0x370c, 0x03},
    	{0x3612, 0x5b},
    	{0x3618, 0x04},
    	{0x5000, 0x06},
    	{0x5001, 0x01}, // AWB
    	{0x5002, 0x41},
    	{0x5003, 0x08},
    	{0x5a00, 0x08},
    	{0x3000, 0x00},
    	{0x3001, 0x00},
    	{0x3002, 0x00},
    	{0x3016, 0x08},
    	{0x3017, 0xe0},
    	{0x3018, 0x44},
    	{0x301c, 0xf8},
    	{0x301d, 0xf0},
    	{0x3a18, 0x00},
    	{0x3a19, 0xf8},
    	{0x3c01, 0x80},
    	{0x3b07, 0x0c},
    	{0x3814, 0x11},
    	{0x3815, 0x11},
    	{0x3708, 0x64},
    	{0x3709, 0x12},
    	// ----- image frame config -----
    	{0x3808, 0x07}, // width  : 1920
    	{0x3809, 0x80},
    	{0x380a, 0x04}, // height : 1080
    	{0x380b, 0x38},
    	{0x3800, 0x01}, // x-start	 : 352
    	{0x3801, 0x60},
    	{0x3802, 0x01}, // y-start	 : 438
    	{0x3803, 0xb6},
    	{0x3804, 0x08}, // x-end	 : 2272 - 1
    	{0x3805, 0xdf},
    	{0x3806, 0x05}, // y-end	 : 1518 - 1
    	{0x3807, 0xed},
    	{0x380c, 0x09}, // HTS: 2460
    	{0x380d, 0x9c},
    	{0x380e, 0x04}, // VTS: 1104 (= height + 24)
    	{0x380f, 0x50},
    	{0x3811, 0x00}, // x-offset : 0
    	{0x3813, 0x00}, // y-offset : 0
    	// ----- END -----
    	{0x3630, 0x2e},
    	{0x3632, 0xe2},
    	{0x3633, 0x23},
    	{0x3634, 0x44},
    	{0x3636, 0x06},
    	{0x3620, 0x64},
    	{0x3621, 0xe0},
    	{0x3600, 0x37},
    	{0x3704, 0xa0},
    	{0x3703, 0x5a},
    	{0x3715, 0x78},
    	{0x3717, 0x01},
    	{0x3731, 0x02},
    	{0x370b, 0x60},
    	{0x3705, 0x1a},
    	{0x3f05, 0x02},
    	{0x3f06, 0x10},
    	{0x3f01, 0x0a},
    	{0x3a08, 0x01},
    	{0x3a09, 0x4b},
    	{0x3a0a, 0x01},
    	{0x3a0b, 0x13},
    	{0x3a0d, 0x04},
    	{0x3a0e, 0x03},
    	{0x3a0f, 0x58},
    	{0x3a10, 0x50},
    	{0x3a1b, 0x58},
    	{0x3a1e, 0x50},
    	{0x3a11, 0x60},
    	{0x3a1f, 0x28},
    	{0x4001, 0x02},
    	{0x4004, 0x04},
    	{0x4000, 0x09},
    	{0x4837, 0x19},
    	{0x4800, 0x34}, // bit[4]: Line sync enable
    	{0x3503, 0x03}, // AGC/AEC Manual
    	{0x0100, 0x01},
    static struct regval_list ov5647_720p_10bpp[] = {
    	{0x0100, 0x00},
    	{0x0103, 0x01},
    	{0x3034, 0x1a},
    	{0x303c, 0x11},
    	{0x3106, 0xf5},
    	{0x3820, 0x00},
    	{0x3827, 0xec},
    	{0x370c, 0x03},
    	{0x3612, 0x5b},
    	{0x3618, 0x04},
    	{0x5000, 0x06},
    	{0x5002, 0x41},
    	{0x5003, 0x08},
    	{0x5a00, 0x08},
    	{0x3000, 0x00},
    	{0x3001, 0x00},
    	{0x3002, 0x00},
    	{0x3016, 0x08},
    	{0x3017, 0xe0},
    	{0x3018, 0x44},
    	{0x301c, 0xf8},
    	{0x301d, 0xf0},
    	{0x3a18, 0x00},
    	{0x3a19, 0xf8},
    	{0x3c01, 0x80},
    	{0x3b07, 0x0c},
    	{0x3814, 0x11},
    	{0x3815, 0x11},
    	{0x3708, 0x64},
    	{0x3709, 0x12},
    	{0x3808, 0x05}, // width  : 1280
    	{0x3809, 0x00},
    	{0x380a, 0x02}, // height : 720
    	{0x380b, 0xd0},
    	{0x3800, 0x02}, // x-start	 : 672
    	{0x3801, 0xa0},
    	{0x3802, 0x02}, // y-start	 : 618
    	{0x3803, 0x6a},
    	{0x3804, 0x07}, // x-end	 : 1952 - 1
    	{0x3805, 0x9f},
    	{0x3806, 0x05}, // y-end	 : 1338 - 1
    	{0x3807, 0x39},
    	{0x380c, 0x07}, // HTS: 1820
    	{0x380d, 0x1c},
    	{0x380e, 0x02}, // VTS: 744
    	{0x380f, 0xe8},
    	// ----- END -----
    	{0x3630, 0x2e},
    	{0x3632, 0xe2},
    	{0x3633, 0x23},
    	{0x3634, 0x44},
    	{0x3636, 0x06},
    	{0x3620, 0x64},
    	{0x3621, 0xe0},
    	{0x3600, 0x37},
    	{0x3704, 0xa0},
    	{0x3703, 0x5a},
    	{0x3715, 0x78},
    	{0x3717, 0x01},
    	{0x3731, 0x02},
    	{0x370b, 0x60},
    	{0x3705, 0x1a},
    	{0x3f05, 0x02},
    	{0x3f06, 0x10},
    	{0x3f01, 0x0a},
    	{0x3a08, 0x01},
    	{0x3a09, 0x4b},
    	{0x3a0a, 0x01},
    	{0x3a0b, 0x13},
    	{0x3a0d, 0x04},
    	{0x3a0e, 0x03},
    	{0x3a0f, 0x58},
    	{0x3a10, 0x50},
    	{0x3a1b, 0x58},
    	{0x3a1e, 0x50},
    	{0x3a11, 0x60},
    	{0x3a1f, 0x28},
    	{0x4001, 0x02},
    	{0x4004, 0x04},
    	{0x4000, 0x09},
    	{0x4837, 0x19},
    	{0x0100, 0x01},
    static const struct ov5647_mode ov5647_modes[] = {
    	/* mode 0 - 2592x1944 full resolution full FOV 10-bit mode. 15.6333fps */
    		.format = {
    			.code		= MEDIA_BUS_FMT_SBGGR10_1X10,
    			.colorspace	= V4L2_COLORSPACE_RAW,
    			.field		= V4L2_FIELD_NONE,
    			.width		= 2592,
    			.height		= 1944
    		.crop = {
    			.left		= 0,
    			.top		= 0,
    			.width		= 2592,
    			.height		= 1944
    		.max_fps = {
    			.numerator	= 10000,
    			.denominator	= 150000,
    		.pixel_rate	= 87500000,
    		.hts		= 2844,
    		.vts		= 0x7b0,
    		.reg_list	= ov5647_2592x1944_10bpp,
    		.num_regs	= ARRAY_SIZE(ov5647_2592x1944_10bpp)
    	/* mode 1 - 1080p30 10-bit mode. Full resolution centre-cropped down to 1080p. */
    		.format = {
    			.width		= 1920,
    			.height		= 1080
    		.crop = {
    			.left		= 0,
    			.top		= 0,
    			.width		= 1920,
    			.height		= 1080,
    		.max_fps = {
    			.numerator	= 10000,
    			.denominator	= 300000,
    		.pixel_rate	= 81666700,
    		.hts		= 2460,
    		.vts		= 1104,
    		.reg_list	= ov5647_1080p30_10bpp,
    		.num_regs	= ARRAY_SIZE(ov5647_1080p30_10bpp)
    	/* mode 2 - 720p 10-bit mode. 60fps */
    		.format = {
    			.width		= 1280,
    			.height		= 720
    		.crop = {
    			.left		= 0,
    			.top		= 0,
    			.width		= 1280,
    			.height		= 720,
    		.max_fps = {
    			.numerator	= 10000,
    			.denominator	= 600000,
    		.hts		= 1820,
    		.vts		= 744,
    		.reg_list	= ov5647_720p_10bpp,
    		.num_regs	= ARRAY_SIZE(ov5647_720p_10bpp)
    /* Default sensor mode is 2x2 binned 640x480 SBGGR10_1X10. */
    #define OV5647_DEFAULT_MODE_IDX 0
    #define OV5647_DEFAULT_MODE	(&ov5647_modes[OV5647_DEFAULT_MODE_IDX])
    #define OV5647_DEFAULT_FORMAT	(ov5647_modes[OV5647_DEFAULT_MODE_IDX].format)
    static int ov5647_write16(struct v4l2_subdev *sd, u16 reg, u16 val)
    	unsigned char data[4] = { reg >> 8, reg & 0xff, val >> 8, val & 0xff};
    	struct i2c_client *client = v4l2_get_subdevdata(sd);
    	int ret;
    	ret = i2c_master_send(client, data, 4);
    	if (ret < 0) {
    		dev_dbg(&client->dev, "%s: i2c write error, reg: %x\n",
    			__func__, reg);
    		return ret;
    static int ov5647_write(struct v4l2_subdev *sd, u16 reg, u8 val)
    	unsigned char data[3] = { reg >> 8, reg & 0xff, val};
    	int ret;
    	ret = i2c_master_send(client, data, 3);
    	if (ret < 0) {
    				__func__, reg);
    		return ret;
    static int ov5647_read(struct v4l2_subdev *sd, u16 reg, u8 *val)
    	unsigned char data_w[2] = { reg >> 8, reg & 0xff };
    	int ret;
    	ret = i2c_master_send(client, data_w, 2);
    	if (ret < 0) {
    			__func__, reg);
    		return ret;
    	ret = i2c_master_recv(client, val, 1);
    	if (ret < 0) {
    		dev_dbg(&client->dev, "%s: i2c read error, reg: %x\n",
    				__func__, reg);
    		return ret;
    static int ov5647_write_array(struct v4l2_subdev *sd,
    			      const struct regval_list *regs, int array_size)
    	int i, ret;
    	for (i = 0; i < array_size; i++) {
    		ret = ov5647_write(sd, regs[i].addr, regs[i].data);
    		if (ret < 0)
    			return ret;
    static int ov5647_set_virtual_channel(struct v4l2_subdev *sd, int channel)
    	u8 channel_id;
    	int ret;
    	ret = ov5647_read(sd, OV5647_REG_MIPI_CTRL14, &channel_id);
    	if (ret < 0)
    		return ret;
    	channel_id &= ~(3 << 6);
    	return ov5647_write(sd, OV5647_REG_MIPI_CTRL14,
    			    channel_id | (channel << 6));
    static int ov5647_set_mode(struct v4l2_subdev *sd)
    	struct ov5647 *sensor = to_sensor(sd);
    	u8 resetval, rdval;
    	int ret;
    	ret = ov5647_read(sd, OV5647_SW_STANDBY, &rdval);
    	if (ret < 0)
    		return ret;
    	ret = ov5647_write_array(sd, sensor->mode->reg_list,
    				 sensor->mode->num_regs);
    	if (ret < 0) {
    		dev_err(&client->dev, "write sensor default regs error\n");
    		return ret;
    	ret = ov5647_set_virtual_channel(sd, 0);
    	if (ret < 0)
    		return ret;
    	ret = ov5647_read(sd, OV5647_SW_STANDBY, &resetval);
    	if (ret < 0)
    		return ret;
    	if (!(resetval & 0x01)) {
    		dev_err(&client->dev, "Device was in SW standby");
    		ret = ov5647_write(sd, OV5647_SW_STANDBY, 0x01);
    		if (ret < 0)
    			return ret;
    static int ov5647_stream_on(struct v4l2_subdev *sd)
    	u8 val = MIPI_CTRL00_BUS_IDLE;
    	int ret;
    	ret = ov5647_set_mode(sd);
    	if (ret) {
    		dev_err(&client->dev, "Failed to program sensor mode: %d\n", ret);
    		return ret;
    	/* Apply customized values from user when stream starts. */
    	ret =  __v4l2_ctrl_handler_setup(sd->ctrl_handler);
    	if (ret)
    		return ret;
    	if (sensor->clock_ncont)
    		val |= MIPI_CTRL00_CLOCK_LANE_GATE |
    		       MIPI_CTRL00_LINE_SYNC_ENABLE;
    	ret = ov5647_write(sd, OV5647_REG_MIPI_CTRL00, val);
    	if (ret < 0)
    		return ret;
    	ret = ov5647_write(sd, OV5647_REG_FRAME_OFF_NUMBER, 0x00);
    	if (ret < 0)
    		return ret;
    	return ov5647_write(sd, OV5640_REG_PAD_OUT, 0x00);
    static int ov5647_stream_off(struct v4l2_subdev *sd)
    	int ret;
    			   MIPI_CTRL00_CLOCK_LANE_GATE | MIPI_CTRL00_BUS_IDLE |
    			   MIPI_CTRL00_CLOCK_LANE_DISABLE);
    	if (ret < 0)
    		return ret;
    	ret = ov5647_write(sd, OV5647_REG_FRAME_OFF_NUMBER, 0x0f);
    	if (ret < 0)
    		return ret;
    	return ov5647_write(sd, OV5640_REG_PAD_OUT, 0x01);
    static int ov5647_power_on(struct device *dev)
    	struct ov5647 *sensor = dev_get_drvdata(dev);
    	int ret;
    	dev_dbg(dev, "OV5647 power on\n");
    	if (sensor->pwdn) {
    		gpiod_set_value_cansleep(sensor->pwdn, 0);
    		msleep(PWDN_ACTIVE_DELAY_MS);
    	ret = clk_prepare_enable(sensor->xclk);
    	if (ret < 0) {
    		dev_err(dev, "clk prepare enable failed\n");
    		goto error_pwdn;
    	ret = ov5647_write_array(&sensor->sd, sensor_oe_enable_regs,
    				 ARRAY_SIZE(sensor_oe_enable_regs));
    	if (ret < 0) {
    		dev_err(dev, "write sensor_oe_enable_regs error\n");
    		goto error_clk_disable;
    	/* Stream off to coax lanes into LP-11 state. */
    	ret = ov5647_stream_off(&sensor->sd);
    	if (ret < 0) {
    		dev_err(dev, "camera not available, check power\n");
    error_clk_disable:
    	clk_disable_unprepare(sensor->xclk);
    error_pwdn:
    	if (sensor->pwdn)
    		gpiod_set_value_cansleep(sensor->pwdn, 1);
    	return ret;
    static int ov5647_power_off(struct device *dev)
    	u8 rdval;
    	int ret;
    	dev_dbg(dev, "OV5647 power off\n");
    	ret = ov5647_write_array(&sensor->sd, sensor_oe_disable_regs,
    				 ARRAY_SIZE(sensor_oe_disable_regs));
    	if (ret < 0)
    		dev_dbg(dev, "disable oe failed\n");
    	/* Enter software standby */
    	ret = ov5647_read(&sensor->sd, OV5647_SW_STANDBY, &rdval);
    	if (ret < 0)
    		dev_dbg(dev, "software standby failed\n");
    	rdval &= ~0x01;
    	ret = ov5647_write(&sensor->sd, OV5647_SW_STANDBY, rdval);
    	if (ret < 0)
    	if (sensor->pwdn)
    #ifdef CONFIG_VIDEO_ADV_DEBUG
    static int ov5647_sensor_get_register(struct v4l2_subdev *sd,
    				      struct v4l2_dbg_register *reg)
    	int ret;
    	u8 val;
    	ret = ov5647_read(sd, reg->reg & 0xff, &val);
    	if (ret < 0)
    		return ret;
    	reg->val = val;
    	reg->size = 1;
    static int ov5647_sensor_set_register(struct v4l2_subdev *sd,
    				      const struct v4l2_dbg_register *reg)
    	return ov5647_write(sd, reg->reg & 0xff, reg->val & 0xff);
    #endif
    static long ov5647_ioctl(struct v4l2_subdev *sd, unsigned int cmd, void *arg)
    	long ret = 0;
    	switch (cmd) {
    	case RKMODULE_GET_CSI_DSI_INFO:
    		*(int *)arg = RKMODULE_CSI_INPUT;
    		break;
    	case RKMODULE_GET_MODULE_INFO:
    	case RKMODULE_SET_QUICK_STREAM:
    	case RKMODULE_GET_VICAP_RST_INFO:
    	case RKMODULE_SET_VICAP_RST_INFO:
    	default:
    		ret = -ENOIOCTLCMD;
    		break;
    	return ret;
    /* Subdev core operations registration */
    static const struct v4l2_subdev_core_ops ov5647_subdev_core_ops = {
    	.subscribe_event	= v4l2_ctrl_subdev_subscribe_event,
    	.unsubscribe_event	= v4l2_event_subdev_unsubscribe,
    	.ioctl			= ov5647_ioctl,
    	.g_register		= ov5647_sensor_get_register,
    	.s_register		= ov5647_sensor_set_register,
    #endif
    static const struct v4l2_rect *
    __ov5647_get_pad_crop(struct ov5647 *ov5647,
    		      struct v4l2_subdev_pad_config *cfg,
    		      unsigned int pad, enum v4l2_subdev_format_whence which)
    	switch (which) {
    	case V4L2_SUBDEV_FORMAT_TRY:
    		return v4l2_subdev_get_try_crop(&ov5647->sd, cfg, pad);
    	case V4L2_SUBDEV_FORMAT_ACTIVE:
    		return &ov5647->mode->crop;
    	return NULL;
    static int ov5647_s_stream(struct v4l2_subdev *sd, int enable)
    	int ret;
    	mutex_lock(&sensor->lock);
    	if (sensor->streaming == enable) {
    		mutex_unlock(&sensor->lock);
    	if (enable) {
    		ret = pm_runtime_resume_and_get(&client->dev);
    		if (ret < 0) {
    			dev_err(&client->dev, "pm runtime resume failed: %d\n", ret);
    			goto error_unlock;
    		ret = ov5647_stream_on(sd);
    		if (ret < 0) {
    			dev_err(&client->dev, "stream start failed: %d\n", ret);
    			goto error_pm;
    	} else {
    		ret = ov5647_stream_off(sd);
    		if (ret < 0) {
    			dev_err(&client->dev, "stream stop failed: %d\n", ret);
    			goto error_pm;
    		pm_runtime_put(&client->dev);
    	sensor->streaming = enable;
    error_pm:
    error_unlock:
    	return ret;
    static int ov5647_g_frame_interval(struct v4l2_subdev *sd,
    				   struct v4l2_subdev_frame_interval *fi)
    	fi->interval = sensor->mode->max_fps;
    static const struct v4l2_subdev_video_ops ov5647_subdev_video_ops = {
    	.s_stream		= ov5647_s_stream,
    	.g_frame_interval	= ov5647_g_frame_interval
    static int ov5647_enum_mbus_code(struct v4l2_subdev *sd,
    				 struct v4l2_subdev_mbus_code_enum *code)
    	if (code->index > 0)
    		return -EINVAL;
    	code->code = MEDIA_BUS_FMT_SBGGR10_1X10;
    static int ov5647_enum_frame_size(struct v4l2_subdev *sd,
    				  struct v4l2_subdev_frame_size_enum *fse)
    	const struct v4l2_mbus_framefmt *fmt;
    	if (fse->code != MEDIA_BUS_FMT_SBGGR10_1X10 ||
    	    fse->index >= ARRAY_SIZE(ov5647_modes))
    		return -EINVAL;
    	fmt = &ov5647_modes[fse->index].format;
    	fse->min_width = fmt->width;
    	fse->max_width = fmt->width;
    	fse->min_height = fmt->height;
    	fse->max_height = fmt->height;
    static int ov5647_get_pad_fmt(struct v4l2_subdev *sd,
    			      struct v4l2_subdev_pad_config *pad_cfg,
    			      struct v4l2_subdev_format *format)
    	struct v4l2_mbus_framefmt *fmt = &format->format;
    	const struct v4l2_mbus_framefmt *sensor_format;
    	switch (format->which) {
    		sensor_format = v4l2_subdev_get_try_format(sd, pad_cfg,
    							   format->pad);
    		break;
    	default:
    		sensor_format = &sensor->mode->format;
    		break;
    	*fmt = *sensor_format;
    static int ov5647_set_pad_fmt(struct v4l2_subdev *sd,
    	mode = v4l2_find_nearest_size(ov5647_modes, ARRAY_SIZE(ov5647_modes),
    				      format.width, format.height,
    				      fmt->width, fmt->height);
    	/* Update the sensor mode and apply at it at streamon time. */
    	if (format->which == V4L2_SUBDEV_FORMAT_TRY) {
    		*v4l2_subdev_get_try_format(sd, pad_cfg, format->pad) = mode->format;
    	} else {
    		int exposure_max, exposure_def;
    		int hblank, vblank;
    		sensor->mode = mode;
    		__v4l2_ctrl_modify_range(sensor->pixel_rate, mode->pixel_rate,
    					 mode->pixel_rate, 1, mode->pixel_rate);
    		hblank = mode->hts - mode->format.width;
    		__v4l2_ctrl_modify_range(sensor->hblank, hblank, hblank, 1,
    					 hblank);
    		vblank = mode->vts - mode->format.height;
    		__v4l2_ctrl_modify_range(sensor->vblank, OV5647_VBLANK_MIN,
    					 OV5647_VTS_MAX - mode->format.height,
    					 1, vblank);
    		__v4l2_ctrl_s_ctrl(sensor->vblank, vblank);
    		exposure_max = mode->vts - 4;
    		exposure_def = min(exposure_max, OV5647_EXPOSURE_DEFAULT);
    		__v4l2_ctrl_modify_range(sensor->exposure,
    					 sensor->exposure->minimum,
    					 exposure_max, sensor->exposure->step,
    					 exposure_def);
    		__v4l2_ctrl_s_ctrl(sensor->link_freq, 0);
    	*fmt = mode->format;
    static int ov5647_get_selection(struct v4l2_subdev *sd,
    				struct v4l2_subdev_selection *sel)
    	switch (sel->target) {
    	case V4L2_SEL_TGT_CROP:
    		sel->r = *__ov5647_get_pad_crop(sensor, pad_cfg, sel->pad,
    						sel->which);
    		dev_info(sd->dev, "%s: V4L2_SEL_TGT_CROP => (%d,%d)%dx%d",
    			__func__, sel->r.left, sel->r.top,
    			sel->r.width, sel->r.height);
    	case V4L2_SEL_TGT_NATIVE_SIZE:
    		sel->r.top 	= 0;
    		sel->r.left 	= 0;
    		sel->r.width 	= OV5647_NATIVE_WIDTH;
    		sel->r.height 	= OV5647_NATIVE_HEIGHT;
    	//case V4L2_SEL_TGT_CROP_DEFAULT:
    	case V4L2_SEL_TGT_CROP_BOUNDS:
    		sel->r.top	= 0;
    		sel->r.left	= 0;
    		sel->r.width	= sensor->mode->crop.width;
    		sel->r.height	= sensor->mode->crop.height;
    		dev_info(sd->dev, "%s: V4L2_SEL_TGT_CROP_BOUNDS => (%d,%d)%dx%d",
    	return -EINVAL;
    static int ov5647_g_mbus_config(struct v4l2_subdev *sd,
    				unsigned int pad_id,
    				struct v4l2_mbus_config *config)
    	u32 val = 0;
    	val = 1 << (OV5647_LANES - 1) |
    	      V4L2_MBUS_CSI2_CHANNEL_0 |
    	      V4L2_MBUS_CSI2_CONTINUOUS_CLOCK;
    	config->type = V4L2_MBUS_CSI2_DPHY;
    	config->flags = val;
    static const struct v4l2_subdev_pad_ops ov5647_subdev_pad_ops = {
    	.enum_mbus_code		= ov5647_enum_mbus_code,
    	.enum_frame_size	= ov5647_enum_frame_size,
    	.set_fmt		= ov5647_set_pad_fmt,
    	.get_fmt		= ov5647_get_pad_fmt,
    	.get_selection		= ov5647_get_selection,
    	.get_mbus_config	= ov5647_g_mbus_config
    static const struct v4l2_subdev_ops ov5647_subdev_ops = {
    	.core		= &ov5647_subdev_core_ops,
    	.video		= &ov5647_subdev_video_ops,
    	.pad		= &ov5647_subdev_pad_ops,
    static int ov5647_detect(struct v4l2_subdev *sd)
    	u8 read;
    	int ret;
    	ret = ov5647_write(sd, OV5647_SW_RESET, 0x01);
    	if (ret < 0)
    		return ret;
    	ret = ov5647_read(sd, OV5647_REG_CHIPID_H, &read);
    	if (ret < 0)
    		return ret;
    	if (read != 0x56) {
    		dev_err(&client->dev, "ID High expected 0x56 got %x", read);
    		return -ENODEV;
    	ret = ov5647_read(sd, OV5647_REG_CHIPID_L, &read);
    	if (ret < 0)
    		return ret;
    	if (read != 0x47) {
    		dev_err(&client->dev, "ID Low expected 0x47 got %x", read);
    		return -ENODEV;
    	return ov5647_write(sd, OV5647_SW_RESET, 0x00);
    static int ov5647_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
    	struct v4l2_mbus_framefmt *format =
    				v4l2_subdev_get_try_format(sd, fh->pad, 0);
    	struct v4l2_rect *crop = v4l2_subdev_get_try_crop(sd, fh->pad, 0);
    	crop->left	= OV5647_DEFAULT_MODE->crop.left;
    	crop->top	= OV5647_DEFAULT_MODE->crop.top;
    	crop->width	= OV5647_DEFAULT_MODE->crop.width;
    	crop->height	= OV5647_DEFAULT_MODE->crop.height;
    	*format		= OV5647_DEFAULT_FORMAT;
    static const struct v4l2_subdev_internal_ops ov5647_subdev_internal_ops = {
    	.open = ov5647_open,
    static int ov5647_s_auto_white_balance(struct v4l2_subdev *sd, u32 val)
    	return ov5647_write(sd, OV5647_REG_AWB, val ? 1 : 0);
    static int ov5647_s_autogain(struct v4l2_subdev *sd, u32 val)
    	int ret;
    	u8 reg;
    	/* Non-zero turns on AGC by clearing bit 1.*/
    	ret = ov5647_read(sd, OV5647_REG_AEC_AGC, &reg);
    	if (ret)
    		return ret;
    	return ov5647_write(sd, OV5647_REG_AEC_AGC, val ? reg & ~BIT(1)
    							: reg | BIT(1));
    static int ov5647_s_exposure_auto(struct v4l2_subdev *sd, u32 val)
    	int ret;
    	u8 reg;
    	 * Everything except V4L2_EXPOSURE_MANUAL turns on AEC by
    	 * clearing bit 0.
    	if (ret)
    		return ret;
    			    val == V4L2_EXPOSURE_MANUAL ? reg | BIT(0)
    							: reg & ~BIT(0));
    static int ov5647_s_analogue_gain(struct v4l2_subdev *sd, u32 val)
    	int ret;
    	/* 10 bits of gain, 2 in the high register. */
    	ret = ov5647_write(sd, OV5647_REG_GAIN_HI, (val >> 8) & 3);
    	if (ret)
    		return ret;
    	return ov5647_write(sd, OV5647_REG_GAIN_LO, val & 0xff);
    static int ov5647_s_exposure(struct v4l2_subdev *sd, u32 val)
    	int ret;
    	 * Sensor has 20 bits, but the bottom 4 bits are fractions of a line
    	 * which we leave as zero (and don't receive in "val").
    	ret = ov5647_write(sd, OV5647_REG_EXP_HI, (val >> 12) & 0xf);
    	if (ret)
    		return ret;
    	ret = ov5647_write(sd, OV5647_REG_EXP_MID, (val >> 4) & 0xff);
    	if (ret)
    		return ret;
    	return ov5647_write(sd, OV5647_REG_EXP_LO, (val & 0xf) << 4);
    static int ov5647_s_ctrl(struct v4l2_ctrl *ctrl)
    	struct ov5647 *sensor = container_of(ctrl->handler,
    					    struct ov5647, ctrls);
    	struct v4l2_subdev *sd = &sensor->sd;
    	int ret = 0;
    	/* v4l2_ctrl_lock() locks our own mutex */
    	if (ctrl->id == V4L2_CID_VBLANK) {
    		/* Update max exposure while meeting expected vblanking */
    		exposure_max = sensor->mode->format.height + ctrl->val - 4;
    					 exposure_def);
    	 * If the device is not powered up do not apply any controls
    	 * to H/W at this time. Instead the controls will be restored
    	 * at s_stream(1) time.
    	if (pm_runtime_get_if_in_use(&client->dev) == 0)
    	switch (ctrl->id) {
    	case V4L2_CID_AUTO_WHITE_BALANCE:
    		ret = ov5647_s_auto_white_balance(sd, ctrl->val);
    		break;
    	case V4L2_CID_AUTOGAIN:
    		ret = ov5647_s_autogain(sd, ctrl->val);
    		break;
    	case V4L2_CID_EXPOSURE_AUTO:
    		ret = ov5647_s_exposure_auto(sd, ctrl->val);
    		break;
    	case V4L2_CID_ANALOGUE_GAIN:
    		ret =  ov5647_s_analogue_gain(sd, ctrl->val);
    		break;
    	case V4L2_CID_EXPOSURE:
    		ret = ov5647_s_exposure(sd, ctrl->val);
    		break;
    	case V4L2_CID_VBLANK:
    		ret = ov5647_write16(sd, OV5647_REG_VTS_HI,
    				     sensor->mode->format.height + ctrl->val);
    		break;
    	/* Read-only, but we adjust it based on mode. */
    	case V4L2_CID_PIXEL_RATE:
    	case V4L2_CID_HBLANK:
    		break;
    	case V4L2_CID_TEST_PATTERN:
    		ret = ov5647_write(sd, 0x503d, ctrl->val ? 0x80 : 0x00);
    		break;
    	default:
    		dev_info(&client->dev,
    			 "Control (id:0x%x, val:0x%x) not supported\n",
    			 ctrl->id, ctrl->val);
    		return -EINVAL;
    	return ret;
    static const struct v4l2_ctrl_ops ov5647_ctrl_ops = {
    	.s_ctrl = ov5647_s_ctrl,
    static int ov5647_init_controls(struct ov5647 *sensor)
    	struct i2c_client *client = v4l2_get_subdevdata(&sensor->sd);
    	int hblank, exposure_max, exposure_def, ret;
    	ret = v4l2_ctrl_handler_init(&sensor->ctrls, 12);
    	if (ret) {
    		dev_err(&client->dev, "v4l2_ctrl_handler_init failed. ret=%d\n", ret);
    		return ret;
    	v4l2_ctrl_new_std(&sensor->ctrls, &ov5647_ctrl_ops,
    			  V4L2_CID_AUTOGAIN, 0, 1, 1, 0);
    			  V4L2_CID_AUTO_WHITE_BALANCE, 0, 1, 1, 1);
    	v4l2_ctrl_new_std_menu(&sensor->ctrls, &ov5647_ctrl_ops,
    			       V4L2_CID_EXPOSURE_AUTO, V4L2_EXPOSURE_MANUAL,
    			       0, V4L2_EXPOSURE_MANUAL);
    	exposure_max = sensor->mode->vts - 4;
    	sensor->exposure = v4l2_ctrl_new_std(&sensor->ctrls, &ov5647_ctrl_ops,
    					     V4L2_CID_EXPOSURE,
    					     OV5647_EXPOSURE_MIN,
    					     exposure_max, OV5647_EXPOSURE_STEP,
    					     exposure_def);
    	/* min: 16 = 1.0x; max (10 bits); default: 32 = 2.0x. */
    			  V4L2_CID_ANALOGUE_GAIN, 16, 1023, 1, 32);
    	/* By default, PIXEL_RATE is read only, but it does change per mode */
    	sensor->pixel_rate = v4l2_ctrl_new_std(&sensor->ctrls, &ov5647_ctrl_ops,
    					       V4L2_CID_PIXEL_RATE,
    					       sensor->mode->pixel_rate,
    					       sensor->mode->pixel_rate, 1,
    					       sensor->mode->pixel_rate);
    	/* By default, HBLANK is read only, but it does change per mode. */
    	hblank = sensor->mode->hts - sensor->mode->format.width;
    	sensor->hblank = v4l2_ctrl_new_std(&sensor->ctrls, &ov5647_ctrl_ops,
    					   V4L2_CID_HBLANK, hblank, hblank, 1,
    					   hblank);
    	sensor->vblank = v4l2_ctrl_new_std(&sensor->ctrls, &ov5647_ctrl_ops,
    					   V4L2_CID_VBLANK, OV5647_VBLANK_MIN,
    					   OV5647_VTS_MAX -
    					   sensor->mode->format.height, 1,
    					   sensor->mode->vts -
    					   sensor->mode->format.height);
    	sensor->link_freq = v4l2_ctrl_new_int_menu(&sensor->ctrls, &ov5647_ctrl_ops,
    		V4L2_CID_LINK_FREQ, ARRAY_SIZE(link_freq_menu_items) - 1,
    		OV5647_DEFAULT_MODE_IDX, link_freq_menu_items);
    	v4l2_ctrl_new_std_menu_items(&sensor->ctrls, &ov5647_ctrl_ops,
    				     V4L2_CID_TEST_PATTERN,
    				     ARRAY_SIZE(test_pattern_menu) - 1,
    				     0, 0, test_pattern_menu);
    	if (sensor->ctrls.error)
    		goto handler_free;
    	sensor->pixel_rate->flags |= V4L2_CTRL_FLAG_READ_ONLY;
    	sensor->hblank->flags |= V4L2_CTRL_FLAG_READ_ONLY;
    	sensor->link_freq->flags |= V4L2_CTRL_FLAG_READ_ONLY;
    	sensor->sd.ctrl_handler = &sensor->ctrls;
    handler_free:
    	dev_err(&client->dev, "%s Controls initialization failed (%d)\n",
    		__func__, sensor->ctrls.error);
    	v4l2_ctrl_handler_free(&sensor->ctrls);
    	return sensor->ctrls.error;
    static int ov5647_parse_dt(struct ov5647 *sensor, struct device_node *np)
    	struct v4l2_fwnode_endpoint bus_cfg = {
    		.bus_type = V4L2_MBUS_CSI2_DPHY,
    	struct device_node *ep;
    	int ret;
    	ep = of_graph_get_next_endpoint(np, NULL);
    	if (!ep)
    		return -EINVAL;
    	ret = v4l2_fwnode_endpoint_parse(of_fwnode_handle(ep), &bus_cfg);
    	if (ret)
    		goto out;
    	sensor->clock_ncont = bus_cfg.bus.mipi_csi2.flags &
    			      V4L2_MBUS_CSI2_NONCONTINUOUS_CLOCK;
    out:
    	of_node_put(ep);
    	return ret;
    static int ov5647_probe(struct i2c_client *client)
    	struct device_node *np = client->dev.of_node;
    	struct device *dev = &client->dev;
    	struct ov5647 *sensor;
    	struct v4l2_subdev *sd;
    	u32 xclk_freq;
    	int ret;
    	sensor = devm_kzalloc(dev, sizeof(*sensor), GFP_KERNEL);
    	if (!sensor)
    		return -ENOMEM;
    	if (IS_ENABLED(CONFIG_OF) && np) {
    		ret = ov5647_parse_dt(sensor, np);
    		if (ret) {
    			dev_err(dev, "DT parsing error: %d\n", ret);
    			return ret;
    	/* get system clock (xclk) */
    	sensor->xclk = devm_clk_get(dev, NULL);
    	if (IS_ERR(sensor->xclk)) {
    		dev_err(dev, "could not get xclk");
    		return PTR_ERR(sensor->xclk);
    	xclk_freq = clk_get_rate(sensor->xclk);
    	if (xclk_freq != 25000000) {
    		ret = clk_set_rate(sensor->xclk, 25000000);
    		if (ret) {
    			dev_err(dev, "failed to set clk rate\n");
    			return -EINVAL;
    	/* Request the power down GPIO asserted. */
    	sensor->pwdn = devm_gpiod_get_optional(dev, "pwdn", GPIOD_OUT_HIGH);
    	if (sensor->pwdn == NULL)
    		dev_warn(dev, "not found 'pwdn' gpio\n");
    	mutex_init(&sensor->lock);
    	sensor->mode = OV5647_DEFAULT_MODE;
    	sd = &sensor->sd;
    	v4l2_i2c_subdev_init(sd, client, &ov5647_subdev_ops);
    	ret = ov5647_init_controls(sensor);
    	if (ret)
    		goto mutex_destroy;
    #ifdef CONFIG_VIDEO_V4L2_SUBDEV_API
    	sd->internal_ops = &ov5647_subdev_internal_ops;
    	sd->flags |= V4L2_SUBDEV_FL_HAS_DEVNODE | V4L2_SUBDEV_FL_HAS_EVENTS;
    #endif
    #ifdef CONFIG_MEDIA_CONTROLLER
    	sensor->pad.flags = MEDIA_PAD_FL_SOURCE;
    	sd->entity.function = MEDIA_ENT_F_CAM_SENSOR;
    	ret = media_entity_pads_init(&sd->entity, 1, &sensor->pad);
    	if (ret < 0)
    		goto ctrl_handler_free;
    #endif
    	ret = ov5647_power_on(dev);
    	if (ret) {
    		dev_err(dev, "failed to power on sensor %d\n", ret);
    		goto entity_cleanup;
    	ret = ov5647_detect(sd);
    	if (ret < 0) {
    		dev_err(dev, "failed to detect sensor %d\n", ret);
    		goto power_off;
    	strncpy(sd->name, dev_name(dev), sizeof(sd->name));
    	ret = v4l2_async_register_subdev(sd);
    	if (ret < 0)
    		goto power_off;
    	/* Enable runtime PM and turn off the device */
    	pm_runtime_set_active(dev);
    	pm_runtime_enable(dev);
    	pm_runtime_idle(dev);
    	dev_dbg(dev, "OmniVision OV5647 camera driver probed\n");
    power_off:
    	ov5647_power_off(dev);
    entity_cleanup:
    	media_entity_cleanup(&sd->entity);
    ctrl_handler_free:
    mutex_destroy:
    	mutex_destroy(&sensor->lock);
    	return ret;
    static int ov5647_remove(struct i2c_client *client)
    	struct v4l2_subdev *sd = i2c_get_clientdata(client);
    	v4l2_async_unregister_subdev(&sensor->sd);
    	media_entity_cleanup(&sensor->sd.entity);
    	v4l2_device_unregister_subdev(sd);
    	pm_runtime_disable(&client->dev);
    static const struct dev_pm_ops ov5647_pm_ops = {
    	SET_RUNTIME_PM_OPS(ov5647_power_off, ov5647_power_on, NULL)
    static const struct i2c_device_id ov5647_id[] = {
    	{ "ov5647", 0 },
    	{ /* sentinel */ }
    MODULE_DEVICE_TABLE(i2c, ov5647_id);
    #if IS_ENABLED(CONFIG_OF)
    static const struct of_device_id ov5647_of_match[] = {
    	{ .compatible = "ovti,ov5647" },
    	{ /* sentinel */ },
    MODULE_DEVICE_TABLE(of, ov5647_of_match);
    #endif
    static struct i2c_driver ov5647_driver = {
    	.driver = {
    		.of_match_table = of_match_ptr(ov5647_of_match),
    		.name	= "ov5647",
    		.pm	= &ov5647_pm_ops,
    	.probe_new	= ov5647_probe,
    	.remove		= ov5647_remove,
    	.id_table	= ov5647_id,
    module_i2c_driver(ov5647_driver);
    MODULE_AUTHOR("Ramiro Oliveira <[email protected]>");
    MODULE_DESCRIPTION("A low-level driver for OmniVision ov5647 sensors");
    MODULE_LICENSE("GPL v2");
