Device fails to start or update
  • 1. Please first provide the exact model of your development board.You can find this information in your purchase order.Also, please provide photos of your hardware connections.We need to know what display you are using — is it DSI or HDMI?If it is an HDMI display, what is the resolution?
    2. The normal boot indication of the development board is that the ACT LED should be blinking.If the ACT LED does not blink, it means the system did not boot properly.
    3. There are many possible reasons for a flashing failure.Based on the error you described, possible causes include:
    • USB hub / adapter on macOS causing communication instability
    • Device enters Maskrom but USB communication is unstable (power supply issue)
    • The board did not actually enter real Maskrom (false Maskrom state)
    For further diagnosis, it is best to provide us with serial debugging logs and more detailed information.
    Important Notes:
    • The power supply should be a Type-C 5V/3A adapter.We typically use the Raspberry Pi 4B power supply for testing.
    • If using a TF card (MicroSD card) as the system boot card, please use a Class 10, 16GB or larger card.
