Konver Keras-Model to RKNN
Posted: 2024-10-03 13:41
by ugoebel
I have been trying to convert a Tensorflow/Keras model into an RKNN model for some time now. I have the model here:
import numpy as np
from tensorflow import keras
from tensorflow.keras import layers
import tensorflow as tf
import onnx
import tf2onnx
# 1. MNIST-Modell mit CNN in Keras
# Daten laden und vorbereiten
(x_train, y_train), (x_test, y_test) = keras.datasets.mnist.load_data()
x_train = x_train.reshape(-1, 28, 28, 1).astype("float32") / 255
x_test = x_test.reshape(-1, 28, 28, 1).astype("float32") / 255
# Modell definieren
model = keras.Sequential([
    layers.Input(shape=(28, 28, 1)),
    layers.Conv2D(32, kernel_size=(3, 3), activation="relu"),
    layers.MaxPooling2D(pool_size=(2, 2)),
    layers.Conv2D(64, kernel_size=(3, 3), activation="relu"),
    layers.Flatten(),
    layers.Dropout(0.5),
    layers.Dense(10, activation="softmax")
# Modell kompilieren
model.compile(loss="sparse_categorical_crossentropy", optimizer="adam", metrics=["accuracy"])
# Modell trainieren
model.fit(x_train, y_train, batch_size=128, epochs=5, validation_split=0.1)
# Modell evaluieren
score = model.evaluate(x_test, y_test, verbose=0)
print(f"Test loss: {score[0]}")
print(f"Test accuracy: {score[1]}")
# 2. Speichern des Modells als ONNX
# Modell als SavedModel speichern
tf.saved_model.save(model, "mnist_model")
# Konvertierung zu ONNX
input_signature = [tf.TensorSpec([None, 28, 28, 1], tf.float32, name='input')]
#onnx_model, _ = tf2onnx.convert.from_keras(model)
onnx_model, _ = tf2onnx.convert.from_keras(model, input_signature, opset=13)
onnx.save(onnx_model, "mnist_model.onnx")
I have not been able to do this so far. Could someone please give me an example of how to do this. I have seen many examples using PyTorch. But I am more familiar with Tensorflow and would like to use it.
Re: Konver Keras-Model to RKNN
Posted: 2024-10-07 14:23
Hello, if you have any questions about RKNN model conversion, you can go to https://github.com/airockchip/rknn_model_zoo to initiate an issue. RKNN is provided by Rockchip. We can only get limited details.
Posted: 2024-10-11 21:41
by ugoebel
Ok, thank you. I will try it.
