it compiles and load just fine
usb is detected
but it isn't recognized as wifi card
i also installed files inside "drv_ko" inside kernel source code from sdk
https://github.com/lwfinger/rtl8xxxu
ubuntu: can't get rtl8xxx_git working
Hello, the link you provided https://github.com/lwfinger/rtl8xxxu uses the dkms method to implement the kernel module loading on the board, but for the resource-constrained chip such as luckfox pico, it is not suitable for kernel compilation on the board side, and the kernel module can only be added by burning a new image after PC compilation. Therefore, after loading the rtl8xxx.ko file generated by the drv_ko compilation, you also need to add USB network card support (such as USB_NET_DRIVERS, etc.) in the kernel, and it should also be noted that the WiFi module may also need to load firmware, and the firmware used needs to be placed in a specific location
i got it working,
firmware was not included in driver repo or firmware package(deb) but i could get from somewhere else
i attached prebuilt one for someone who might need
extract drv_ko.tgz and copy content to /
extract rtl3.tgz and "make install"
install firmware according to message that appears in dmesg
- Attachments
rtl3.tgz (4.06 MiB)
- rtl8xxxu_git module
Downloaded 566 times
drv_ko.tgz (823.76 KiB)
- modules including cfg80211
Downloaded 545 times
Thanks for sharing.sodo wrote: ↑2024-10-10 8:34 i got it working,
Did you have to do anything ense to get this to work ?
I have the driver installed and loaded but all I see is wlan0 (the onboard wireless) and I was expecting to see a wlan1 for the USB dongle...
Any hints welcome.
Any hints welcome.
root@luckfox:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@luckfox:~# lsmod
Module Size Used by
rtl8xxxu_git 136155 0
mac80211 264707 1 rtl8xxxu_git
aic8800_fdrv 272882 0
aic8800_bsp 46005 1 aic8800_fdrv
aes_generic 24532 0
ccm 6847 0
ctr 2606 0
libarc4 799 1 mac80211
cfg80211 168757 3 mac80211,aic8800_fdrv,rtl8xxxu_git
video_rkcif 130130 0
phy_rockchip_csi2_dphy_hw 8161 0
phy_rockchip_csi2_dphy 7674 0
ipv6 226496 23Code: Select all
root@luckfox:~# nmcli device
DEVICE TYPE STATE CONNECTION
eth0 ethernet connected Wired connection 1
wlan0 wifi disconnected --
p2p-dev-wlan0 wifi-p2p disconnected --
lo loopback unmanaged -- have you checked your dmesg?IndianaTux wrote: ↑2024-10-26 4:00 Hi,
Any hints welcome.
root@luckfox:~# lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@luckfox:~# lsmod Module Size Used by rtl8xxxu_git 136155 0 mac80211 264707 1 rtl8xxxu_git aic8800_fdrv 272882 0 aic8800_bsp 46005 1 aic8800_fdrv aes_generic 24532 0 ccm 6847 0 ctr 2606 0 libarc4 799 1 mac80211 cfg80211 168757 3 mac80211,aic8800_fdrv,rtl8xxxu_git video_rkcif 130130 0 phy_rockchip_csi2_dphy_hw 8161 0 phy_rockchip_csi2_dphy 7674 0 ipv6 226496 23Code: Select all
root@luckfox:~# nmcli device DEVICE TYPE STATE CONNECTION eth0 ethernet connected Wired connection 1 wlan0 wifi disconnected -- p2p-dev-wlan0 wifi-p2p disconnected -- lo loopback unmanaged --
it may show some firmware missing
you can get it from anywhere
also my one is compiled for luckfox pico
if this is not the same board, you can try compiling yourself
