luck fox ultra w 编译uboot下载很慢,有啥加速方法
Posted: 2024-09-28 10:25
by idotce
Re: luck fox ultra w 编译uboot下载很慢,有啥加速方法
Posted: 2024-09-28 10:38
您好 uboot 默认是不连接网络的,编译慢可能是电脑性能或者虚拟机配置问题,如果使用虚拟机的话可以看一下是是否分配了足够的内容和CPU数量
Posted: 2024-09-28 11:43
by idotce
wget --passive-ftp -nd -t 3 -O '/data/build/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/build/.waf-2.0.24.bcXnVq/output' 'https://waf.io/waf-2.0.24'
--2024-09-28 19:43:27-- https://waf.io/waf-2.0.24
Connecting to 192.168.1.5:8888... connected.
Proxy request sent, awaiting response... 200 OK
Length: 105408 (103K) [application/octet-stream]
Saving to: '/data/build/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/build/.waf-2.0.24.bcXnVq/output'
/data/build/luckfox-pico/sysd 100%[=================================================>] 102.94K 189KB/s in 0.5s
2024-09-28 19:43:30 (189 KB/s) - '/data/build/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/build/.waf-2.0.24.bcXnVq/output' saved [105408/105408]
waf-2.0.24: OK (sha1: 9cc6db88ecda57067024f368722ecbf48a3bba1a)
waf-2.0.24: OK (sha256: 93909bca823a675f9f40af7c65b24887c3a3c0efdf411ff1978ba827194bdeb0)
>>> pulseaudio 16.1 Downloading
wget --passive-ftp -nd -t 3 -O '/data/build/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/build/.pulseaudio-16.1.tar.xz.oiYh4x/output' 'https://mirrors.lzu.edu.cn/buildroot/pu ... 6.1.tar.xz'
--2024-09-28 19:43:30-- https://mirrors.lzu.edu.cn/buildroot/pu ... 6.1.tar.xz
Proxy request sent, awaiting response... 302 Moved Temporarily
Location: https://mirrors.687461.xyz/buildroot/pu ... 6.1.tar.xz [following]
--2024-09-28 19:43:30-- https://mirrors.687461.xyz/buildroot/pu ... 6.1.tar.xz
Posted: 2024-09-28 11:44
by idotce
奇怪,我的一直在下载uboot里的东西
Posted: 2024-09-29 1:26
您好 这里是buildroot在下载软件包, 可以参考viewtopic.php?p=3431&hilit=buildroot#p3431修复
