DDR 306b9977f5 wesley.yao 23/12/21-09:28:37,fwver: v1.15
S5P1
4x
f967
rgef1
DDRConf2
DDR3, BW=16 Col=10 Bk=8 CS0 Row=14 CS=1 Size=256MB
924MHz
DDR bin out
U-Boot SPL board init
U-Boot SPL 2017.09 (Apr 30 2026 - 20:46:31)
unknown raw ID 0 0 0
Trying to boot from MMC2
Card did not respond to voltage select!
mmc_init: -95, time 20
spl: mmc init failed with error: -95
Trying to boot from MMC1
Best phase range 0-270 (25 len)
Successfully tuned phase to 135, used 3ms
ENVF: Primary 0x00000000 - 0x00008000
No misc partition
Trying fit image at 0x440 sector
## Verified-boot: 0
## Checking uboot 0x00200000 (lzma @0x00400000) ... sha256(404ced129a...) + sha256(56ddbad9ee...) + OK
## Checking fdt 0x00260998 ... sha256(9f596c5683...) + OK
Total: 385.224/416.971 ms
Jumping to U-Boot(0x00200000)
U-Boot 2017.09 (Apr 30 2026 - 20:46:31 +0800)
Model: Rockchip RV1106 EVB Board
MPIDR: 0xf00
PreSerial: 2, raw, 0xff4c0000
DRAM: 256 MiB
Sysmem: init
Relocation Offset: 0fd81000
Relocation fdt: 0edfa778 - 0edfede0
CR: M/C/I
Using default environment
mmc@ffa90000: 0, mmc@ffaa0000: 1
Successfully tuned phase to 135, used 4ms
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: ENV
DM: v2
No misc partition
boot mode: None
RESC: 'boot', blk@0x00001f26
resource: sha256+
DTB: rk-kernel.dtb
HASH(c): OK
Model: Luckfox Pico Pi W
## retrieving sd_update.txt ...
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 924000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
aclk_peri_root 400000 KHz
hclK_peri_root 200000 KHz
pclk_peri_root 100000 KHz
aclk_bus_root 300000 KHz
pclk_top_root 100000 KHz
pclk_pmu_root 100000 KHz
hclk_pmu_root 200000 KHz
Net: eth0: ethernet@ffa80000
Hit key to stop autoboot('CTRL+C'): 0
## Booting FIT Image at 0xe8dcb40 with size 0x0031cc00
Fdt Ramdisk skip relocation
No misc partition
Sysmem Warn: kernel 'reserved-memory' "mmc@3f000"(0x0003f000 - 0x00040000) is overlap with "KERNEL" (0x00008000 - 0x0031ac04)
sysmem_dump_all:
memory.rgn[0].addr = 0x00000000 - 0x10000000 (size: 0x10000000)
memory.total = 0x10000000 (256 MiB. 0 KiB)
allocated.rgn[0].name = "UBOOT"
.addr = 0x0edfa750 - 0x10000000 (size: 0x012058b0)
allocated.rgn[1].name = "STACK"
.addr = 0x0ebfa750 - 0x0edfa750 (size: 0x00200000)
allocated.rgn[2].name = "FIT"
.addr = 0x0e8dcb40 - 0x0ebf9744 (size: 0x0031cc04)
allocated.rgn[3].name = "FDT"
.addr = 0x00c00000 - 0x00c09804 (size: 0x00009804)
allocated.rgn[4].name = "KERNEL"
.addr = 0x00008000 - 0x0031ac04 (size: 0x00312c04)
kmem-resv.rgn[0].name = "mmc@3f000"
.addr = 0x0003f000 - 0x00040000 (size: 0x00001000)
framework malloc_r = 16 MiB
framework malloc_f = 512 KiB
allocated.total = 0x01a3f8bc (26 MiB. 254 KiB)
LMB.allocated[0].addr = 0x00008000 - 0x0031ac04 (size: 0x00312c04)
LMB.allocated[1].addr = 0x00c00000 - 0x00c09804 (size: 0x00009804)
LMB.allocated[2].addr = 0x0e8dcb40 - 0x0ebf9780 (size: 0x0031cc40)
LMB.allocated[3].addr = 0x0ebfa750 - 0x10000000 (size: 0x014058b0)
reserved.core.total = 0x01a3e8f8 (26 MiB. 250 KiB)
## Loading kernel from FIT Image at 0e8dcb40 ...
Using 'conf' configuration
## Verified-boot: 0
Trying 'kernel' kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x0e8e6b40
Data Size: 3222232 Bytes = 3.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha256
Hash value: 40e8e13ec6a619d8c428506a2ee7cbdb5e4c1f1edf67214c4f77ff15d1b88625
Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 0e8dcb40 ...
Trying 'fdt' fdt subimage
Type: Flat Device Tree
Data Start: 0x0e8dd340
Data Size: 38509 Bytes = 37.6 KiB
Architecture: ARM
Load Address: 0x00c00000
Hash algo: sha256
Hash value: 2b256ecebb7fe287a6950907a2e2d04aa5498113f3b4f03b99be489c0b63186a
Loading fdt from 0x0e8dcb40 to 0x00c00000
Booting using the fdt blob at 0x00c00000
Loading Kernel Image from 0x0e8e6b40 to 0x00008000 ... OK
kernel loaded at 0x00008000, end = 0x0031aad8
Using Device Tree in place at 00c00000, end 00c0c66c
## reserved-memory:
mmc@3f000: addr=3f000 size=1000
Adding bank: 0x00000000 - 0x10000000 (size: 0x10000000)
Total: 813.142/1235.188 ms
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.160 (luckfox@luckfox) (arm-rockchip830-linux-uclibcgnueabihf-gcc (crosstool-NG 1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1 Thu Apr 30 18:06:04 CST 2026
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Luckfox Pico Pi W
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 67584 KiB at 0x0be00000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000000fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000000fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000000fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal rootwait earlycon=uart8250,mmio32,0xff4c0000 console=ttyFIQ0 root=/dev/mmcblk0p7 snd_soc_core.prealloc_buffer_size_kbytes=16 coherent_pool=0 blkdevparts=mmcblk0:32K(env),512K@32K(idblock),256K(uboot),32M(boot),512M(oem),256M(userdata),6G(rootfs) rootfstype=ext4 rk_dma_heap_cma=66M androidboot.fwver=uboot-04/30/2026
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 185096K/262144K available (4056K kernel code, 388K rwdata, 1948K rodata, 204K init, 149K bss, 9464K reserved, 67584K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000517] Console: colour dummy device 80x30
[ 0.000559] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000575] pid_max: default: 4096 minimum: 301
[ 0.000736] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000750] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001314] CPU: Testing write buffer coherency: ok
[ 0.001874] Setting up static identity map for 0x81c0 - 0x81f8
[ 0.002357] devtmpfs: initialized
[ 0.009366] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.009522] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.009542] futex hash table entries: 16 (order: -5, 192 bytes, linear)
[ 0.009616] pinctrl core: initialized pinctrl subsystem
[ 0.010768] NET: Registered protocol family 16
[ 0.011205] DMA: failed to allocate 0 KiB pool for atomic coherent allocation
[ 0.011714] Registered FIQ tty driver
[ 0.012029] thermal_sys: Registered thermal governor 'step_wise'
[ 0.012037] thermal_sys: Registered thermal governor 'user_space'
[ 0.012251] cpuidle: using governor menu
[ 0.026231] rockchip-gpio ff380000.gpio: probed /pinctrl/gpio@ff380000
[ 0.026856] rockchip-gpio ff530000.gpio: probed /pinctrl/gpio@ff530000
[ 0.027445] rockchip-gpio ff540000.gpio: probed /pinctrl/gpio@ff540000
[ 0.028144] rockchip-gpio ff550000.gpio: probed /pinctrl/gpio@ff550000
[ 0.028721] rockchip-gpio ff560000.gpio: probed /pinctrl/gpio@ff560000
[ 0.028806] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.039210] fiq_debugger fiq_debugger.0: IRQ uart_irq not found
[ 0.039231] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 0.039491] printk: console [ttyFIQ0] enabled
[ 0.039657] Registered fiq debugger ttyFIQ0
[ 0.040792] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[ 0.040823] reg-fixed-voltage: probe of vdd-arm failed with error -22
[ 0.041420] SCSI subsystem initialized
[ 0.041616] usbcore: registered new interface driver usbfs
Seeding 256 bits without crediting
[ 0.041663] usbcore: registered new interface driver hub
Saving 256 bits of creditable seed for next boot
[ 0.041721] usbcore: registered new device driver usb
Starting syslogd: [ 0.041941] mc: Linux media interface: v0.10
OK
[ 0.041981] videodev: Linux video capture interface: v2.00
[ 0.043032] Advanced Linux Sound Architecture Driver Initialized.
[ 0.043515] Bluetooth: Core ver 2.22
Starting klogd: [ 0.043583] NET: Registered protocol family 31
OK
[ 0.043594] Bluetooth: HCI device and connection manager initialized
[ 0.043610] Bluetooth: HCI socket layer initialized
[ 0.043622] Bluetooth: L2CAP socket layer initialized
[ 0.043645] Bluetooth: SCO socket layer initialized
[ 0.044066] rockchip-cpuinfo cpuinfo: SoC : 11061000
Running sysctl: [ 0.044090] rockchip-cpuinfo cpuinfo: Serial : cb23b7bb575806db
[ 0.044466] rockchip,rknpor-powergood ff000000.syscon:rknpor-powergood: probe success!
[ 0.045322] clocksource: Switched to clocksource arch_sys_counter
[ 0.051435] NET: Registered protocol family 2
[ 0.051656] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
OK
[ 0.052120] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.052154] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
Populating /dev using udev: [ 0.052180] TCP bind hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.052202] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.052289] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.052317] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.052440] NET: Registered protocol family 1
[ 0.052925] RPC: Registered named UNIX socket transport module.
[ 0.052945] RPC: Registered udp transport module.
[ 0.052954] RPC: Registered tcp transport module.
[ 0.052960] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.053846] rockchip-thermal ff3c8000.tsadc: tsadc is probed successfully!
[ 0.054836] Initialise system trusted keyrings
[ 0.055073] workingset: timestamp_bits=30 max_order=16 bucket_order=0
[ 0.058598] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.059342] NFS: Registering the id_resolver key type
[ 0.059402] Key type id_resolver registered
[ 0.059412] Key type id_legacy registered
[ 0.059455] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.147793] Key type asymmetric registered
[ 0.147815] Asymmetric key parser 'x509' registered
[ 0.147840] io scheduler mq-deadline registered
[ 0.148210] rockchip-usb2phy ff3e0000.usb2-phy: IRQ index 0 not found
[ 0.152826] dma-pl330 ff420000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.152859] dma-pl330 ff420000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.153607] rockchip-pvtm ff240000.pvtm: pvtm@0 probed
[ 0.153768] rockchip-pvtm ff390000.pvtm: pvtm@0 probed
[ 0.154068] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.154580] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.155202] ff4b0000.serial: ttyS1 at MMIO 0xff4b0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.161215] random: crng init done
[ 0.168838] brd: module loaded
[ 0.173927] loop: module loaded
[ 0.175967] rk_gmac-dwmac ffa80000.ethernet: IRQ eth_lpi not found
[ 0.176131] rk_gmac-dwmac ffa80000.ethernet: PTP uses main clock
[ 0.176172] rk_gmac-dwmac ffa80000.ethernet: no regulator found
[ 0.176187] rk_gmac-dwmac ffa80000.ethernet: clock input or output? (input).
[ 0.176198] rk_gmac-dwmac ffa80000.ethernet: Can not read property: tx_delay.
[ 0.176208] rk_gmac-dwmac ffa80000.ethernet: set tx_delay to 0xffffffff
[ 0.176218] rk_gmac-dwmac ffa80000.ethernet: Can not read property: rx_delay.
[ 0.176226] rk_gmac-dwmac ffa80000.ethernet: set rx_delay to 0xffffffff
[ 0.176322] rk_gmac-dwmac ffa80000.ethernet: integrated PHY? (yes).
[ 0.176341] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_rx
[ 0.176352] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_tx
[ 0.176384] rk_gmac-dwmac ffa80000.ethernet: cannot get clock clk_mac_speed
[ 0.176394] rk_gmac-dwmac ffa80000.ethernet: clock input from PHY
[ 0.176638] rk_gmac-dwmac ffa80000.ethernet: init for RMII
[ 0.176835] rk_gmac-dwmac ffa80000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.176857] rk_gmac-dwmac ffa80000.ethernet: DWMAC4/5
[ 0.176871] rk_gmac-dwmac ffa80000.ethernet: DMA HW capability register supported
[ 0.176882] rk_gmac-dwmac ffa80000.ethernet: RX Checksum Offload Engine supported
[ 0.176889] rk_gmac-dwmac ffa80000.ethernet: TX Checksum insertion supported
[ 0.176899] rk_gmac-dwmac ffa80000.ethernet: Wake-Up On Lan supported
[ 0.176906] rk_gmac-dwmac ffa80000.ethernet: TSO supported
[ 0.176915] rk_gmac-dwmac ffa80000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.176924] rk_gmac-dwmac ffa80000.ethernet: TSO feature enabled
[ 0.176935] rk_gmac-dwmac ffa80000.ethernet: Using 40 bits DMA width
[ 0.179209] PPP generic driver version 2.4.2
[ 0.179441] PPP BSD Compression module registered
[ 0.179457] PPP Deflate Compression module registered
[ 0.179517] usbcore: registered new interface driver asix
[ 0.179568] usbcore: registered new interface driver ax88179_178a
[ 0.179616] usbcore: registered new interface driver cdc_ether
[ 0.179654] usbcore: registered new interface driver net1080
[ 0.179688] usbcore: registered new interface driver rndis_host
[ 0.179726] usbcore: registered new interface driver cdc_subset
[ 0.179757] usbcore: registered new interface driver zaurus
[ 0.179815] usbcore: registered new interface driver cdc_ncm
[ 0.179848] usbcore: registered new interface driver qmi_wwan
[ 0.184565] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.184877] usbcore: registered new interface driver cdc_wdm
[ 0.184938] usbcore: registered new interface driver usb-storage
[ 0.185035] usbcore: registered new interface driver option
[ 0.185067] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.185112] usbcore: registered new interface driver qcserial
[ 0.185148] usbserial: USB Serial support registered for Qualcomm USB modem
[ 0.185298] gadgetfs: USB Gadget filesystem, version 24 Aug 2004
[ 0.185384] Mass Storage Function, version: 2009/09/11
[ 0.185401] LUN: removable file: (no medium)
[ 0.185431] no file given for LUN0
[ 0.185464] udc ffb00000.usb: failed to start g_mass_storage: -22
[ 0.186904] rockchip-rtc ff1c0000.rtc: registered as rtc0
[ 0.186979] rockchip-rtc ff1c0000.rtc: setting system clock to 2020-01-01T12:00:12 UTC (1577880012)
[ 0.187196] i2c /dev entries driver
[ 0.189472] usbcore: registered new interface driver uvcvideo
[ 0.189494] USB Video Class driver (1.1.1)
[ 0.190081] Bluetooth: HCI UART driver ver 2.3
[ 0.190099] Bluetooth: HCI UART protocol H4 registered
[ 0.190276] cpu cpu0: leakage=17
[ 0.191006] Synopsys Designware Multimedia Card Interface Driver
[ 0.191904] dtbocfg: 0.1.0
[ 0.191947] dtbocfg: OK
[ 0.193102] rockchip-pinctrl pinctrl: pin gpio2-1 already requested by ff470000.i2c; cannot claim for ff9a0000.mmc
[ 0.193129] rockchip-pinctrl pinctrl: pin-65 (ff9a0000.mmc) status -22
[ 0.193145] rockchip-pinctrl pinctrl: could not request pin 65 (gpio2-1) from group sdmmc1m0-bus4 on device rockchip-pinctrl
[ 0.193155] dwmmc_rockchip ff9a0000.mmc: Error applying setting, reverse things back
[ 0.193188] dwmmc_rockchip: probe of ff9a0000.mmc failed with error -22
[ 0.193522] dwmmc_rockchip ffa90000.mmc: IDMAC supports 32-bit address mode.
[ 0.193567] dwmmc_rockchip ffa90000.mmc: Using internal DMA controller.
[ 0.193585] dwmmc_rockchip ffa90000.mmc: Version ID is 270a
[ 0.193626] dwmmc_rockchip ffa90000.mmc: DW MMC controller at irq 53,32 bit host data width,256 deep fifo
[ 0.193736] mmc_host mmc0: card is non-removable.
[ 0.194016] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.194593] dwmmc_rockchip ffaa0000.mmc: No normal pinctrl state
[ 0.194617] dwmmc_rockchip ffaa0000.mmc: No idle pinctrl state
[ 0.194741] dwmmc_rockchip ffaa0000.mmc: IDMAC supports 32-bit address mode.
[ 0.194778] dwmmc_rockchip ffaa0000.mmc: Using internal DMA controller.
[ 0.194794] dwmmc_rockchip ffaa0000.mmc: Version ID is 270a
[ 0.194836] dwmmc_rockchip ffaa0000.mmc: DW MMC controller at irq 54,32 bit host data width,256 deep fifo
[ 0.194936] dwmmc_rockchip ffaa0000.mmc: allocated mmc-pwrseq
[ 0.194951] mmc_host mmc1: card is non-removable.
[ 0.196358] rv1106-acodec ff480000.acodec: current soc_id: rv1106
[ 0.196439] rv1106-acodec ff480000.acodec: No use pa_ctl_gpio and pa_ctl_delay_ms: 0
[ 0.197983] NET: Registered protocol family 17
[ 0.198182] Bluetooth: RFCOMM TTY layer initialized
[ 0.198208] Bluetooth: RFCOMM socket layer initialized
[ 0.198239] Bluetooth: RFCOMM ver 1.11
[ 0.198306] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.198317] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.198823] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 5.
[ 0.198866] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 2.
[ 0.198888] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 34.
[ 0.198901] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 0.198955] [BT_RFKILL]: Failed to get bt_default_wake_host gpio.
[ 0.198999] rfkill_bt: probe of wireless-bluetooth failed with error -1
[ 0.199080] Key type dns_resolver registered
[ 0.199969] Loading compiled-in X.509 certificates
[ 0.215069] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.227983] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.228622] rockchip-pinctrl pinctrl: pin gpio2-1 already requested by ff470000.i2c; cannot claim for ff9a0000.mmc
[ 0.228645] rockchip-pinctrl pinctrl: pin-65 (ff9a0000.mmc) status -22
[ 0.228658] rockchip-pinctrl pinctrl: could not request pin 65 (gpio2-1) from group sdmmc1m0-bus4 on device rockchip-pinctrl
[ 0.228668] dwmmc_rockchip ff9a0000.mmc: Error applying setting, reverse things back
[ 0.228704] dwmmc_rockchip: probe of ff9a0000.mmc failed with error -22
[ 0.240074] mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
[ 0.245363] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[ 0.245551] mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
[ 0.246539] mmc1: new SDIO card at address 7a8a
[ 0.252241] mmc_host mmc0: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[ 0.254773] mmc0: new high speed MMC card at address 0001
[ 0.255193] mmcblk0: mmc0:0001 TWSC 7.13 GiB
[ 0.255300] mmcblk0boot0: mmc0:0001 TWSC partition 1 4.00 MiB
[ 0.255430] mmcblk0boot1: mmc0:0001 TWSC partition 2 4.00 MiB
[ 0.255630] mmcblk0rpmb: mmc0:0001 TWSC partition 3 4.00 MiB, chardev (247:0)
[ 0.256074] mmcblk0: p1(env) p2(idblock) p3(uboot) p4(boot) p5(oem) p6(userdata) p7(rootfs)
[ 0.308085] ALSA device list:
[ 0.308112] #0: rv1106-acodec
[ 0.317993] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
[ 0.318017] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
[ 0.373145] EXT4-fs (mmcblk0p7): recovery complete
[ 0.378583] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 0.378670] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 0.383523] devtmpfs: mounted
[ 0.383723] Freeing unused kernel memory: 204K
[ 0.383734] Kernel memory protection not selected by kernel config.
[ 0.383769] Run /sbin/init as init process
[ 0.389737] process '/bin/busybox' started with executable stack
[ 0.457034] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 0.710363] udevd[100]: starting version 3.2.7
[ 0.719616] udevd[100]: specified group 'input' unknown
[ 0.720611] udevd[100]: specified group 'kvm' unknown
[ 0.746034] udevd[101]: starting eudev-3.2.7
done
resize2fs 1.46.5 (30-Dec-2021)
The filesystem is already 1572864 (4k) blocks long. Nothing to do!
e2fsck 1.46.5 (30-Dec-2021)
userdata: recovering journal
Setting free inodes count to 65525 (was 0)
Setting free blocks count to 243616 (was 0)
userdata: clean, 11/65536 files, 18528/262144 blocks
[ 2.102165] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.102216] ext4 filesystem being mounted at /userdata supports timestamps until 2038 (0x7fffffff)
The filesystem is already 262144 (1k) blocks long. Nothing to do!
tune2fs 1.46.5 (30-Dec-2021)
oem: recovering journal
Setting free inodes count to 32559 (was 0)
Setting free blocks count to 119816 (was 0)
oem: clean, 209/32768 files, 11256/131072 blocks
[ 2.399217] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
The filesystem is already 131072 (4k) blocks long. Nothing to do!
Initializing random number generator... done.
/dev/block/by-name/userdata on /userdata type ext4 (rw,relatime)
Starting system message bus: [ 2.609473] rk_dvbm ffa70000.rkdvbm: probe start
[ 2.609511] rk_dvbm ffa70000.rkdvbm: dvbm ctx 601bdade
[ 2.609823] rk_dvbm ffa70000.rkdvbm: probe success
[ 2.634860] sc3336 4-0030: driver version: 00.01.01
[ 2.634968] sc3336 4-0030: Failed to get pwdn-gpios
[ 2.634985] sc3336 4-0030: could not get default pinstate
[ 2.634993] sc3336 4-0030: could not get sleep pinstate
[ 2.635016] sc3336 4-0030: supply avdd not found, using dummy regulator
[ 2.635218] sc3336 4-0030: supply dovdd not found, using dummy regulator
[ 2.635283] sc3336 4-0030: supply dvdd not found, using dummy regulator
dbus[170]: Unknown username "pulse" in message bus configuration file
done
Starting bluetoothd: OK
Starting network: OK
Starting ntpd: [ 2.855387] rk3x-i2c ff470000.i2c: timeout, ipd: 0x00, state: 3
[ 2.855425] sc3336 4-0030: Unexpected sensor id(000000), ret(-5)
[ 2.867072] mis5001 4-0031: driver version: 00.01.02
[ 2.867196] mis5001 4-0031: Failed to get pwdn-gpios
[ 2.867211] mis5001 4-0031: could not get default pinstate
[ 2.867219] mis5001 4-0031: could not get sleep pinstate
[ 2.867243] mis5001 4-0031: supply avdd not found, using dummy regulator
[ 2.867442] mis5001 4-0031: supply dovdd not found, using dummy regulator
[ 2.867502] mis5001 4-0031: supply dvdd not found, using dummy regulator
OK
[ 3.085386] rk3x-i2c ff470000.i2c: timeout, ipd: 0x00, state: 3
[ 3.085436] mis5001 4-0031: Unexpected sensor id(000000), ret(-5)
[ 3.106324] rkcifhw ffa10000.rkcif: no iommu attached, using non-iommu buffers
[ 3.106352] rkcifhw ffa10000.rkcif: No reserved memory region assign to CIF
ssh-keygen: generating new host keys: RSA [ 3.106733] rkcif rkcif-mipi-lvds: rkcif driver version: v00.02.00
[ 3.106875] rkcif rkcif-mipi-lvds: attach to cif hw node
[ 3.106889] rkcif rkcif-mipi-lvds: failed to get dphy hw node
[ 3.106898] rkcif rkcif-mipi-lvds: rkcif wait line 0
[ 3.106910] rkcif rkcif-mipi-lvds: rkcif fastboot reserve bufs num 3
[ 3.106925] : terminal subdev does not exist
[ 3.106935] : terminal subdev does not exist
[ 3.106943] : terminal subdev does not exist
[ 3.106950] : terminal subdev does not exist
[ 3.106960] : get_remote_sensor: video pad[0] is null
[ 3.106971] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.106982] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 3.106991] : get_remote_sensor: video pad[0] is null
[ 3.106998] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.107008] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 3.107016] : get_remote_sensor: video pad[0] is null
[ 3.107023] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.107032] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 3.107040] : get_remote_sensor: video pad[0] is null
[ 3.107047] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.107055] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 3.115024] rkcif rkcif-mipi-lvds: No memory-region-thunderboot specified
[ 3.116348] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 3.116514] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 3.116650] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 3.116769] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 3.117157] rockchip-mipi-csi2 mipi0-csi2: attach to csi2 hw node
[ 3.117228] rkcif rkcif-mipi-lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 3.117244] rockchip-mipi-csi2: Async registered subdev
[ 3.117254] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds!
[ 3.155611] rkisp_hw ffa00000.rkisp: is_thunderboot: 0
[ 3.155637] rkisp_hw ffa00000.rkisp: Missing rockchip,grf property
[ 3.155679] rkisp_hw ffa00000.rkisp: max input:0x0@0fps
0
[ 3.155845] rkisp_hw ffa00000.rkisp: get sram size:253952
[ 3.155861] rkisp_hw ffa00000.rkisp: no iommu attached, using non-iommu buffers
[ 3.155870] rkisp_hw ffa00000.rkisp: No reserved memory region. default cma area!
[ 3.156239] rkisp rkisp-vir0: rkisp driver version: v02.05.00
[ 3.156360] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 3.157346] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 3.185916] rockchip-csi2-dphy-hw ff3e8000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 3.205005] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
Luckfox Pico Pi A W 在接SC3336无法启动
请检查一下供电是否稳定,内核日志在WIFI模组初始化之前就停止,WIFI模组在启动初始化时功耗要求较大,有可能是供电不足导致
