我們購買了轻量级PicoKVM 使用, 使用後, PC OS畫面操作正常, 但在進入PC BIOS畫面後, 畫面顯示不正確:
因為BIOS下的解析度是800x600 60Hz, 有嘗試改用800x600 EDID, 但是BIOS畫面沒有變化, 還是一樣不正確:
使用的800x600 EDID字串如下:
00ffffffffffff0052620188008888881c150103800000790a0dc9a05747982712484c000000010101010101010101010101010101010000a020582c203030202020000000000020011d007251d01e206e285500c48e2100001e000000fc00543734392d6648443732300a20000000fd00147801ff1d000a202020202020017a
請問有建議的排查方式嗎?
另外請問貴司有販售PicoKVM的軟體授權嗎?
我們有購買和銷售相關的問題, 請問需要聯繫哪個email窗口? 謝謝.
Luckfox PicoKVM 使用和授權問題
您好,因EDID导致画面异常除了不断测试出正确的EDID外目前我们没有更好的建议,PicoKVM 的软件是基于开源项目二次开放的,遵守 GPL-2.0 协议,有需要可以了解 GPL-2.0 协议规定
Hi luckfox-support-team,
nice product. But there are green lines, if the resolution via vga-adapter is 1024x768 or 800x600. How can I optimize the resolution? Unfortunately the EDID above did not help. Also firmware update to 0.3 did not help. Also console command would help.
Thanks
mugel84
Thanks
mugel84
Hello,at present, we don't have any more effective suggestions regarding the display errors caused by EDID. The only solution at the moment is to keep trying and obtain the correct EDID.
