Luckfox pico pro max, the light doesn't come on, but it recognizes it normally on the PC!!!
  • ailton10 wrote: 2024-10-19 5:39 my luckfox is having problems, the toolkit program recognizes it but when writing the flash it gives this Error:Write LBA failed,can't read flash id from device!
    and it doesn't turn on anything, but it recognizes it on the PC!! Does anyone have an eprom file to rewrite?
    Hello, there are many cases of Write LBA faild! (such as cable problems or computer USB port problems), not necessarily flash problems, if you have the conditions, you can use the serial module to observe the output of the serial port in burn mode (UART2_M1 near the TypeC port of the serial port), and observe whether there are other logs printed. You can refer to F&Q:https://wiki.luckfox.com/zh/Luckfox-Pic ... x-Pico-FAQ
