Luckfox Pico 更新通知(Luckfox Pico Update Notice)
  • Luckfox Pico 更新通知(202407)。以下为简单的发布说明,
    了解更多详情:
    GitHub链接:https://github.com/LuckfoxTECH/luckfox- ... ADME_CN.md
    Gitee链接:https://gitee.com/LuckfoxTECH/luckfox-p ... ADME_CN.md
    Wiki 链接:https://wiki.luckfox.com/zh/Luckfox-Pico/Download
    论坛链接:index.php
    更新说明
    • 增加了对 Luckfox-pico-Ultra 和 Luckfox-pico-Ultra-W 的支持
    • 增加了RGB屏幕切换分辨率的功能
    • 增强包管理操作,使用 ./build.sh buildrootconfig 命令直接进入menuconfig选项界面
    • 增强内核配置操作,使用./build.sh kernelconfig 命令直接进入menuconfig选项界面
    • 增加了luckfox-config系统配置工具,可以在开发板上快速启用或禁用特定的接口,例如 I2C、SPI、GPIO 、UART和USB等端口
    • 优化了./build.sh clean rootfs 会全删buildroot的问题
    • 优化系统根文件系统打包流程,允许自定义`<Luckfox-pico SDK PATH>/output/out/rootfs_uclibc_rv1106`夹中的根文件
    • 修复在编译Ubuntu过程中下载软件包失败等问题
    • 开源 Luckfox Pico Ultra系列完整的原理图
    Luckfox Pico Update Notification (202407). Below is a brief release note:
    For more details:
    GitHub link: https://github.com/LuckfoxTECH/luckfox- ... ADME_CN.md
    Gitee link: https://gitee.com/LuckfoxTECH/luckfox-p ... ADME_CN.md
    Wiki link: https://wiki.luckfox.com/zh/Luckfox-Pico/Download
    Forum link: index.php
    Update Notes
    • Added support for Luckfox-pico-Ultra and Luckfox-pico-Ultra-W
    • Added functionality to switch resolutions on RGB screens
    • Enhanced package management operations, allowing direct access to the menuconfig interface using the ./build.sh buildrootconfig command
    • Enhanced kernel configuration operations, allowing direct access to the menuconfig interface using the ./build.sh kernelconfig command
    • Added the luckfox-config system configuration tool, enabling quick enablement or disablement of specific interfaces on the development board, such as I2C, SPI, GPIO, UART, and USB ports
    • Optimized the ./build.sh clean rootfs command to prevent it from deleting the entire buildroot
    • Optimized the system root filesystem packaging process, allowing customization of the root files in the <Luckfox-pico SDK PATH>/output/out/rootfs_uclibc_rv1106 directory
    • Fixed issues with downloading software packages during Ubuntu compilation
    • Open-sourced the complete schematics for the Luckfox Pico Ultra series
  • Luckfox Pico 更新通知(202411)。以下为简单的发布说明,
    了解更多详情:
    论坛链接:index.php
    更新说明
    • 内核更新至 5.10.160,升级 RKNN 和 ROCKIT 驱动,RV1106G3 可以在设备树中开启超频使 NPU 算力达到 1 TOPS
    • 增加了快速启动支持,可以实现在 1 s 内进入根文件系统,支持将 Luckfox Pico 模拟为 UVC 摄像头,目前适配了 Luckfox Pico Ultra / Luckfox Pico Ultra W / Luckfox Pico Pro / Luckfox Pico Max
    • 增加自定义根文件系统功能,可以快速替换为第三方根文件系统
    • 规范客制化根文件系统的方式,在 rootfs.img 构建时按文件系统结构替换或添加文件
    • 增加USB Peripheral模式下因接触不良断开重新连接的功能
    • 优化 spi-nand 构建镜像的存储空间布局
    Luckfox Pico Update Notification (202411). Below is a brief release note:
    For more details:
    Update Notes
    • The kernel has been updated to version 5.10.160, with upgraded RKNN and ROCKIT drivers. For RV1106G3, overclocking can be enabled in the device tree, boosting NPU performance to 1 TOPS.
    • Added fast boot support, enabling the system to enter the root filesystem within 1 second and emulate as a UVC camera. Currently, it is compatible with Luckfox Pico Ultra, Luckfox Pico Ultra W, Luckfox Pico Pro, and Luckfox Pico Max.
    • Introduced a custom root filesystem feature, enabling quick replacement with third-party root filesystems.
    • Standardized the customization of root filesystems by replacing or adding files according to the filesystem structure during `rootfs.img` construction.
    • Added reconnection functionality in USB Peripheral mode to address disconnection issues caused by poor contact.
    • Optimized SPI-NAND image storage layout to improve space utilization.
