I am following the Buildroot Configuration procedure (
https://wiki.luckfox.com/Luckfox-Pico/L ... -Buildroot) and after I have done the menu config and then run:
I am getting:
make: *** No rule to make target 'savedconfig'. Stop.
I don't think I am doing anything wrong. Is this error normal?
Then when I go to recompile the image, I get:
start build fakeroot image
mkfs.ubifs
root: /root/sdk/luckfox-pico/output/out/rootfs_uclibc_rv1106/
min_io_size: 2048
leb_size: 126976
max_leb_cnt: 660
output: /root/sdk/luckfox-pico/output/image/.ubi_cfg/rootfs_2KB_128KB_80MB.ubifs
jrn_size: 8388608
reserved: 0
compr: lzo
keyhash: r5
fanout: 8
orph_lebs: 1
space_fixup: 1
Error: max_leb_cnt too low (666 needed)
[mkfs_ubi.sh:error] Running main failed!
[mkfs_ubi.sh:error] exit code 255 from line 341:
[mkfs_ubi.sh:info] $FAKEROOT_TOOL -- $ROOTFS_IMAGE_FAKEROOT_UBI
[build.sh:error] Running build_mkimg failed!
[build.sh:error] exit code 255 from line 1742:
[build.sh:info] $RK_PROJECT_TOOLS_MKFS_UBIFS $src $(dirname $dst) $part_size $part_name $fs_type $RK_UBIFS_COMP
This "Error: max_leb_cnt too low (936 needed)" error seems pretty consistent and when I go back and deselect packages the "mex_leb_cnt" just gets higher.
torchris4 wrote: ↑2024-02-12 15:26
I am getting:
mkfs.ubifs
min_io_size: 2048
leb_size: 126976
max_leb_cnt: 660
jrn_size: 8388608
reserved: 0
compr: lzo
keyhash: r5
fanout: 8
orph_lebs: 1
space_fixup: 1
You entered the command incorrectly. Please carefully follow the instructions in the tutorial when entering commands.
