make ARCH=arm CROSS_COMPILE=arm-rockchip830-linux-uclibcgnueabihf- source -C /home/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6
make[1]: Entering directory '/home/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6'
/usr/bin/make -j1 O=/home/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" syncconfig
make[2]: Entering directory '/home/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6'
make[2]: Leaving directory '/home/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6'
Your PATH contains spaces, TABs, and/or newline (\n) characters.
This doesn't work. Fix you PATH.
make[1]: *** [support/dependencies/dependencies.mk:27: dependencies] Error 1
make[1]: Leaving directory '/home/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6'
make: *** [Makefile:572: buildroot] Error 2
make: Leaving directory '/home/luckfox/luckfox-pico/sysdrv'
[build.sh:error] Running build_sysdrv failed!
[build.sh:error] exit code 2 from line 653:
[build.sh:info] make -C ${SDK_SYSDRV_DIR}
