I am looking for a simple example that allows me to capture a still image with the camera on my Luckfox Pico Ultra either using opencv or some other alternative.
I am familiar with the examples at https://github.com/LuckfoxTECH/luckfox_ ... l-5.10.160
But I am looking for a more basic example that does not require RTSP.
Can someone point me in the right direction?
Regards
Simple OpenCV example
Hello, the example routines we provide use opencv-mobile instead of opencv. For a simple example of capturing images, you can refer to https://wiki.luckfox.com/zh/Luckfox-Pic ... ncv-mobile
Thank you for the reply.
I tried that example and it does not work on the Pico Ultra.
Looking at the code, I am unsure how this could work. OpenCV assumes camera output is BGR (or RGB) by default, but the Luckfox MIPI CSI camera outputs raw YUV formats (e.g. UYVY, NV12, NV21, etc.), which OpenCV does not automatically convert.
I slight modified the code in the sample for debugging:
Any help would be appreciated.
./opencv-mobile-test
opencv-mobile MIPI CSI camera with v4l2 rkaiq
opencv-mobile HW JPG encoder with rk mpp
Still Image Capture Example..
devpath = /dev/video11
driver = rkisp_v7
card = rkisp_mainpath
version = 20500
capabilities = 84201000
device_caps = 4201000
fmt = UYVY 4:2:2 59565955
fmt = Y/CbCr 4:2:2 3631564e
fmt = Y/CrCb 4:2:2 3136564e
fmt = Y/CrCb 4:2:0 3132564e
size = 32 x 32 ~ 2304 x 1296 (+8 +8)
fmt = Y/CbCr 4:2:0 3231564e
rkaiq log level ff1
XCORE:K:rk_aiq_init_lib, ISP HW ver: 32
XCORE:K:
************************** VERSION INFOS **************************
version release date: 2024-2-18
AIQ: AIQ v5.0x5.0
git logs:
25bd14e RV1106: smart_door: release rga/isp/mpp for V1.3.0
99d080a RV1106/RV1103: Battery/Doorbell: release kmpp/rockit-ko for V1.3.2
6458e2a RV1106/RV1103: Battery/Doorbell: release kmpp/rockit-ko for V1.3.1
e8dab39 RV1106: CVR: release rga/isp/mpp for V1.1.0
a021b32 RV1106/RV1103: Battery/Doorbell: release kmpp/rockit-ko for V1.3.0
************************ VERSION INFOS END ************************
XCORE:K:rk_aiq_uapi_sysctl_preInit_scene: main_scene: normal, sub_scene: day
XCORE:E:invalid main scene len!
# v4l2-ctl -d /dev/video11 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
[0]: 'UYVY' (UYVY 4:2:2)
Size: Stepwise 32x32 - 2304x1296 with step 8/8
[1]: 'NV16' (Y/CbCr 4:2:2)
[2]: 'NV61' (Y/CrCb 4:2:2)
[3]: 'NV21' (Y/CrCb 4:2:0)
[4]: 'NV12' (Y/CbCr 4:2:0)
[5]: 'NM21' (Y/CrCb 4:2:0 (N-C))
[6]: 'NM12' (Y/CbCr 4:2:0 (N-C))
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <unistd.h> // sleep()
int main()
fprintf(stderr, "Still Image Capture Example..\n");
cv::VideoCapture cap;
cap.set(cv::CAP_PROP_FRAME_WIDTH, 320);
cap.set(cv::CAP_PROP_FRAME_HEIGHT, 240);
cap.open(0);
if (!cap.isOpened())
fprintf(stderr, "ERROR: Cannot open camera.\n");
return -1;
else
fprintf(stderr, "Opened camera..\n");
const int w = cap.get(cv::CAP_PROP_FRAME_WIDTH);
const int h = cap.get(cv::CAP_PROP_FRAME_HEIGHT);
fprintf(stderr, "Image Dimensions: %d x %d\n", w, h);
cv::Mat bgr[9];
for (int i = 0; i < 9; i++)
cap >> bgr[i];
if (bgr[i].empty())
fprintf(stderr, "ERROR: Frame %d is empty\n", i);
return -1;
fprintf(stderr, "Captured frame %d: type = %d, channels = %d\n",
i, bgr[i].type(), bgr[i].channels());
// Save intermediate frames for debugging
std::string filename = "frame_" + std::to_string(i) + ".jpg";
cv::imwrite(filename, bgr[i]);
sleep(1);
cap.release();
// combine into big image
cv::Mat out(h * 3, w * 3, CV_8UC3);
bgr[0].copyTo(out(cv::Rect(0, 0, w, h)));
bgr[1].copyTo(out(cv::Rect(w, 0, w, h)));
bgr[2].copyTo(out(cv::Rect(w * 2, 0, w, h)));
bgr[3].copyTo(out(cv::Rect(0, h, w, h)));
bgr[4].copyTo(out(cv::Rect(w, h, w, h)));
bgr[5].copyTo(out(cv::Rect(w * 2, h, w, h)));
bgr[6].copyTo(out(cv::Rect(0, h * 2, w, h)));
bgr[7].copyTo(out(cv::Rect(w, h * 2, w, h)));
bgr[8].copyTo(out(cv::Rect(w * 2, h * 2, w, h)));
if (!cv::imwrite("out.jpg", out))
fprintf(stderr, "ERROR: Failed to write out.jpg\n");
return -1;
Please check if the rkipc program is closed. If it is using the camera device, the routine will not be able to run.
I ran RKlunch-stop.sh before running the code
lsmod
Module Size Used by Tainted: G
aic8800_btlpm 1719 0
aic8800_fdrv 285463 0
aic8800_bsp 53767 2 aic8800_btlpm,aic8800_fdrv
aes_generic 24532 0
ccm 6847 0
ctr 2606 0
libarc4 799 0
pwm_bl 4629 0
cfg80211 168973 1 aic8800_fdrv
rve 23436 0
rockit 225880 0
rknpu 27019 0
mpp_vcodec 414257 1 rockit
rga3 90762 1 rockit
phy_rockchip_csi2_dphy 9338 0
phy_rockchip_csi2_dphy_hw 10066 0
video_rkisp 171838 1 rockit
video_rkcif 162117 1 rockit
sc3336 9940 1
rk_dvbm 5941 2 mpp_vcodec,video_rkisp
lsmod
aes_generic 24532 0
ccm 6847 0
ctr 2606 0
libarc4 799 0
pwm_bl 4629 0
rve 23436 0
rockit 225880 0
rknpu 27019 0
rga3 90762 1 rockit
sc3336 9940 1
I compiled again, made sure I ran RkLunch-stop.sh and can confirm the example worked. Thank you.
