I've followed the guide form this page
https://wiki.luckfox.com/Luckfox-Pico/L ... Burn-Image
But I receive "Wait For Maskrom Fail" when execute "sudo upgrade_tool uf update.img"
Do you have any idea?
The log as shownbelow:
bico@bico:~/luckfox/docker/luckfox-pico/output/image$ sudo upgrade_tool uf update.img
Loading firmware...
Support Type:1106 FW Ver:0.0.00 FW Time:2024-10-06 16:09:32
Loader ver:1.01 Loader Time:2024-10-06 15:03:32
Start to upgrade firmware...
Download Boot Start
Download Boot Success
Wait For Maskrom Start
Hello maskrom mode needs to press and hold the boot key while connecting the power supply and then releasing the boot key trigger (or press the boot key and press the reset key and release the boot key trigger), if you are sure that there is no problem with the operation, please provide the log of serial output(need USB-to-serial port tool), which helps to further determine where the problem occurs.
