ssh log/pass in Direct Network Cable Configuration?
  • Hello, if you are using an Ubuntu system, the corresponding commands for the user you want to use are as follows:
    # Login as root user
    ssh [email protected]
    # password: root
    # Login as pico user
    # password: luckfox
    If you are using a Buildroot system (single user), the corresponding command is:
    # password: luckfox
    You can refer to the link in the wiki https://wiki.luckfox.com/zh/Luckfox-Pic ... lnet-Login for more information.
  • I connect via module Rj45 Ethernet Expansion Module For Melk V Without Milk V Motherboard) Extended version.
    link https://www.aliexpress.com/item/1005006 ... 1802615zK7
    I use frimware Luckfox_Pico_Plus_Ubuntu_MicroSD-20240829T094931Z for support Rj45 Ethernet.
    I connect via putty, with data SSH IP 192.168.10.200 (ping 192.168.10.200 OK!!!!).
    I receive an invitation in putty!!!!
    what password and login should i enter to connect via putty?
    I tried your recommendations. They don't work.
    C:\Users\user>ping 192.168.10.200
    Обмен пакетами с 192.168.10.200 по с 32 байтами данных:
    Ответ от 192.168.10.200: число байт=32 время=3мс TTL=64
    Ответ от 192.168.10.200: число байт=32 время=1мс TTL=64
    Статистика Ping для 192.168.10.200:
    Пакетов: отправлено = 4, получено = 4, потеряно = 0
    (0% потерь)
    Приблизительное время приема-передачи в мс:
    Минимальное = 1мсек, Максимальное = 3 мсек, Среднее = 1 мсек
    C:\Users\user>ssh [email protected]
    [email protected]'s password: root
    Connection closed by 192.168.10.200 port 22
  • I mainly use 192.168.10.200, which does not seem to be the IP address of the Luckfox Pico's eth0. You might want to try logging into the Luckfox Pico via ADB to check if the IP address is set correctly, or first try connecting via ssh [email protected] to see if that works.
  • I have connection:
    root@luckfox:/etc/init.d# ifconfig
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
    inet 192.168.10.200 netmask 255.255.252.0 broadcast 192.168.11.255
    ether 1a:f9:72:3b:87:85 txqueuelen 1000 (Ethernet)
    RX packets 906 bytes 74423 (74.4 KB)
    RX errors 0 dropped 0 overruns 0 frame 0
    TX packets 1125 bytes 64618 (64.6 KB)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    device interrupt 45
    Pinging 192.168.10.200 with 32 bytes of data:
    Reply from 192.168.10.200: bytes=32 time=1ms TTL=64
    Reply from 192.168.10.200: bytes=32 time=2ms TTL=64
    Ping statistics for 192.168.10.200:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 2ms, Average = 1ms
    I have an invitation:
    I can't find the password!!
    Is it possible to solve this problem? How? Maybe there are other options?
  • Given the complexity of the network, it’s difficult to pinpoint the exact cause of the SSH failure. Potential reasons could include IP conflicts or port occupation. If you're certain that the device with IP `192.168.10.200` is the only Luckfox Pico, please execute the following in Windows:
    #USERPROFILE is the path to your user folder, typically located under C:/Users/<Your User Name>/
    ssh-keygen -f "%USERPROFILE%/.ssh/known_hosts" -R "192.168.10.200"
    After that, try reconnecting via SSH.
