I would like to flash it by changing the configuration. As a result, the board is always in Maskrom and does not start the firmware.
I assembled it using the following configuration:
#!/bin/bash
# Board Config
export LF_ORIGIN_BOARD_CONFIG=BoardConfig-SPI_NOR-Buildroot-RV1106_Luckfox_Pico_Pro-IPC.mk
# Target CHIP
export RK_CHIP=rv1106
# app config
export RK_APP_TYPE=RKIPC_RV1106
# Config CMA size in environment
export RK_BOOTARGS_CMA_SIZE="66M"
# Kernel dts
export RK_KERNEL_DTS=rv1106g-luckfox-pico-pro.dts
# BOOT_MEDIUM
# Target boot medium: emmc/spi_nor/spi_nand
export RK_BOOT_MEDIUM=spi_nor
# Uboot defconfig fragment
export RK_UBOOT_DEFCONFIG_FRAGMENT=rk-sfc.config
# specify post.sh for delete/overlay files
# export RK_PRE_BUILD_OEM_SCRIPT=rv1103-spi_nor-post.sh
# config partition in environment
# RK_PARTITION_CMD_IN_ENV format:
# <partdef>[,<partdef>]
# <partdef> := <size>[@<offset>](part-name)
# Note:
# If the first partition offset is not 0x0, it must be added. Otherwise, it needn't adding.
export RK_PARTITION_CMD_IN_ENV="256K(env),256K@256K(idblock),512K(uboot),4M(boot),30M(oem),10M(userdata),210M(rootfs)"
# config partition's filesystem type (squashfs is readonly)
# emmc: squashfs/ext4
# nand: squashfs/ubifs
# spi nor: squashfs/jffs2
# RK_PARTITION_FS_TYPE_CFG format:
# AAAA:/BBBB/CCCC@ext4
# AAAA ----------> partition name
# /BBBB/CCCC ----> partition mount point
# ext4 ----------> partition filesystem type
export RK_PARTITION_FS_TYPE_CFG=rootfs@IGNORE@jffs2,oem@/oem@jffs2,userdata@/userdata@jffs2
# config filesystem compress (Just for squashfs or ubifs)
# squashfs: lz4/lzo/lzma/xz/gzip, default xz
# ubifs: lzo/zlib, default lzo
# export RK_SQUASHFS_COMP=xz
# export RK_UBIFS_COMP=lzo
# TARGET_ROOTFS
# Target rootfs : ubuntu(only emmc)/buildroot/busybox
export LF_TARGET_ROOTFS=buildroot
# Buildroot defconfig
export RK_BUILDROOT_DEFCONFIG=luckfox_pico_defconfig
# Defconfig
# Target arch
export RK_ARCH=arm
# Target Toolchain Cross Compile
export RK_TOOLCHAIN_CROSS=arm-rockchip830-linux-uclibcgnueabihf
#misc image
export RK_MISC=wipe_all-misc.img
# Uboot defconfig
export RK_UBOOT_DEFCONFIG=luckfox_rv1106_uboot_defconfig
# Kernel defconfig
export RK_KERNEL_DEFCONFIG=luckfox_rv1106_linux_defconfig
# Config sensor IQ files
# RK_CAMERA_SENSOR_IQFILES format:
# "iqfile1 iqfile2 iqfile3 ..."
# ./build.sh media and copy <SDK root dir>/output/out/media_out/isp_iqfiles/$RK_CAMERA_SENSOR_IQFILES
export RK_CAMERA_SENSOR_IQFILES="sc4336_OT01_40IRC_F16.json sc3336_CMK-OT2119-PC1_30IRC-F16.json mis5001_CMK-OT2115-PC1_30IRC-F16.json"
#export RK_CAMERA_SENSOR_IQFILES="sc4336_OT01_40IRC_F16.json sc3336_CMK-OT2119-PC1_30IRC-F16.json sc530ai_CMK-OT2115-PC1_30IRC-F16.json"
# Config sensor lens CAC calibrattion bin files
export RK_CAMERA_SENSOR_CAC_BIN="CAC_sc4336_OT01_40IRC_F16"
#export RK_CAMERA_SENSOR_CAC_BIN="CAC_sc4336_OT01_40IRC_F16 CAC_sc530ai_CMK-OT2115-PC1_30IRC-F16"
# build ipc web backend
#export RK_APP_IPCWEB_BACKEND=y
# enable install app to oem partition
export RK_BUILD_APP_TO_OEM_PARTITION=y
# enable rockchip test
export RK_ENABLE_ROCKCHIP_TEST=y
# PRE and POST
# specify pre.sh for delete/overlay files
export RK_PRE_BUILD_OEM_SCRIPT=luckfox-buildroot-oem-pre.sh
export RK_PRE_BUILD_USERDATA_SCRIPT=luckfox-userdata-pre.sh
# declare overlay directory
export RK_POST_OVERLAY="overlay-luckfox-config overlay-luckfox-buildroot-init overlay-luckfox-buildroot-shadow"
