index=0, name=images, n_dims=4, dims=[1, 640, 640, 3], n_elems=1228800, size=1228800, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003922
index=0, name=output0, n_dims=4, dims=[1, 80, 80, 255], n_elems=1632000, size=1632000, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003922
index=1, name=286, n_dims=4, dims=[1, 40, 40, 255], n_elems=408000, size=408000, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003922
index=2, name=288, n_dims=4, dims=[1, 20, 20, 255], n_elems=102000, size=102000, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003922
model is NHWC input fmt
model input height=640, width=640, channel=3
init rknn model success!
load lable ./model/coco_80_labels_list.txt
rkaiq log level ff0
ID: 0, sensor_name is , iqfiles is /etc/iqfiles
Segmentation fault (core dumped)
在pico上运行luckfox_pico_rtsp_yolov5,出现以下问题,如何解决
您好 ,根据log信息看应该是摄像头问题,请检查是否执行RKlunch-stop.sh 解除摄像头占用,同时需要提醒一下在luckfox pico(rv1103)上由于资源限制是无法运行 luckfox_pico_rtsp_yolov5 的,详细请参考https://wiki.luckfox.com/zh/Luckfox-Pic ... F%E6%8C%81 平台支持说明
