LuckfoxPico Max rv1106 如何安装iptables
  • 您好, iptables 要启动有多个内核依赖选项,这里是一份可以支持NAT转发的内核设置,您可以参考一下。
    rv1106-NAT.7z (433 Bytes)
    Downloaded 681 times
    需要的可以通过修改板级支持文件.BoardConfig.mk 中添加内核选项扩展或者直接修改内核defconfig后重新编译内核烧录
    export RK_KERNEL_DEFCONFIG_FRAGMENT="<其他覆盖选项文件> rv1106_NAT.config "
  • 参考
    https://blog.csdn.net/motianjie/article ... /131206295
    https://blog.csdn.net/oshan2012/article ... /114572330
    https://www.cnblogs.com/twzy/p/15126656.html
    执行
    uname -r
    mkdir /lib/modules
    ln -s /oem/usr/ko /lib/modules/5.10.110
    depmod
    iptables -L
  • fcoolt wrote: 2024-11-08 4:29 参考
    执行
    uname -r
    mkdir /lib/modules
    depmod
    iptables -L
    感谢分享
  • Alenwowo wrote: 2024-11-08 5:59
    执行
    uname -r
    mkdir /lib/modules
    depmod
    iptables -L
    感谢分享
    In my case:
    [root@luckfox root]# iptables -L
    modprobe: can't change directory to '/lib/modules': No such file or directory
    iptables v1.8.9 (legacy): can't initialize iptables table `filter': Table does n ot exist (do you need to insmod?)
    Perhaps iptables or your kernel needs to be upgraded.
  • Hello.
    This method is applicable to the older version of the SDK (kernel version 5.10.110). The latest version of the SDK has upgraded its kernel to 5.10.160. The correct command to execute should be
    uname -r
    mkdir /lib/modules
    ln -s /oem/usr/ko /lib/modules/5.10.160 depmod
    iptables -L
