Wireguard
How can I install wireguard on my luckfox pico-max 256? Thank you in advance
Hello, the installation and migration of the software are not within the scope of technical support. It is recommended to consult the official instructions of Wireguard to modify the kernel defconifg (this may require enabling NAT IPTABLE and other support). The wireguard-tools can be installed by using the command "./build.sh buildroot-config".
If you mean "luckfox pro-max" as "Luckfox Pico Pro-Max", please post your question on the Luckfox Pico-RV1103/RV1106 section. Previously, a community member provided a firmware supporting WireGuard for Luckfox Pico at https://github.com/Droid-MAX/Luckfox-Pico-SDWAN
