How to add multiple wifi connections to Luckfox Pico Ultra w.
I have added wpa_supplicant.conf like below.
ctrl_interface=/var/run/wpa_supplicant
ap_scan=1
update_config=1
network={
ssid="Home24GHz"
psk="Joxxxxxx"
key_mgmt=WPA-PSK
network={
ssid="Office2.4GHz"
psk="Boxxxxxx"
key_mgmt=WPA-PSK
May I know is this correct
Thanks,
Naveen
Hello, there is no problem with your settings. If necessary, you can add the "priority" attribute to set the priority to ensure that two wifi can be connected at the same time. You can choose the one you want.Like this:
network={
ssid="xxx"
psk="xxx"
key_mgmt=WPA-PSK
priority=1
