I have a Luckfox Pico Mini B and I went through the tutorial of Flashing the SPI NAND Flash. I flashed the image from Firmware\backup\luckfox_pico_mini_b_image available on google.
I have disabled my Public and Private network firewall and setup the static IP of this Pico device to 172.32.0.100 as mentioned in tutorial. Still I am unable to login to the device. I get the above error ssh: connect to host 172.32.0.93 port 22: Connection refused.
I have also gone through the below forums but it was of no help. Since I do not get the enter password prompt.
viewtopic.php?t=837
viewtopic.php?p=1881&hilit=172.32.0.93#p1881
If you need more clarity please mention, I will provide them.
This got solved when I used another image located in Firmware\buildroot\Luckfox_Pico_Mini_Flash\mini_buildroot_spi.
Could you tell me the use of the backup folder and why the image kept there did not work?
Hello, the image placed in the backup folder is an early version. Some content in the current wiki may not have been adapted in the early days. If you use it, use the latest image first.
