Pico_Max Recovery
Posted: 2024-11-18 8:00
by Traktorist3d
Hello everyone, guys, help me restore Pico_Max, I messed up something with the firmware, now when connecting via USB the LEDs do not light up, and in the device manager it is seen as an incomprehensible device for which I cannot find drivers. Is there a chance to fix it and return Pico to the factory state and the ability to run firmware from MicroSD.
Re: Pico_Max Recovery
Posted: 2024-11-18 9:01
by Eng33
I think it is caused by you not installing the corresponding driver, please refer to our wiki .erasing -spi-nand-flash
and create SD card
https://wiki.luckfox.com/Luckfox-Pico/L ... nand-flash
Posted: 2024-11-18 12:09
by Traktorist3d
Eng33 wrote: 2024-11-18 9:01 I think it is caused by you not installing the corresponding driver, please refer to our wiki .erasing -spi-nand-flash
and create SD card
No, my friend, that's not the issue, and I installed the driver. I have a second Pico_Max and it always blinks the LED when power is supplied, but the faulty one doesn't blink. And it doesn't boot from a working micro sd with a working system, which boots normally on the third-party Pico_Max
Posted: 2024-11-20 2:15
Hello, LED does not flash means that it has not entered the kernel loading stage, if you can boot the system in another SD card can not make this problem Pico_Max start may be hardware damage, PC can also identify Rockusb Device Description bootrom and DDR is able to run normally, if there is a serial debugging tool, then provide a bit after inserting SD card after power-on printed content, you can easily find out where the problem is
We provide an image on the network disk at https://wiki.luckfox.com/Luckfox-Pico/Download/ , where you can also perform flashing and testing.
