Yes sir it has been commented
fi
if [ ! -f "$rkipc_ini" ]; then
cp $default_rkipc_ini $rkipc_ini -f
fi
if [ ! -f "/userdata/image.bmp" ]; then
cp -fa /oem/usr/share/image.bmp /userdata/
fi
#if [ -d "/oem/usr/share/iqfiles" ];then
# rkipc -a /oem/usr/share/iqfiles &
#else
# rkipc &
#fi
# ip addr show eth0
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq qlen 1000
link/ether 76:58:87:d0:3b:02 brd ff:ff:ff:ff:ff:ff
# ifconfig
eth0 Link encap:Ethernet HWaddr 76:58:87:D0:3B:02
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:30212 errors:0 dropped:12 overruns:0 frame:0
TX packets:292 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2101180 (2.0 MiB) TX bytes:99864 (97.5 KiB)
Interrupt:50
# ip addr show eth0
link# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
ping: sendto: Network is unreachable
Luckfox pico max ethernet and sd card issue
fi
fi
#else
# rkipc &
#fi
# ping 8.8.8.8
# ip route show
172.32.0.0/16 dev usb0 scope link src 172.32.0.93
fi
#else
# rkipc &
#fi
# ping 8.8.8.8
# ip route show
I noticed that you can identify eth0 when executing ifconfig, but the network is still not connected successfully. Please try to modify the IP address (192.168.0.35) in the static ip script and try again.
Sir i have inserted a new 32 gb memory card in Luckfox pico max but it is not showing in the shell kernel.please suggest
LuckFox Pico Pro/Max come with an SD card pre-mounted, so you can simply plug it in and use it.
Download link:https://drive.google.com/drive/folders/ ... drive_link
