How to build the newest u-boot, kernel, and buildroot on a Luckfox-Pico-Max?
How to build the newest u-boot, kernel, and buildroot on a Luckfox-Pico-Max?Welcome to Longer Vision Technology
Due to the limited resources of the development board, these operations must be completed on the PC.
We don't seem to be able to build much on a Pico right now, because attempting to compile *anything* with GCC on the current Ubuntu image results in a linker error:
/usr/bin/ld: cannot find -lgcc: No such file or directory
...that apparently could be solved by installing gcc-multilib, which unfortunately doesn't exist for Ubuntu on Arm.
Clang may work, depending on what you're trying to make, but cross-compiling is really the only practical approach right now.
TatSledge wrote: ↑2024-02-14 16:47 We don't seem to be able to build much on a Pico right now, because attempting to compile *anything* with GCC on the current Ubuntu image results in a linker error:
Due to the limited resources on the development board, we recommend users to use cross-compilation. If the development board is flashed with Ubuntu system and you want to run programs on it, the general process is as follows:
1. Install the cross-compiler on the Ubuntu computer host or virtual machine.
sudo apt install gcc-arm-linux-gnueabihfCode: Select all
arm-linux-gnueabihf-gcc test.c -o test
